PSV model for interrupts not explicitly declared
With version 3.0 of the C30 compiler a PSV model is necessary for interrupts. If one isn't specified you get warnings like the following:
Any way this could be fixed? Looks like just setting it to auto_psv would work and then I won't get warnings for every IC channel I'm using.
dsPIC_InputCapture_Interrupt.c: In function '_IC8Interrupt':
dsPIC_InputCapture_Interrupt.c:80: warning: PSV model not specified for '_IC8Interrupt';
assuming 'auto_psv' this may affect latency
Re: PSV model for interrupts not explicitly declared
Oh, it also looks like this affects the UART2 interrupts, but I would imagine this affects all interrupts generated by the blockset.
Hi Bryan,
I corrected the problem by addiin the PSV model option within the interrupt. (I used the auto_psv option).
Will be realease with the next version.
Anyway, the generated code is Ok despite of this warning.
Thanks for the suggestion.
