Simulink to dspic
Simulink to dspic
This is a model of a PWM rectifier in simulink I want to translate Blokset / MATLAB to program a dsPIC 30F4011 to Implement
But when I reflected I do not find output to the terminal dsPIC knowing that input is a sine wave and ferquence 50 hz
Can you help me about this problem?
thanks
Elmay
thanks
Elmay
Re: Simulink to dspic
Hi Elmay,
I do not understand what your model is supposed to do.
The input capture Up signal connected to a boolean data type conversion will provide you 1 until the Up period of the input signal is not 0.
you might use the rising edge detection of this block. In the input capture block, you might set the "Change Detected on" option to 1 for rising edge (see block dialog box).
You might also use only one block PWM_motor. Select three channels output. (output channel will be [1 2 3] )
