Warning at opening time and can't open dialog in library
Warning at opening time and can’t open dialog in library
northbear
hi, Lubin
I dowload the "install_dsPIC_R2007a.zip" from your website today, then install it acording to your installing instructions. all is ok.
but, when dual click the "Embedded Tartget for Microchip dsPIC" from the "Simulink Library Browse", the following warning occurs:
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> dsPIC_ConfigRTWOption at 34
The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==> Configuration Parameters ==> Real Time workshop.
> In load_system at 52
In libbrowse>i_LoadSys at 142
In libbrowse>LoadLibrary at 121
In libbrowse at 24
why?
Expect your reply.
and the "dsPIC_33f_Explorer16.mdl" can be open, but the warning is followed:
>> open dsPIC_33f_Explorer16.mdl
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/Master' : Invalid setting in Master block (mask) 'Master' for parameter 'FPBOR'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/Master' : Invalid setting in Master block (mask) 'Master' for parameter 'MCLR'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'ADC_TYPE12'.
> In F:\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 4
In F:\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 87
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'VoltRef'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'OutFormatBits'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'NCHANNEL'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'ANCHANNELS_BITEWISE'.
In open at 146
NbrPortUsed is 6
why?
Citation : northbear
hi, Lubin
In libbrowse at 24
why?
The blockset dialog box can only be opened when they are placed into a simulink diagram file with the correct parameters set (Fixed Step, and Target File defined as dsPIC)
(for Simplicity, you could start your new diagram from an example file given.)
In open at 146
In open at 146
In open at 146
In open at 146
In open at 146
In open at 146
In open at 146
NbrPortUsed is 6
why?
don't take attention to warning appearing at oppening of a diagram. While oppening diagram, each block are loaded and initialized one after another. However, some blocks need other blocks to be loaded before them.
Note that once the diagram is fully loaded, all blocks are initialized. These warning should not appear when presing the update button.
