CAN block on 33fj256MC710 target
I'm evaluating the 3.4c blocket (Matlab 2010a) on a 33fj256mc710 target. When I place te CAN configuration block on a model it states "No CAN Peripheral on 33fj256MC710'", which doesn't seem to be correct. Any ideas?
Re: CAN block on 33fj256MC710 target
Ah - I see that the blockset doesn't support ECAN - only CAN.
Reading the forum it looks as if ECAN was on the roadmap back in 2008, but still hasn't made it into the blockset.
The slug team provide me with all the sources to do quickly the ECAN module. However, I still haven't done it yet, even if I started few month ago.
Anyway, you might use ECAN peripheral using the C call function and the c sources code provided by the slug team (you should fine on the forum a git repository with theses sources, or a post from Bryant Mairs (bmairs) )
Thanks for the pointer Lubin, I'm sure the SLUGS code will be a great help.
See post http://www.kerhuel.eu/forum/viewtopic.p ... 1525#p1525 for link to a git repository with ECAN projects from Bryant Mairs.
