PTfile not found
PTfile not found
schloudara
This is my first attempt to get started with the dsblock set.
I'm running Matlab R2010.a 32bit and installed the C30 and C32 compiler as well as the dsblockset. That worked out fine.
Then I wanted to create a new simulink model and draged the blocks "configure model" and "compile for dspic" as well as the "Master block" in a new window. Looking at the worksspace there occured the error:
TimeStep was undefined and is set to : 0.001
System target file set to dspic.tlc
file not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC30F\libpchoose_dsPIC_Target-coff.a
Model configured...
PNumber of I/O PINs used : 0
T>>
I want to use the whole thing on a PIC32MX795F512L (USB starter kit II)
Therefore I think I need the C32 Compiler. Can I therefore ignore this error, because it refers to dsPIC30F?
Plz Help, I'm new to this... Thanks so far
schloudara
Re: PTfile not found
When I select PIC32MX795F512L in the "Master block" new error occure:
Tfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC30F\libpchoose_dsPIC_Target-coff.a
PTfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC30F\libpchoose_dsPIC_Target-coff.a
TTfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC30F\libpchoose_dsPIC_Target-coff.a
TTfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libp32MX795F512L-coff.a
directory not found : C:\Program Files (x86)\Microchip\mplabc32\v2.01\pic32mx\include
--> corrected : find in C:\PROGRA~2\MICROC~1\mplabc32\v2.01\pic32mx\include
Warning: The dialog of 'untitled/Master' is being closed because a mask parameter has been changed
> In C:\Program Files (x86)\DSPIC Blockset\blocks\dsPIC_Set_Dialog_PopUp_Param.p>dsPIC_Set_Dialog_PopUp_Param at 57
In C:\Program Files (x86)\DSPIC Blockset\blocks\dsPIC_MASTER_callback_InitMask.p>dsPIC_MASTER_callback_InitMask at 269
file not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpchoose_dsPIC_Target-coff.a
directory not found : C:\Program Files (x86)\Microchip\MPLAB C30\include
--> corrected : find in C:\PROGRA~2\MICROC~1\MPLABC~2\include
Tfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpchoose_dsPIC_Target-coff.a
PTfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpchoose_dsPIC_Target-coff.a
PTTfile not found : C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpchoose_dsPIC_Target-coff.a
PTT>>
Is this ok?
Greetings
Hey,
Choose a dsPIC within the MASTER block.
Until you select a chip, the default pic usd is called "choose_dsPIC". Obviously compiler definition files for that chip does not exist !
Anyway, thanks for the bug report, I might try to help user for that.
schloudara
Thanks for the fast answer!!
However the error, as I wrote before, occured also as I choose the right PIC.
Anyways I just ignored it and wrote a simple program and everything worked out fine.
Big thanks for this blockset, it is very useful!!
