Error on compilation of examples in dspic toolbox
Hi everyone,
I have matlab2006a installed with Simulink version 6.4,Real-Time Windows Target version 2.6.1, Real-Time Workshop version 6.4 and Real-Time Workshop Embedded Coder 4.4.
I have downloaded and installed the "dspic toolbox for matlab 2006a" from the link
http://www.kerhuel.eu/wiki/Release_Notes
The installation of the toolbox is completed. When i run the following command to check the perfect installation of the toolbox, i got error.
cd examples
compileallmodels
The error which i have obtained is "Error evaluating 'openfcn' callback of master function. RTW system target must be defined to dspic.tlc.
But the simulink->configuration parameters -> real time workshop -> system target file is already pointing dspic.tlc only.
!gake command and !pic30-gcc and !pic30-gcc -v command are normal. (as per many errors discussed in the forum)
I have MPLAB c30 compiler student version 3.11b installed in the system.
I have worked with corresponding blocksets in matlab 2007a and 2010a. I didn't get any problem like this. So i cant conclude that this maybe the problem of compiler.
Anybody help me to overcome this problem???????????
cd examples
compileallmodels
