Port Info block annotation
Can the port info block be extended to include a mask where the individual pins can be manually annotated. This would be very useful for documentation.
So if I was using two pins: RA0 and RA1 I could double-click on the block and the mask parameters would pop up and I could add notes about those pins. So I could add "Reset status - LED D3" and "HIL status - LED D4" into those notes. The block would then display the notes on the front along with the pin and associated peripheral.
