dspic30f6010
dspic30f6010
hi
when I am using variable on c30 compiler those are not intialized to the given value. it is showing out of scope , restricted memory in watch window. can u suggest me the solution?
Is there any connexion with Simulink and the Blockset for dsPIC ?
I guess you are not on the right forum ! Anyway, you could try to remove compiler optimisation...
