Simulink : Creating a Mask with tabs
yannick
I am wondering if there is a way to create "tabs" in a simulink mask? An easy example is the Constant block. It has a "Main" tab and a "Signal Attributes" tab.
I have looked for documentation on this and I haven't be able to find anything that even mentions it.
Yannick
yannick
Re: Simulink : Creating a Mask with tabs
What I found is you can't create any tab in a mask with the version before 2009.
With the version 2009, in the parameters mask, when you add a parameter, there is a column named tab name or somethink like that. You just have to put the name you want and it works !
