Required Matlab components
Can you please state what components / toolboxes are required to use the blockset?
e.g. Matlab, Simulink, Simulink Coder (formerly Real Time Workshop), and Embedded Coder...
did I miss anything?
Re: Required Matlab components
You listed the minimum required toolboxes. EC (Embeddede Coder) is the most important !
for designing efficient embedded system, the fixed point toolboxes is very useful.
Stateflow might also be usefull if you are to design FSM.
Then all matlab toolboxes related to your topic (system identification, control toolbox, optimisation...)
I see that Matlab coder is required to run embedded coder.
Thus EC works on top of Matlab Coder ?
Thanks Mathworks ;-)
This kind of explains it: http://blogs.mathworks.com/seth/2011/04 ... he-coders/. But when installing I was required to add Matlab Coder in addition to these like resodad mentioned. Looks like the base requirements are: Matlab, Simulink, Simulink Coder, Embedded Coder, and Matlab Coder.
