MPLAB X link post-compilation errors
bmairs
Clicking the MPLAB X link within MATLAB gives me an error and doesn't launch MPLAB X. The link for launching MPLAB 8, however, is correct.
Here is what I see at the end of compilation along with the errors. After compilation I clicked the MPLAB X link, then the MPLAB 8 link, then the MPLAB X link again, which is what the additional output shows.
"    ---33fJ256GP710---"
"*** Created "executable": ..\../code_gen.cof"
''pic30-bin2hex ..\../code_gen.cof
"*** Converted code_gen.cof to code_gen.hex"
"***  MPLAB: file -> import, choose code_gen.hex. Configure -> Configuration Bits : Verify !"
"       Download into the chip and run."
### Successful completion of Real-Time Workshop build procedure for model: code_gen
***  You could open project created and (re)compile it :
   	  ==> MPLAB 8: Within Matlab, right-click code_gen.mcp -> open outside Matlab.
   	  ==> MPLAB X: Start MPLAB X, open the project folder C:\Users\Bryant\Projects\Autoboat\Code\basic_model\code_gen_dspic
???  disp('Starting MPLAB X...
Error: A MATLAB string constant is not terminated properly.
Starting MPLAB 8...
Starting MPLAB 8...
Re: MPLAB X link post-compilation errors
Thanks for bug report,
bug corrected in version 3.6c. Note however than MPLAB X do not open your project (like MPLAB 8). I do not know yet how to make this happend...
