dsPIC and PIC 18F
dsPIC and PIC 18F
vedant
Hi i have seen your work on dsPIC toolbox and also had a look at your resume. Was very impressed . Can you please send me the toolbox for PIC 18 F4580 so that i can work on my project.
Hi Vedant,
The PIC18F family do not use the same C compiler.
I looked at the possibility to do a toolbox for 18F chips long time ago ( 2 or 3 years) and concluded that the C compiler for PIC18 I used (from Hi-tech) was not Compliant with the standard C, thus, it does not work with C code generated with the matlab Real Time Workshop Embedded Coder.
Consider using a dsPIC or PIC24 if you want to generate your code with matlab and the toolbox I created. You could also have a look on the SimuQuest companie that propose a toolbox for some PIC18. Let us know if the product is good.
Lubin KERHUEL
arsen
pic 16F84A/16f87X
hi again Lubin,
my tool is working fine and everything goes well( ı ve got compiling problem some weeks ago maybe u remember) now i ve another question to you about pic 16f84A or 16f87X. İs ir possible to use 16f84A /16f87X with your tool ?? i would like to use this pic cos its very cheap and easy to find etc..
also i ve compared 16f with 30f , 30f has a lot of fetures and abilities , since i am gonna embedd very simple programma i think i dont need 30f,
i hope that 16f84Aor 16f87X works with ur tool
thanx for now
arsen
Re: dsPIC and PIC 18F
Hi Arsen,
I'm glad your "tool" is working fine now.
The blockset do not support 16f chips and there is no plan to support 16f in the near futur ;-).
arsen
hi lubinnn,
thanx again for your quick responce, so then i ve got to use from your supported chips , then i ve got onother question , as a begginner ( and my programme is not that big space only controlling leds with diiferent time cycles, for example i ve got 2or 3 inputs in every 30 sec cycle and according to these inputs, as an output i ve got to switch some leds on some not or switch some leds for 30 sec on or X sec on, depending on the input ) which chip model would you advise for real application which one is more stable for real application ( ofcourse among the chips which are supported from ur tool)
thanx again
arsen
Hi Arsen,
Coudn't give you an usefull advice. All chips seems to works well for direct I/O input/output.
sreenatg
Can i have the PIC 18F 4580 blockset. I would be greatfull if someone help me on this.
