Recive Multiple Data from the same UART
Vladimir Dvorkin
I am using dsPic 30F4011 microcontroller.
I am commuincating with the dsPIC using Xbee Pro series 1 modules, and using Simulink's Real Time Workshop.
I am trying to send multiple data from my RTW model (see attachment) using mux function and sending threw Packet output.
I can't split the recieved data vector using demux, since the UART Rx Block produce 1 output uint 8 signal, and matlab wont let me compile my program!
How can I recieve multiple data from the same UART port? (e.g. turn on LED with PORTB0, and conrol PWM)
Vladimir
Pièce jointe : LED_PWM.mdl
Pièce jointe : rtw.mdl
resodad
Re: Recive Multiple Data from the same UART
Vladimir,
You want to parse incoming data (UART Rx). I did similar for Tx. See the post "Rx Interrupt buffer size" linked here: http://www.kerhuel.eu/forum/viewtopic.p ... +uart#p453.
You might get some ideas that will work for you.
Regards,
