MPLAB Compilation
MPLAB Compilation
[/img] hello Sir
I am a program SIMULINK / BlockSet and it works in MATLAB
but while running under MPLAB m'apparair following error:
Failed to import Generated Files. Check the Build Window to know the Status of Build
[/b][/size]
[/b][/size]
</i>Opening Matlab session and model 'D:\Documents and Settings\ELMAY\Bureau\DRAFT\MPH.mdl'
Please wait...
Warning: Could not find an exact (case-sensitive) match for 'ExecBatch'.
D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\execBatch.p is a case-insensitive match and will be used instead.
You can improve the performance of your code by using exact
name matches and we therefore recommend that you update your
usage accordingly. Alternatively, you can disable this warning using
warning('off','MATLAB:dispatcher:InexactCaseMatch').
This warning will become an error in future releases.
> In D:\Program Files\MATLAB\R2009b\toolbox\rtw\rtw\private\getSTFInfo.p>getSTFInfo at 77
In <a href="matlab: opentoline('D:\Program Files\MATLAB\R2009b\toolbox\rtw\rtw\rtwprivate.m',12,1)">rtwprivate at 12</a>
In <a href="matlab: opentoline('D:\Program Files\MATLAB\R2009b\toolbox\rtw\rtw\stf4target.m',34,1)">stf4target at 34</a>
In <a href="matlab: opentoline('D:\Program Files\MATLAB\R2009b\toolbox\rtw\rtw\stf2target.m',61,1)">stf2target at 61</a>
In <a href="matlab: opentoline('D:\Program Files\Microchip\MPLAB IDE\Tools\Matlab\MplabOpenModel.m',14,1)">MplabOpenModel at 14</a>
Warning: GMAKE_PLACE not defined, check tlc target
> In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 45
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 87
Warning: The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==> Configuration Parameters ==> Real Time workshop
> In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 407
PWarning: --- =========> PORT A0 is used by at least two peripheral <========= ---
> In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>setTypePort at 521
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 74
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 89
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 132
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 149
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 231
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 261
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 281
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 283
In D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PortSetting.p>dsPIC_PortSetting at 300
Warning: SubSystem block (mask) does not have a parameter named 'T1CSL'.
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. SubSystem block (mask) does not have a parameter named 'T1CSL'.
PTodel at 14</a>
Succesfully Opened The Model
Generating files for Simulink model 'D:\Documents and Settings\ELMAY\Bureau\DRAFT\MPH.mdl'. This may take a few minutes.
Please wait...### Starting Real-Time Workshop build procedure for model: MPH
### Generating code into build directory: D:\Documents and Settings\ELMAY\Bureau\DRAFT\MPH_dspic\sources
PTPNumber of I/O PINs used : 1
TPTPTTPNumber of I/O PINs used : 1
TTTTPTPTPTTPNumber of I/O PINs used : 1
TPTTWarning: Source 'MPH/Subsystem/Sine Wave1' specifies that its sample time (-1) is back-inherited. You should explicitly specify the sample time of sources. You can disable this diagnostic by setting the 'Source block specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the Configuration Parameters dialog box.
### Invoking Target Language Compiler on MPH.rtw
D:\Documents and Settings\ELMAY\Bureau\DRAFT\MPH_dspic\sources\MPH.rtw
D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\dspic.tlc
-OD:\Documents and Settings\ELMAY\Bureau\DRAFT\MPH_dspic\sources
-ID:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic
-ID:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks
-ID:\Documents and Settings\ELMAY\Bureau\DRAFT\MPH_dspic\sources\tlc
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\mw
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\lib
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\blocks
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\fixpt
-ID:\Program Files\MATLAB\R2009b\stateflow\c\tlc
-aInlineInvariantSignals=0
-aInlineParameters=0
-aInitFltsAndDblsToZero=0
-aForceBlockIOInitOptimize=0
-aGenerateTraceInfo=0
-aIgnoreTestpoints=0
-aSuppressErrorStatus=1
-aPortableWordSizes=0
-aGMAKE_PLACE="D:\PROGRA~1\MATLAB\R2009b\bin\win32\gmake"
-aOPTIM_GCC="-mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2"
-aLDFLAGS=" -Xlinker -t -Xlinker --report-mem -Xlinker -Map=../untitled.map -Xlinker --heap=0 -Xlinker -cref"
-aLDPICTYPE=" -Xlinker --script=D:\PROGRA~1\MICROC~1\mplabc30\v3.25\support\dsPIC30F\gld\p30f4013.gld"
-aLDLIBPIC=" D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f4013-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a"
-aPIC_INCLUDES=" -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include"
-aPIC_REF="30f4013"
-aGCCPATH=""
-aProtectedModelReferenceTarget=0
### Writing header file MPH_types.h
### Writing header file MPH.h
### Writing source file MPH.c
### Writing header file MPH_private.h
### Writing source file MPH_data.c
### Writing source file MPH_main.c
Embedded Coder for dsPIC V3.4b(14-Jan-2011) for Matlab R2009b.
Licence Accorded to Demonstration Version
[adresse e-mail retirée]
Author : Lubin KERHUEL
WEBSITE : http://www.kerhuel.eu/wiki
SIRENE : 503 920 456
SIRET : 503 920 456 00012
Facturation to : Demo
Demo
Lubin KERHUEL
1, rue Alfred Fredet
38100 Grenoble
FRANCE
Check updates and new informations at : <a href = "http://www.kerhuel.eu/wiki/index.php5#3"> www.kerhuel.eu </a>
### Processing Template Makefile: D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\dspic_pic30_gcc.tmf
### MPH.mk which is generated from D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\dspic_pic30_gcc.tmf is up to date
### Building MPH: "D:\PROGRA~1\MATLAB\R2009b\bin\win32\gmake" -f MPH.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc -c -mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -ID:\PROGRA~1\MATLAB\R2009b/simulink/include -ID:\PROGRA~1\MATLAB\R2009b/extern/include -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/ert -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src/ext_mode/common -ID:\DOCUME~1\ELMAY\Bureau\DRAFT\MPH_dspic\sources -ID:\DOCUME~1\ELMAY\Bureau\DRAFT -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include MPH_data.c
''pic30-gcc -c -mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -ID:\PROGRA~1\MATLAB\R2009b/simulink/include -ID:\PROGRA~1\MATLAB\R2009b/extern/include -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/ert -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src/ext_mode/common -ID:\DOCUME~1\ELMAY\Bureau\DRAFT\MPH_dspic\sources -ID:\DOCUME~1\ELMAY\Bureau\DRAFT -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include MPH_main.c
''pic30-gcc -c -mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -ID:\PROGRA~1\MATLAB\R2009b/simulink/include -ID:\PROGRA~1\MATLAB\R2009b/extern/include -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/ert -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src/ext_mode/common -ID:\DOCUME~1\ELMAY\Bureau\DRAFT\MPH_dspic\sources -ID:\DOCUME~1\ELMAY\Bureau\DRAFT -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include MPH.c
''pic30-gcc -mcpu=30f4013 MPH_data.o MPH_main.o MPH.o D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f4013-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a -o ..\../MPH.cof -Xlinker --script=D:\PROGRA~1\MICROC~1\mplabc30\v3.25\support\dsPIC30F\gld\p30f4013.gld -Xlinker -t -Xlinker --report-mem -Xlinker -Map=../untitled.map -Xlinker --heap=0 -Xlinker -cref
d:\program files\microchip\mplabc30\v3.25\bin\bin\..\bin/pic30-coff-ld.exe: mode pic30_coff
MPH_data.o
MPH_main.o
MPH.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a)crt0_standard.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a)data_init_standard.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f4013-coff.a)ConfigIntTimer1.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)floatsisf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)addsf3.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)mulsf3.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)sinf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)cosf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fgtge.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fpack.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)funpack2.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)futil.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)sincosf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fcompare.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)funpack.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)errno.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)feqltle.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fmodf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fixsfsi.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fmodrem.o
Program Memory [Origin = 0x100, Length = 0x7f00]
section address length (PC units) length (bytes) (dec)
.text 0x100 0x4d6 0x741 (1857)
.text 0x5d6 0x31e 0x4ad (1197)
.dinit 0x8f4 0x68 0x9c (156)
.text 0x95c 0x14 0x1e (30)
.isr 0x970 0x2 0x3 (3)
Total program memory used (bytes): 0xcab (3243) 6%
Data Memory [Origin = 0x800, Length = 0x800]
section address alignment gaps total length (dec)
.ndata 0x800 0 0x70 (112)
.nbss 0x870 0 0x18 (24)
.ndata 0x888 0 0x2 (2)
.nbss 0x88a 0 0x2 (2)
Total data memory used (bytes): 0x8c (140) 6%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x88c 0x774 (1908)
Maximum dynamic memory (bytes): 0x774 (1908)
"*** Embedded Target for dsPIC by Lubin KERHUEL - http://www.kerhuel.eu"
" | Licence Accorded to Demonstration Version |"
" | [adresse e-mail retirée] |"
" | Companie : Author : Lubin KERHUEL |"
" | WEBSITE : http://www.kerhuel.eu/wiki |"
" | SIRENE : 503 920 456 |"
" | SIRET : 503 920 456 00012 |"
" | Financial Service : Demo |"
" | Contact Demo |"
" | Lubin KERHUEL |"
" | 1, rue Alfred Fredet |"
" | 38100 Grenoble |"
" | FRANCE |"
" | Version 3.4b 14-Jan-2011 |"
" | For Matlab 7.9 R2009b |"
"*** Created "executable": ..\../MPH.cof"
''pic30-bin2hex ..\../MPH.cof
"*** Created "executable": ..\../MPH.hex"
"***Ready to be downloaded into 30f4013. (with MPLAB: file -> import, choose MPH.hex)"
"***alternative: load the project and re-compile it in MPLAB IDE"
### Successful completion of Real-Time Workshop build procedure for model: MPH
BUILD EXECUTION COMMAND COMPLETED
Load Main Project (or) Set Main Project as Active Project
Re: MPLAB Compilation
First, please download the latest blockset version available on the wiki.
Then, do not use the MPLAB Matlab menu.
Just open your model within matlab, compile it.
If you want to open the generated C code within MPLAB, just open the mplab project file that is generated within Matlab. (instruction are givens at end of compilation process with the latest blockset version !)
That's it !
Please let me know if you make it !
That's it !
