Generated MPLAB projects don't allow debugging
Generated MPLAB projects don’t allow debugging
bmairs
The MPLAB projects that are generated on compilation don't set up the compilation within MPLAB to allow for debugging and stepping through the code. This is generally what I want to do when I go to use MPLAB. I've found that changing the following options allow for code step-through and variable watching:
Project->Build options->Project under the MPLAB LINK30 tab, Diagnostics category select "Generate map file"
Project->Build options->Project under the MPLAB C30 tab, General category select "Generate debugging information"
Would it make sense for these options to be set by default in the generated MPLAB projects?
bmairs
Re: Generated MPLAB projects don't allow debugging
If I change just those two settings I mentioned above, then the .mcp file TOOL_SETTINGS section looks as follows:
[TOOL_SETTINGS]
TS{7D9C6ECE-785D-44CB-BA22-17BF2E119622}=
TS{25AC22BD-2378-4FDB-BFB6-7345A15512D3}=-g -O3 -fschedule-insns -fschedule-insns2
TS{7DAC9A1D-4C45-45D6-B25A-D117C74E8F5A}=-Map="$(BINDIR_)$(TARGETBASE).map" --report-mem -o"$(BINDIR_)$(TARGETBASE).$(TARGETSUFFIX)"
TS{509E5861-1E2A-483B-8B6B-CA8DB7F2DD78}=
The bold parts are the only things that've changed.
Thanks Bryant,
This will be taken into account in the next release (after 3.4c).
