Please support 32MX320F128H
Digilent has released the Cerebot MX3 cK board.
I would like to use it because It is small and cheap.
Please consider supporting the 32MX320F128H chip in your next blockset release.
Regards,
Regards,
Re: Please support 32MX320F128H
Until you get around to it,
How would I modify the code generated for one chip to work on a different chip?
Hello John,
32MX320 & 32MX340 chips are now added in latest version (3.7d).
Modifying generated code is pretty easy through MPLAB as the MPLAB 8 or MPLAB X project are created with the source code.
However, that might be quite complicated if chip is too different from an existing chip.
Adding new chip into the blockset is not currently supported.
Thanks Lubin.
