problems with embedded coder
dan
Do you guys know if the library for real time embedded coder for dspic for matlab r2009b is working properly, is there any bug? Because I'm encountering errors when performing the example available in the site, Log and plot datas from the PIC with Matlab, it is a very simple test. But when a press start in the rsr232gui nothing happens, I mean, that should appear a graph showing the pulses signals. Just a backslash appears spinning in the field os Bytes.
