RTW vs. RTW embedded coder
I have downloaded your software of install_dsPIC_R2006b.m dated 2007/12/09.
After installing it, I had tried to compile Servo_sinus.mdl, then came accross an error.
The following is translation from Japanese error message:
Block diagram 'Servo Sinus' Real-Time Workship target build error.
Matlab Error Message:
Error:==> callMakeHook.p>callMakeHook
Real-Time Workshop Embedded Coder's license cannot be found.
Current target: C:\matlab\install_dsPIC_R2006b\dspic\dspic.tlc
We have Real-Time Workshop instead of Real-Time Workshop Embedded Coder.
Is this a problem?
Is this a problem?
Re: RTW vs. RTW embedded coder
Hi Masaki,
Real Time Workshop Embedded Coder is required for the dsPIC blockset.
It will not work without RTW Embedded Coder. (RTW Embedded Coder works on top or Real Time Workshop, so you need both)
