SLUGS - an open source autopilot
Forum : Version compatibility issues
25 message(s) · archive en lecture seule
The open source SLUG UAV autopilot is being developed at the Autonomous Systems Lab at the University of California Santa Cruz. More information can be found at http://slugsuav.soe.ucsc.edu/
The autopilot can be compiled using the blockset (with a demo version allowing only 8 I/O, 2 I/O should be removed first for testing the compilation process)
I get into a mail exchange with Mariano and another team. I rewrite here few tricks to compile successfully the SLUG autopilot with the most recent compiler and blockset version.
SLUG :
Sources downloaded from git at https://github.com/malife/slugs
Revert the git repository to a former stable and working version (From mariano, : git checkout 13d8c62a7d2)
(Problem with missing navlink.h with head SLUG version (November 2010) )
I tested with the following configuration :
MATLAB 2010a (0x64)
dsPIC blockset V3.3a
dsPIC30, Microchip v3_25
I get a error as shown in the compilation report:
Problem encounter while linking; Compiler suggest large-data model.
The project can be opened within MPLAB (the blockset creates an MPLAB project file from version 3.3). Right click on the mcp file within the MATLAB file browser, and select open outside MATLAB ==> it will open MPLAB.
MPLAB will allow changing graphically the compilation options and to play with...
Thus, in the compilation options of MPLAB C30 choose large data model and re-compile the project (within MPLAB).
It works successfully.
Let’s integrate the new compilation options.
The problem could directly be solved within matlab:
In the opened model, choose
Simulation ==> Configuration Parameters ==>
In the tab Real-Time Workshop ==> DsPIC options, add -mlarge-data to the optimisation parameter (OPTIM_GCC). The line should now be : -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data
(Mariano provided the same trick by mail)
Generating C and compiling the model within Simulink is now Ok.
The finale report becomes:
SLUG :
MATLAB 2010a (0x64)
PPNumber of I/O PINs used : 8
TPTPTTPNumber of I/O PINs used : 8
TTTWarning: Could not find an exact (case-sensitive) match for 'dsPIC_PWM_Motor_callback_InitMask'.
C:\Mes_doccuments_Maison\prog\Matlab2\RTWdsPIC\blocks\dsPIC_PWM_motor_callback_InitMask.m is a case-insensitive
match and will be used instead.
You can improve the performance of your code by using exact
name matches and we therefore recommend that you update your
usage accordingly. Alternatively, you can disable this warning using
warning('off','MATLAB:dispatcher:InexactCaseMatch').
This warning will become an error in future releases.
PTPTPTTPNumber of I/O PINs used : 8
TPTWarning: Input port 1 of 'controlMCUSlugsMKII/Trim Vals/Log Trims Using PWM High [groundStationDriver.c]/Report
Airspeed' is not connected.
Warning: Output port 1 of 'controlMCUSlugsMKII/Update PWM Commands and Send Telemetry/[dR dE dA dT]2' is not
connected.
Warning: Output port 1 of 'controlMCUSlugsMKII/Update PWM Commands and Send Telemetry/[dR dE dA dT]3' is not
connected.
Warning: Parameter precision loss occurred for 'Threshold'. The parameter's value cannot be represented exactly
using the run-time data type. A small quantization error has occurred. You can control this diagnostic on the
Diagnostics pane of the Configuration Parameters dialog. This originated from 'controlMCUSlugsMKII/Inner Loop//
Navigation/Compute psi_dot_m/Protect NaNs/Switch3'.
Warning: Parameter precision loss occurred for 'Gain'. The parameter's value cannot be represented exactly using the
run-time data type. A small quantization error has occurred. You can control this diagnostic on the Diagnostics pane
of the Configuration Parameters dialog. This originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/L1 Output
Feedback Controller With Projection Operator/Control Law/Compute Coef/-T'.
Navigation/L1 Output Feedback Controller With Projection Operator/Protect NaNs/Switch3'.
Navigation/L1 Output Feedback Controller With Projection Operator/Protect NaNs2/Switch3'.
Feedback Controller With Projection Operator/State Predictor/Compute Coef/-T'.
Warning: Parameter precision loss occurred for 'Value'. The parameter's value cannot be represented exactly using
the run-time data type. A small quantization error has occurred. You can control this diagnostic on the Diagnostics
pane of the Configuration Parameters dialog. This originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/L1
Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Constant'.
Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Constant1'.
Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Constant2'.
Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Constant3'.
Navigation/L1 Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Protect NaNs/Switch3'.
Navigation/L1 Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Protect NaNs1/Switch3'.
Navigation/L1 Output Feedback Controller With Projection Operator/Trapezoidal Integrator/Switch1'.
Navigation/Lateral Channel/Angle Conversion/Unit Conversion'.
Navigation/Lateral Channel/Angle Conversion2/Unit Conversion'.
Navigation/Lateral Channel/Bank to Psi Dot/Constant1'.
Navigation/Lateral Channel/Bank to Psi Dot/Protect NaNs/Switch3'.
Navigation/Lateral Channel/Bank to Psi Dot/Protect NaNs1/Switch3'.
Navigation/Lateral Channel/High Pass (Washout) Filter/Constant1'.
Navigation/Lateral Channel/High Pass (Washout) Filter/Constant2'.
Navigation/Lateral Channel/High Pass (Washout) Filter/Constant3'.
Navigation/Lateral Channel/Protect NaNs/Switch3'.
Navigation/Lateral Channel/Protect NaNs1/Switch3'.
Navigation/Lateral Channel/Protect NaNs2/Switch3'.
Navigation/Lateral Channel/Protect NaNs3/Switch3'.
Navigation/Lateral Channel/Roll Control [PID]/Gain'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Constant'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Constant1'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Constant2'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Constant3'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Protect NaNs /Switch3'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Protect NaNs1/Switch3'.
Navigation/Lateral Channel/Roll Control [PID]/Trapezoidal Integrator/Switch1'.
Navigation/Lateral Channel/Roll Control [PID]/delayTime'.
Navigation/Lateral Channel/Sideslip Compensation/Bank to Psi Dot/Constant1'.
Navigation/Lateral Channel/Sideslip Compensation/Constant'.
Navigation/Lateral Channel/Sideslip Compensation/Low Pass/Compute Coef/-T'.
Navigation/Lateral Channel/Sideslip Compensation/Protect NaNs2/Switch3'.
Navigation/Lateral Channel/Sideslip Compensation/psi_dot to Bank/Constant1'.
Navigation/Lateral Channel/Switch'.
Navigation/Lateral Channel/Switch1'.
Navigation/Lateral Channel/Switch2'.
Navigation/Lateral Channel/Switch3'.
Navigation/Lateral Channel/Yaw Damper [PID]/Gain'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant1'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant2'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant3'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Protect NaNs /Switch3'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Protect NaNs1/Switch3'.
Navigation/Lateral Channel/Yaw Damper [PID]/Trapezoidal Integrator/Switch1'.
Navigation/Lateral Channel/Yaw Damper [PID]/delayTime'.
Navigation/Lateral Channel/psi_dot to Bank/Constant1'.
Navigation/Longitudinal Channel/Air Density from Height/Constant 2 from Model'.
Navigation/Longitudinal Channel/Air Density from Height/Length Conversion/Unit Conversion'.
Navigation/Longitudinal Channel/Air Density from Height/Rho_0 (Kg//m^3)'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Gain'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Constant'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Constant1'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Constant2'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Constant3'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Protect NaNs /Switch3'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Protect NaNs1/Switch3'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/Trapezoidal Integrator/Switch1'.
Navigation/Longitudinal Channel/Airspeed Hold [PID]/delayTime'.
Warning: Parameter precision loss occurred for 'LowerLimit'. The parameter's value cannot be represented exactly
Navigation/Longitudinal Channel/Compute Airspeed/[ 0.01 50000]'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Gain'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Constant'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Constant1'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Constant2'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Constant3'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Protect NaNs/Switch3'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Protect NaNs /Switch3'.
Navigation/Longitudinal Channel/Height Error to Pitch Command [PI]/Trapezoidal Integrator/Switch1'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Gain'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Constant'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Constant1'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Constant2'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Constant3'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Protect NaNs /Switch3'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Protect NaNs1/Switch3'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/Trapezoidal Integrator/Switch1'.
Navigation/Longitudinal Channel/Pitch To Elevator [PID]/delayTime'.
Navigation/Longitudinal Channel/Protect NaNs/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs1/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs2/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs3/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs4/Switch3'.
Navigation/Longitudinal Channel/Schedule LPF'.
Navigation/Longitudinal Channel/Switch'.
Navigation/Navigation/Compute Lateral Error/Subsystem3/Protect NaNs/Switch3'.
Navigation/Navigation/Compute WP Index/Compute P/Compute T in Frenet/Normalize Vector/Zero Bound'.
Navigation/Navigation/Compute WP Index/Compute P/Geod2LTP1/ECEF2LTP (UEN)/Deg2R'.
Navigation/Navigation/Compute WP Index/Compute P/Geod2LTP1/Geod2ECEF1/Deg2R'.
Navigation/Navigation/Compute WP Index/Compute P/Geod2LTP1/Geod2ECEF1/Deg2R1'.
Navigation/Navigation/Compute WP Index/Compute P/Geod2LTP1/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Compute WP Index/Compute P/Get Circles/Compute delta Left Turn/Constant5'.
Navigation/Navigation/Compute WP Index/Compute P/Get Circles/Constant5'.
Navigation/Navigation/Compute WP Index/Compute P/Get Circles/compute delta Right Turn/Constant5'.
Navigation/Navigation/Compute WP Index/Grab IC/Compute GS Location/Geod2ECEF1/Deg2R'.
Navigation/Navigation/Compute WP Index/Grab IC/Compute GS Location/Geod2ECEF1/Deg2R1'.
Navigation/Navigation/Compute WP Index/Grab IC/Compute GS Location/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Compute WP Index/Protect NaNs/Switch3'.
Navigation/Navigation/Compute WP Index/Switch when in Line Segment/1st WP'.
Navigation/Navigation/Compute WP Index/Switch when in Line Segment/Compute Projection/Protect NaNs/Switch3'.
Navigation/Navigation/Compute WP Index/Switch when in Line Segment/Compute Total Run/Protect NaNs/Switch3'.
Navigation/Navigation/Get Wps Compute Frenet/Compute Frenet/Normalize Vector/Zero Bound'.
Navigation/Navigation/Get Wps Compute Frenet/Compute Frenet/Normalize Vector /Zero Bound'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP1/ECEF2LTP (UEN)/Deg2R'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP1/Geod2ECEF1/Deg2R'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP1/Geod2ECEF1/Deg2R1'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP1/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP2/ECEF2LTP (UEN)/Deg2R'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP2/Geod2ECEF1/Deg2R'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP2/Geod2ECEF1/Deg2R1'.
Navigation/Navigation/Get Wps Compute Frenet/Geod2LTP2/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Get Wps Compute Frenet/Switch'.
Navigation/Navigation/Gravity'.
Navigation/Navigation/Park, Deyst & How Lat Accel Cmd/Compute Eta/Subsystem6/Protect NaNs/Switch3'.
Warning: Parameter precision loss occurred for 'UpperLimit'. The parameter's value cannot be represented exactly
Navigation/Navigation/Park, Deyst & How Lat Accel Cmd/Compute Eta/Subsystem6/[-1,1]'.
Navigation/Navigation/Park, Deyst & How Lat Accel Cmd/GainSchedule L2 and Get Groundspeed/Protect NaNs/Switch3'.
Navigation/Navigation/Park, Deyst & How Lat Accel Cmd/Park's Lateral Accel Command/Protect NaNs/Switch3'.
Navigation/Navigation/as_c to phi_c/Protect NaNs/Switch3'.
Navigation/Protect NaNs/Switch3'.
Diagnostics pane of the Configuration Parameters dialog. This originated from 'controlMCUSlugsMKII/Trim
Vals/Gain1'.
Vals/Gain2'.
Vals/Gain3'.
Diagnostics pane of the Configuration Parameters dialog. This originated from 'controlMCUSlugsMKII/Update PWM
Commands and Send Telemetry/Generate PWM Signals Based on the Control Type/If Control Type Is Selective
Passthrough/Switch'.
Passthrough/Switch1'.
Passthrough/Switch2'.
Passthrough/Switch3'.
Diagnostics pane of the Configuration Parameters dialog. This originated from 'controlMCUSlugsMKII/get Nav
Vars/Angle Conversion/Unit Conversion'.
Vars/Direction Cosine Matrix to Euler Angles/Subsystem3/[-1,1]'.
### Invoking Target Language Compiler on controlMCUSlugsMKII.rtw
### Using System Target File: C:\Mes_doccuments_Maison\prog\Matlab2\RTWdsPIC\dspic\dspic.tlc
### Writing source file controlMCUSlugsMKII.c
### Writing header file controlMCUSlugsMKII_private.h
### Writing header file controlMCUSlugsMKII.h
### Writing header file controlMCUSlugsMKII_types.h
### Writing header file rtwtypes.h
### Writing header file rt_MAXf_snf.h
### Writing header file rt_zcfcn.h
### Writing source file rt_zcfcn.c
### Writing header file rt_nonfinite.h
### Writing source file rt_nonfinite.c
### Writing header file rt_SATURATE.h
### Writing header file rt_SIGNf_snf.h
### Writing header file rtGetInf.h
### Writing source file rtGetInf.c
### Writing header file rtGetNaN.h
### Writing source file rtGetNaN.c
### Writing source file controlMCUSlugsMKII_data.c
### Writing source file controlMCUSlugsMKII_main.c
### Creating HTML report file controlMCUSlugsMKII_codegen_rpt.html
.### Creating project marker file: rtw_proj.tmw
Embedded Coder for dsPIC V&&Version&&(&& Date &&) for Matlab && Release &&.
Licence Accorded to && Licence Name &&
&& Mailcontact &&
&& Companie &&
&& CompanieAddress1 &&
&& CompanieAddress2 &&
&& CompanieAddress3 &&
&& CompanieAddress4 &&
Facturation to : && BuyerName &&
&& MailBuyer &&
&& BuyerAddress1 &&
&& BuyerAddress2 &&
&& BuyerAddress3 &&
&& BuyerAddress4 &&
Check updates and new informations at : www.kerhuel.eu
### Processing Template Makefile: C:\Mes_doccuments_Maison\prog\Matlab2\RTWdsPIC\dspic\dspic_pic30_gcc.tmf
### Creating controlMCUSlugsMKII.mk from C:\Mes_doccuments_Maison\prog\Matlab2\RTWdsPIC\dspic\dspic_pic30_gcc.tmf
### Building controlMCUSlugsMKII: "C:\PROGRA~1\MATLAB\R2010a\bin\win64\gmake" -f controlMCUSlugsMKII.mk GENERATE_REPORT=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDS=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/DEE.c
''pic30-gcc -c C:\Users\Lubin\Desktop\SLUGS\clib/DEES.s -Wa,-p=33fJ256MC710,-g
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/apUtils.c
C:\Users\Lubin\Desktop\SLUGS\clib/apUtils.c:852:7: warning: no newline at end of file
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/circBuffer.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include controlMCUSlugsMKII_data.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include controlMCUSlugsMKII_main.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include dsPIC_InputCapture_Interrupt.c
dsPIC_InputCapture_Interrupt.c: In function '_IC2Interrupt':
dsPIC_InputCapture_Interrupt.c:11: warning: PSV model not specified for '_IC2Interrupt';
assuming 'auto_psv' this may affect latency
dsPIC_InputCapture_Interrupt.c: In function '_IC3Interrupt':
dsPIC_InputCapture_Interrupt.c:32: warning: PSV model not specified for '_IC3Interrupt';
dsPIC_InputCapture_Interrupt.c: In function '_IC4Interrupt':
dsPIC_InputCapture_Interrupt.c:53: warning: PSV model not specified for '_IC4Interrupt';
dsPIC_InputCapture_Interrupt.c: In function '_IC5Interrupt':
dsPIC_InputCapture_Interrupt.c:74: warning: PSV model not specified for '_IC5Interrupt';
dsPIC_InputCapture_Interrupt.c: In function '_IC8Interrupt':
dsPIC_InputCapture_Interrupt.c:95: warning: PSV model not specified for '_IC8Interrupt';
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/groundStationDriver.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/interProcCommSlave.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/navSupport.c
C:\Users\Lubin\Desktop\SLUGS\clib/navSupport.c:211:2: warning: no newline at end of file
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/protDecoder.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rtGetInf.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rtGetNaN.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rt_nonfinite.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rt_zcfcn.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/sbrk.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include controlMCUSlugsMKII.c
''pic30-ld -t --report-mem -Map ../untitled.map --heap 0 -cref -T C:\PROGRA~2\MICROC~1\MPLABC~2\support\dsPIC33F\gld\p33fJ256MC710.gld -o ..\../controlMCUSlugsMKII.cof DEE.o DEES.o apUtils.o circBuffer.o controlMCUSlugsMKII_data.o controlMCUSlugsMKII_main.o dsPIC_InputCapture_Interrupt.o groundStationDriver.o interProcCommSlave.o navSupport.o protDecoder.o rtGetInf.o rtGetNaN.o rt_nonfinite.o rt_zcfcn.o sbrk.o controlMCUSlugsMKII.o C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a
C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\bin/pic30-coff-ld.exe: mode pic30_coff
DEE.o
DEES.o
apUtils.o
circBuffer.o
navSupport.o
protDecoder.o
rtGetInf.o
rtGetNaN.o
rt_nonfinite.o
rt_zcfcn.o
sbrk.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpic30-coff.a)crt0_standard.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpic30-coff.a)brk.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libpic30-coff.a)data_init_standard.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)putsUART2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntTimer1.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntTimer2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenTimer2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture4.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture4.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture5.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture5.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture8.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture8.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)SetDCMCPWM.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntMCPWM.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenMCPWM.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)memcpy.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)vsprintf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)memset.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xprintf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xvacopy.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)strchr.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xputfld.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xputtxt.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xldtob.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xlitob.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)strlen.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)memchr.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xldunsca.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xldscale.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)ldiv.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xgenld.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)xdnorm.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libc-coff.a)div.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fixsfsi.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)atan2f.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)powf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)sqrtf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)atanf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)asinf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)sinf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)cosf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)tanf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)acosf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)expf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fixunssfsi.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)feqltle.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fne.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fgtge.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)mulsf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)addsf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)divsf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)floatsisf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)floorf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fmodf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)extendsfdf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)deqltle.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fixdfsi.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)floatsidf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)subdf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dgtge.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)divsi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)muldf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)divdf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)umodsi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)udivsi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)mulsi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)divmoddi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)muldi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)funpack.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)funpack2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)errno.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)futil.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fchop.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)_frexpf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)ldexpf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)logf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fpack.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)asinacosf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)sincosf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fcompare.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)fmodrem.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dcompare.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dunpack.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dunpack2.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)floatdidf.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)adddf3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dpack.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)umuldi3.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dtype.o
(C:\PROGRA~2\MICROC~1\MPLABC~2\lib\libm-coff.a)dpropagateNaN.o
Program Memory [Origin = 0x200, Length = 0x2aa00]
section address length (PC units) length (bytes) (dec)
.text 0x200 0x296e 0x3e25 (15909)
.text 0x2b6e 0x8c 0xd2 (210)
.isr 0x2bfa 0x2 0x3 (3)
_036e5a804ce95ae1 0x2c00 0x1000 0x1800 (6144)
.const 0x3c00 0x94 0xde (222)
.text 0x3c94 0x6012 0x901b (36891)
.dinit 0x9ca6 0x1da 0x2c7 (711)
.text 0x9e80 0x3be 0x59d (1437)
.text 0xa23e 0x8e 0xd5 (213)
Total program memory used (bytes): 0xf12c (61740) 23%
Data Memory [Origin = 0x800, Length = 0x7800]
section address alignment gaps total length (dec)
.nbss 0x800 0 0x174e (5966)
.ndata 0x1f4e 0 0x56 (86)
.nbss 0x1fa4 0 0x2c (44)
.ndata 0x1fd0 0 0x4 (4)
.nbss 0x1fd4 0 0x4 (4)
.ndata 0x1fd8 0 0x4 (4)
.nbss 0x1fdc 0 0x2 (2)
.data 0x1fde 0 0x48 (72)
.dconst 0x2026 0 0x32 (50)
.data 0x2058 0 0x34 (52)
.dconst 0x208c 0 0x8 (8)
.bss 0x2094 0 0x2 (2)
.data 0x2096 0 0x2 (2)
.dconst 0x2098 0 0x2 (2)
.data 0x209a 0 0x2 (2)
_0299ea804ce95aea 0x7f32 0 0xce (206)
Total data memory used (bytes): 0x196a (6506) 21%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x209c 0x5e96 (24214)
Maximum dynamic memory (bytes): 0x5e96 (24214)
sbrk.o(.libc+0x4):C:\Users\Lubin\Desktop\SLUGS\clib\sbrk.c: Link Error: Cannot access symbol (___curbrk) with file register addressing. Value must be less than 8192. Suggest large-data model.
C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\bin/pic30-coff-ld.exe: link errors found, deleting executable `..\../controlMCUSlugsMKII.cof'
gmake: *** [..\../controlMCUSlugsMKII.cof] Error 255
### Real-Time Workshop build procedure for model: 'controlMCUSlugsMKII' aborted due to an error.
PTTPTPTPNumber of I/O PINs used : 8
TTPTPTWarning: Input port 1 of 'controlMCUSlugsMKII/Trim Vals/Log Trims Using PWM High
[groundStationDriver.c]/Report Airspeed' is not connected.
dT]2' is not connected.
dT]3' is not connected.
represented exactly using the run-time data type. A small quantization error has occurred. You can
control this diagnostic on the Diagnostics pane of the Configuration Parameters dialog. This
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Compute psi_dot_m/Protect
NaNs/Switch3'.
exactly using the run-time data type. A small quantization error has occurred. You can control
this diagnostic on the Diagnostics pane of the Configuration Parameters dialog. This originated
from 'controlMCUSlugsMKII/Inner Loop// Navigation/L1 Output Feedback Controller With Projection
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/L1 Output Feedback Controller With
can control this diagnostic on the Diagnostics pane of the Configuration Parameters dialog. This
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Angle
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Bank to Psi
Dot/Constant1'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/High Pass (Washout)
Filter/Constant1'.
Filter/Constant2'.
Filter/Constant3'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Protect
NaNs/Switch3'.
NaNs1/Switch3'.
NaNs2/Switch3'.
NaNs3/Switch3'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Roll Control
[PID]/Gain'.
[PID]/delayTime'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Sideslip
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Switch'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Switch1'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Switch2'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Switch3'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/Yaw Damper
[PID]/Gain'.
[PID]/delayTime'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral Channel/psi_dot to
Bank/Constant1'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Air Density
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Airspeed Hold
[PID]/Gain'.
[PID]/delayTime'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Compute
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Height Error
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Pitch To
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Protect
NaNs/Switch3'.
NaNs1/Switch3'.
NaNs2/Switch3'.
NaNs3/Switch3'.
NaNs4/Switch3'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Schedule LPF'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal Channel/Switch'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Compute Lateral
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Compute WP Index/Compute
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Compute WP Index/Grab
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Compute WP Index/Protect
NaNs/Switch3'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Compute WP Index/Switch
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Get Wps Compute
Frenet/Switch'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Gravity'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Park, Deyst & How Lat
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/as_c to phi_c/Protect
NaNs/Switch3'.
originated from 'controlMCUSlugsMKII/Inner Loop// Navigation/Protect NaNs/Switch3'.
originated from 'controlMCUSlugsMKII/Trim Vals/Gain1'.
originated from 'controlMCUSlugsMKII/Trim Vals/Gain2'.
originated from 'controlMCUSlugsMKII/Trim Vals/Gain3'.
originated from 'controlMCUSlugsMKII/Update PWM Commands and Send Telemetry/Generate PWM Signals
Based on the Control Type/If Control Type Is Selective Passthrough/Switch'.
Based on the Control Type/If Control Type Is Selective Passthrough/Switch1'.
Based on the Control Type/If Control Type Is Selective Passthrough/Switch2'.
Based on the Control Type/If Control Type Is Selective Passthrough/Switch3'.
originated from 'controlMCUSlugsMKII/get Nav Vars/Angle Conversion/Unit Conversion'.
originated from 'controlMCUSlugsMKII/get Nav Vars/Direction Cosine Matrix to Euler
.### Evaluating PostCodeGenCommand specified in the model
&& Mailcontact &&
&& Companie &&
&& MailBuyer &&
&& BuyerAddress1 &&
&& BuyerAddress2 &&
&& BuyerAddress3 &&
&& BuyerAddress4 &&
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/DEE.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/apUtils.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/circBuffer.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include controlMCUSlugsMKII_data.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include controlMCUSlugsMKII_main.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include dsPIC_InputCapture_Interrupt.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/groundStationDriver.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/interProcCommSlave.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/navSupport.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/protDecoder.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rtGetInf.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rtGetNaN.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rt_nonfinite.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include rt_zcfcn.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include C:\Users\Lubin\Desktop\SLUGS\clib/sbrk.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Lubin\Desktop\SLUGS\controlMCUSlugsMKII_dspic\sources -IC:\Users\Lubin\Desktop\SLUGS -IC:\Users\Lubin\Desktop\SLUGS\clib -I C:\PROGRA~2\MICROC~1\MPLABC~2\include controlMCUSlugsMKII.c
DEE.o
DEES.o
apUtils.o
circBuffer.o
navSupport.o
protDecoder.o
rtGetInf.o
rtGetNaN.o
rt_nonfinite.o
rt_zcfcn.o
sbrk.o
_03597a804ce99355 0x2c00 0x1000 0x1800 (6144)
.text 0x3c94 0x646a 0x969f (38559)
.dinit 0xa0fe 0x1da 0x2c7 (711)
.text 0xa2d8 0x3be 0x59d (1437)
.text 0xa696 0x8e 0xd5 (213)
Total program memory used (bytes): 0xf7b0 (63408) 24%
.nbss 0x800 0 0x2 (2)
.bss 0x802 0 0x174e (5966)
.data 0x1f50 0 0x9e (158)
.dconst 0x1fee 0 0x32 (50)
.data 0x2020 0 0x22 (34)
.bss 0x2042 0 0x2c (44)
.data 0x206e 0 0x12 (18)
.dconst 0x2080 0 0x8 (8)
.data 0x2088 0 0x4 (4)
.bss 0x208c 0 0x4 (4)
.data 0x2090 0 0x4 (4)
_0291ea804ce9935e 0x7f32 0 0xce (206)
heap 0 0 (0)
*** Embedded Target for dsPIC by Lubin KERHUEL - http://www.kerhuel.eu
| Licence Accorded to && Licence Name &&|
| && Mailcontact &&|
| Companie : && Companie &&|
| && CompanieAddress1 &&|
| && CompanieAddress2 &&|
| && CompanieAddress3 &&|
| && CompanieAddress4 &&|
| Financial Service : && BuyerName &&|
| Contact && MailBuyer &&|
| && BuyerAddress1 &&|
| && BuyerAddress2 &&|
| && BuyerAddress3 &&|
| && BuyerAddress4 &&|
| Version &&Version&& && Date && |
| For Matlab && VerMatlab && && Release && |
*** Created executable: ..\../controlMCUSlugsMKII.cof
''pic30-bin2hex ..\../controlMCUSlugsMKII.cof
*** Created executable: ..\../controlMCUSlugsMKII.hex
***Ready to be downloaded into 33fJ256MC710. (with MPLAB: file -> import, choose controlMCUSlugsMKII.hex)
***alternative (experimental): load the project and re-compile it in MPLAB IDE
### Successful completion of Real-Time Workshop build procedure for model: controlMCUSlugsMKII
>> Lubin
Re: SLUGS - an open source autopilot
Here is what has been going on when I try and compile the stable version (checkout: 13d8c62a7d2) of the SLUG software.
To make sure the latest blockset (V3.3a Matlab 20010a) was working I compiled the example mode files and it succeed with no errors.
I went ahead and tried to compile the controlMCUSlugsMKII.c file to created the necessary files and I got the following error. Below is a copy-paste of my command window.
I attached the error window also.
http://img713.imageshack.us/img713/9108/error1t.th.png
http://img99.imageshack.us/img99/443/error2m.th.png
Am I not initiating something? MATLAB isn't sucessfully compiling the model correctly so I can't try the -mlarge-data compile flag.
Do have an Idea of what I am doing wrong?
EDIT 11-22-10: Tried to compile the latest commit and got the same error. This has to be caused by MATLAB.
Here is my compiler info, etc.
OS: Windows 7 (32-bit)
MATLAB: Matlab 2010a (32-bit)
mex and mbuild compiler: Microsoft Visual C++ 2008 Express
dsPIC Blockset V3.3a
MPLAB C30 Compiler (MPLAB C Compiler for PIC24 MCUs and dsPICs v3.25 LITE Mode)
MPLAB C32 Compiler (MPLAB C Compiler for PIC32 v1.1B LITE Mode)
MPLAB IDE v8.60
Dan
Ok ==> Data_Login_Matlab.mdl
Ok ==> FlexBoard_Blinking_Led.mdl
Ok ==> Servo_ADC.mdl
Ok ==> Servo_Sinus.mdl
Ok ==> dsPIC_32MX460F512L_Explorer16_HyperSampling.mdl
Ok ==> dsPIC_33f_Explorer16.mdl
End of Compilation in Elapsed time is 114.912392 seconds.
Some models may not compile if the appropriate
dsPIC (24 30 33) or PIC32 Compiler is not installed
Using PWM High [groundStationDriver.c]/Report Airspeed' is not
connected.
and Send Telemetry/[dR dE dA dT]2' is not connected.
and Send Telemetry/[dR dE dA dT]3' is not connected.
failed assertion in .\cdr\cdr_api.cpp at line 3194:
!errorOccurred
Stack Trace:
[0] stateflow.dll:0x286b1e4a(0x28739f5c "!errorOccurred", 0x28739490 ".\cdr\cdr_api.cpp", 3194, 0)
[1] stateflow.dll:0x284bd540(0, 0x00c18664, 0, 0x00c186cc)
[2] stateflow.dll:0x284bdf0d(44, 0, 0x00c18664, 2)
[3] stateflow.dll:0x286b7e70(0, 0x00c18664, 3, 0x00c186c4)
[4] stateflow.dll:0x285ebd77(0, 0x00c18664, 0x00c186c4, 0x22242550)
[5] stateflow.dll:0x285ebdba(0, 0x00c18664, 3, 0x00c186c4)
[6] libmex.dll:_mexRunMexFile(0, 0x00c18664, 3, 0x00c186c4) + 132 bytes
[7] libmex.dll:private: void __thiscall Mfh_mex::runMexFileWithSignalProtection(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c18664, 3, 0x00c186c4) + 73 bytes
[8] libmex.dll:public: virtual void __thiscall Mfh_mex::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c18664, 3, 0x00c186c4) + 321 bytes
[9] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c18664, 3, 0x00c186c4) + 249 bytes
[10] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c18664, 3, 0x00c186c4) + 420 bytes
[11] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1282, 0x27c08eec "sf", 0, 3) + 626 bytes
[12] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 12106, 125, 0) + 1282 bytes
[13] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 12106, 10, 0) + 39 bytes
[14] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 12106, 10, 0) + 251 bytes
[15] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0, 0xffffffff, 0x260fe318, 1) + 876 bytes
[16] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c18eac, 5, 0x00c18f0c) + 466 bytes
[17] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c18eac, 5) + 23 bytes
[18] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c18eac, 5, 0x00c18f0c) + 25 bytes
[19] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c18eac, 5, 0x00c18f0c) + 249 bytes
[20] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c18eac, 5, 0x00c18f0c) + 420 bytes
[21] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(2689, 0x2a8b8eac "code_sfun_glue_code", 1, 5) + 626 bytes
[22] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 921, 55, 0) + 1282 bytes
[23] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 921, 13, 0) + 39 bytes
[24] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 921, 13, 0) + 251 bytes
[25] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x0fa45300, 0xffffffff, 0x26276090, 0) + 876 bytes
[26] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c196f4, 3, 0x00c19754) + 466 bytes
[27] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c196f4, 3) + 23 bytes
[28] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c196f4, 3, 0x00c19754) + 25 bytes
[29] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c196f4, 3, 0x00c19754) + 249 bytes
[30] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c196f4, 3, 0x00c19754) + 420 bytes
[31] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(2683, 0x2becf680 "code_chart_source_file_sfun", 0, 3) + 626 bytes
[32] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 210, 10, 0) + 1282 bytes
[33] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 210, 7, 0) + 39 bytes
[34] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 210, 7, 0) + 251 bytes
[35] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x722b4c00, 0xffffffff, 0x26276978, 0) + 876 bytes
[36] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c19f3c, 3, 0x00c19f9c) + 466 bytes
[37] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c19f3c, 3) + 23 bytes
[38] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c19f3c, 3, 0x00c19f9c) + 25 bytes
[39] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c19f3c, 3, 0x00c19f9c) + 249 bytes
[40] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c19f3c, 3, 0x00c19f9c) + 420 bytes
[41] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(2652, 0x2bbc8320 "code_chart_source_file", 0, 3) + 626 bytes
[42] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 1721, 70, 0) + 1282 bytes
[43] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1721, 5, 0) + 39 bytes
[44] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1721, 5, 0) + 251 bytes
[45] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x080d8800, 0xffffffff, 0x260fbbe8, 0) + 876 bytes
[46] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c1a784, 2, 0x00c1a7e4) + 466 bytes
[47] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c1a784, 2) + 23 bytes
[48] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c1a784, 2, 0x00c1a7e4) + 25 bytes
[49] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c1a784, 2, 0x00c1a7e4) + 249 bytes
[50] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c1a784, 2, 0x00c1a7e4) + 420 bytes
[51] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1703, 0x21d9ebdc "generate_code_for_charts_and_mac..", 0, 2) + 626 bytes
[52] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 2556, 163, 0) + 1282 bytes
[53] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 2556, 13, 0) + 39 bytes
[54] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 2556, 13, 0) + 251 bytes
[55] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x722b4c00, 0xffffffff, 0x260f8f60, 1) + 876 bytes
[56] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c1afcc, 5, 0x00c1b02c) + 466 bytes
[57] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c1afcc, 5) + 23 bytes
[58] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1afcc, 5, 0x00c1b02c) + 25 bytes
[59] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1afcc, 5, 0x00c1b02c) + 249 bytes
[60] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1afcc, 5, 0x00c1b02c) + 420 bytes
[61] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1697, 0x2b5bd4e0 "sfc", 1, 5) + 626 bytes
[62] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 388, 309, 0) + 1282 bytes
[63] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 388, 293, 0) + 39 bytes
[64] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 388, 293, 0) + 251 bytes
[65] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x01003800, 0xffffffff, 0x2af36300 "|1 zak", 2) + 876 bytes
[66] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(2, 0x00c1b934, 6, 0x00c1b998) + 466 bytes
[67] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 2, 0x00c1b934, 6) + 23 bytes
[68] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c1b934, 6, 0x00c1b998) + 25 bytes
[69] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c1b934, 6, 0x00c1b998) + 249 bytes
[70] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c1b934, 6, 0x00c1b998) + 420 bytes
[71] m_interpreter.dll:_inCallFcn(2, 0x00c1b934, 6, 0x00c1b998) + 84 bytes
[72] m_interpreter.dll:_inFullFevalFcn(2, 0x00c1b934, 7, 0x00c1b994) + 234 bytes
[73] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c1b934, 7, 0x00c1b994) + 92 bytes
[74] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c1b934, 7, 0x00c1b994) + 247 bytes
[75] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(311, 0x2b5bd14c "feval", 2, 7) + 626 bytes
[76] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 1133, 130, 0) + 1282 bytes
[77] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1133, 122, 0) + 39 bytes
[78] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1133, 122, 0) + 251 bytes
[79] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x080e1100, 0xffffffff, 0x2af36be8 "|1 zfk", 0) + 876 bytes
[80] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c1c238, 8, 0x00c1c1a8) + 466 bytes
[81] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c1c238, 8) + 23 bytes
[82] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c1c238, 8, 0x00c1c1a8) + 25 bytes
[83] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c1c238, 8, 0x00c1c1a8) + 249 bytes
[84] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c1c238, 8, 0x00c1c1a8) + 420 bytes
[85] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00c1c238, 8, 0x00c1ca00) + 81 bytes
[86] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0x00c1c4c8, 0, 1, 0x2b77af60) + 1209 bytes
[87] m_interpreter.dll:private: bool __thiscall accelImpl::MFunctionCall(struct _accelOp * *)(0x00c1ca14 "À[§+", 0xffffffff, 0x2b562d50, 0xffffffff) + 545 bytes
[88] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelImpl::Exec(void)(0x00c1ca00, 0xffffffff, 0x2ba32d80, 0xffffffff) + 170 bytes
[89] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelCode::Call(enum inMarshalType *,int *)const (0x00c1ccd8, 0xffffffff, 0, 0) + 133 bytes
[90] m_interpreter.dll:public: static bool __cdecl inJit::ExecuteHotSegment(struct _inJitAccelInfo *,enum opcodes *,int *,int *)(0x00c1cea0 "À\²!`ÏÁ", 0x00c1cff0, 0x00c1cf94, 0x00c1d170) + 2529 bytes
[91] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 1476, 62, 0) + 797 bytes
[92] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1476, 8, 0) + 39 bytes
[93] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1476, 8, 0) + 251 bytes
[94] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x0fa45300, 0xffffffff, 0x21b25cc0, 1) + 876 bytes
[95] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c1d580, 7, 0x00c1d4f0) + 466 bytes
[96] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c1d580, 7) + 23 bytes
[97] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1d580, 7, 0x00c1d4f0) + 25 bytes
[98] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1d580, 7, 0x00c1d4f0) + 249 bytes
[99] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1d580, 7, 0x00c1d4f0) + 420 bytes
[100] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(1, 0x00c1d580, 7, 0x00c1dd48 "\àÁ") + 81 bytes
[101] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0x00c1d810, 1, 1, 0x2bb76f30) + 1209 bytes
[102] m_interpreter.dll:private: bool __thiscall accelImpl::MFunctionCall(struct _accelOp * *)(0x00c1dd5c, 0xffffffff, 0x2abb7ed0, 0xffffffff) + 545 bytes
[103] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelImpl::Exec(void)(0x00c1dd48 "\àÁ", 0xffffffff, 0x2b9c0588, 0xffffffff) + 170 bytes
[104] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelCode::Call(enum inMarshalType *,int *)const (0x00c1e020, 0xffffffff, 0, 0) + 133 bytes
[105] m_interpreter.dll:public: static bool __cdecl inJit::ExecuteHotSegment(struct _inJitAccelInfo *,enum opcodes *,int *,int *)(0x00c1e1e8 "À7ò*¨âÁ", 0x00c1e338, 0x00c1e2dc, 0x00c1e4b8) + 2529 bytes
[106] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 1470, 191, 0) + 797 bytes
[107] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1470, 73, 0) + 39 bytes
[108] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1470, 73, 0) + 251 bytes
[109] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x0fa45300, 0xffffffff, 0x2af237c0 "|1 zËj", 1) + 876 bytes
[110] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c1e8c8, 5, 0x00c1e838) + 466 bytes
[111] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c1e8c8, 5) + 23 bytes
[112] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1e8c8, 5, 0x00c1e838) + 25 bytes
[113] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1e8c8, 5, 0x00c1e838) + 249 bytes
[114] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1e8c8, 5, 0x00c1e838) + 420 bytes
[115] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(1, 0x00c1e8c8, 5, 0x00c1f090 "¤óÁ") + 81 bytes
[116] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0x00c1eb58, 1, 1, 0x2b652878) + 1209 bytes
[117] m_interpreter.dll:private: bool __thiscall accelImpl::MFunctionCall(struct _accelOp * *)(0x00c1f0a4 "@t=+", 0xffffffff, 0x2abb9ec8, 0xffffffff) + 545 bytes
[118] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelImpl::Exec(void)(0x00c1f090 "¤óÁ", 0xffffffff, 0x2b287ff8, 0xffffffff) + 170 bytes
[119] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelCode::Call(enum inMarshalType *,int *)const (0x00c1f368, 0xffffffff, 0, 0) + 133 bytes
[120] m_interpreter.dll:public: static bool __cdecl inJit::ExecuteHotSegment(struct _inJitAccelInfo *,enum opcodes *,int *,int *)(0x00c1f530, 0x00c1f680, 0x00c1f624, 0x00c1f800) + 2529 bytes
[121] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 497, 53, 0) + 797 bytes
[122] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 497, 20, 0) + 39 bytes
[123] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 497, 20, 0) + 251 bytes
[124] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x0fa45300, 0xffffffff, 0x260f5498, 1) + 876 bytes
[125] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c1fc10, 5, 0x00c1fb80) + 466 bytes
[126] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c1fc10, 5) + 23 bytes
[127] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1fc10, 5, 0x00c1fb80) + 25 bytes
[128] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1fc10, 5, 0x00c1fb80) + 249 bytes
[129] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c1fc10, 5, 0x00c1fb80) + 420 bytes
[130] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(1, 0x00c1fc10, 5, 0x00c203d8) + 81 bytes
[131] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0x00c1fea0, 1, 1, 0x2aeaea28) + 1209 bytes
[132] m_interpreter.dll:private: bool __thiscall accelImpl::MFunctionCall(struct _accelOp * *)(0x00c203ec "ÈEË'", 0xffffffff, 0x2aa35c40, 0xffffffff) + 545 bytes
[133] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelImpl::Exec(void)(0x00c203d8, 0xffffffff, 0x2aa6e400, 0xffffffff) + 170 bytes
[134] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelCode::Call(enum inMarshalType *,int *)const (0x00c206b0, 0xffffffff, 0, 0) + 133 bytes
[135] m_interpreter.dll:public: static bool __cdecl inJit::ExecuteHotSegment(struct _inJitAccelInfo *,enum opcodes *,int *,int *)(0x00c20878, 0x00c209c8, 0x00c2096c, 0x00c20b48) + 2529 bytes
[136] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 2185, 96, 0) + 797 bytes
[137] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 2185, 8, 0) + 39 bytes
[138] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 2185, 8, 0) + 251 bytes
[139] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0, 0xffffffff, 0x260f5660, 0) + 876 bytes
[140] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c20f58, 3, 0x00c20ec8) + 466 bytes
[141] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c20f58, 3) + 23 bytes
[142] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c20f58, 3, 0x00c20ec8) + 25 bytes
[143] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c20f58, 3, 0x00c20ec8) + 249 bytes
[144] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c20f58, 3, 0x00c20ec8) + 420 bytes
[145] m_interpreter.dll:public: void __thiscall ResolverFunctionDesc::CallFunction(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00c20f58, 3, 0x00c21720) + 81 bytes
[146] m_interpreter.dll:public: bool __thiscall Resolver::CallMFunction(int,int,class _m_operand * const,union m_operand_storage *,int,class _m_operand * const,union m_operand_storage *,int *)(0x00c211e8, 0, 1, 0x2aead6c0) + 1209 bytes
[147] m_interpreter.dll:private: bool __thiscall accelImpl::MFunctionCall(struct _accelOp * *)(0x00c21734, 0xffffffff, 0x27553b68 " ³÷) ³÷)(³÷)à³÷)д÷)8¶÷)8¶÷)", 0xffffffff) + 545 bytes
[148] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelImpl::Exec(void)(0x00c21720, 0xffffffff, 0x274e2ec0, 0xffffffff) + 170 bytes
[149] m_interpreter.dll:public: enum jitReturnFlags __thiscall accelCode::Call(enum inMarshalType *,int *)const (0x00c219f8, 0xffffffff, 0, 0) + 133 bytes
[150] m_interpreter.dll:public: static bool __cdecl inJit::ExecuteHotSegment(struct _inJitAccelInfo *,enum opcodes *,int *,int *)(0x00c21bc0, 0x00c21d10, 0x00c21cb4, 0x00c21e90) + 2529 bytes
[151] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 1588, 122, 0) + 797 bytes
[152] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1588, 9, 0) + 39 bytes
[153] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1588, 9, 0) + 251 bytes
[154] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x00c22600, 0xffffffff, 0x21b295c0, 1) + 876 bytes
[155] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c235ec, 3, 0x00c22c14) + 466 bytes
[156] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c235ec, 3) + 23 bytes
[157] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 3, 0x00c22c14) + 25 bytes
[158] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 3, 0x00c22c14) + 249 bytes
[159] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 3, 0x00c22c14) + 420 bytes
[160] m_interpreter.dll:_inCallFcn(1, 0x00c235ec, 3, 0x00c22c14) + 84 bytes
[161] m_interpreter.dll:public: virtual int __thiscall InterpBridge::CallFcnWithTrap(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const,char const *,bool)(1, 0x00c235ec, 3, 0x00c22c14) + 104 bytes
[162] m_interpreter.dll:_inMexCallMATLAB(1, 0x00c23501 "5Â", 3, 0x00c22c14) + 136 bytes
[163] libmex.dll:_mexCallMATLAB(1, 0x00c235ec, 3, 0x00c22c14) + 41 bytes
[164] stateflow.dll:0x286b16d0(1, 0x00c235ec, 3, 0x00c22c14)
[165] stateflow.dll:0x285ed065(167, 1, 0x00c235ec, 4)
[166] stateflow.dll:0x286b7e70(1, 0x00c235ec, 5, 0x00c22c0c)
[167] stateflow.dll:0x285ebd77(1, 0x00c235ec, 0x00c22c0c, 0x22242550)
[168] stateflow.dll:0x285ebdba(1, 0x00c235ec, 5, 0x00c22c0c)
[169] libmex.dll:_mexRunMexFile(1, 0x00c235ec, 5, 0x00c22c0c) + 132 bytes
[170] libmex.dll:private: void __thiscall Mfh_mex::runMexFileWithSignalProtection(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 5, 0x00c22c0c) + 73 bytes
[171] libmex.dll:public: virtual void __thiscall Mfh_mex::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 5, 0x00c22c0c) + 321 bytes
[172] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 5, 0x00c22c0c) + 249 bytes
[173] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 5, 0x00c22c0c) + 420 bytes
[174] m_interpreter.dll:_inCallFcn(1, 0x00c235ec, 5, 0x00c22c0c) + 84 bytes
[175] m_interpreter.dll:public: virtual int __thiscall InterpBridge::CallFcnWithTrap(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const,char const *,bool)(1, 0x00c235ec, 5, 0x00c22c0c) + 104 bytes
[176] m_interpreter.dll:_inMexCallMATLAB(1, 0x00c23501 "5Â", 5, 0x00c22c0c) + 136 bytes
[177] libmex.dll:_mexCallMATLAB(1, 0x00c235ec, 5, 0x00c22c0c) + 41 bytes
[178] stateflow.dll:0x286b18c0(1, 0x00c235ec, 3, 0x00c235d8)
[179] stateflow.dll:0x285edb6c(120, 1, 0x00c235ec, 3)
[180] stateflow.dll:0x286b7e70(1, 0x00c235ec, 4, 0x00c235d4)
[181] stateflow.dll:0x285ebd77(1, 0x00c235ec, 0x00c235d4, 0x22242550)
[182] stateflow.dll:0x285ebdba(1, 0x00c235ec, 4, 0x00c235d4)
[183] libmex.dll:_mexRunMexFile(1, 0x00c235ec, 4, 0x00c235d4) + 132 bytes
[184] libmex.dll:private: void __thiscall Mfh_mex::runMexFileWithSignalProtection(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 4, 0x00c235d4) + 73 bytes
[185] libmex.dll:public: virtual void __thiscall Mfh_mex::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 4, 0x00c235d4) + 321 bytes
[186] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 4, 0x00c235d4) + 249 bytes
[187] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c235ec, 4, 0x00c235d4) + 420 bytes
[188] m_interpreter.dll:_inCallFcn(1, 0x00c235ec, 4, 0x00c235d4) + 84 bytes
[189] sl_services.dll:protected: virtual void __thiscall CallFcn_MLCommand::operator()(void)(1, 0x6ffd2bc4, 1, 0x00c235ec) + 26 bytes
[190] sl_services.dll:class slsvDiagnosticImpl * __cdecl slsvFEVAL_NoThrow(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const,char const *,bool)(1, 0x00c235ec, 4, 0x00c235d4) + 84 bytes
[191] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl callSlSfCommand(struct slBlockDiagram_tag *,double,char const *,void *)(0x27db9358, 0, 0x40310000, 0x6ecd9158 "compile_post_propagation") + 166 bytes
[192] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl slNotifyStateflowModel(struct slBlockDiagram_tag *,char const *)(0x27db9358, 0x6ecd9158 "compile_post_propagation", 0x2b36d800 "Ø6J/0ÔU/", 0x2e46c200 "ÜMÎn") + 140 bytes
[193] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl sleCompileBlockDiagram(struct slBlockDiagram_tag *,bool,bool,enum SimType,struct mxArray_tag *)(0x27db9358, 0, 0, 4) + 8988 bytes
[194] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl GetBlockDiagramModelType(class slModel *,struct sleInitModelContext *,bool,bool)(0x00c23818, 0, 0, 0x062342b8) + 2132 bytes
[195] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl sleInitModel(class slModel *,struct sleInitModelContext,bool,bool)(0x00c237b8, 4, 0xffffffff, 0) + 287 bytes
[196] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl DoRTWGen(struct RTWInfo *,struct mxArray_tag *,int,struct mxArray_tag * * const)(0x00c238f0, 0x080ea470, 3, 0x00c23bb4) + 685 bytes
[197] libmwsimulink.dll:void __cdecl sleRTWGen(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(3, 0x00c23bb4, 13, 0x00c23c14) + 189 bytes
[198] libmwsimulink.dll:void __cdecl slFullRTWGen(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(3, 0x00c23bb4, 13, 0x00c23c14) + 82 bytes
[199] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(3, 0x00c23bb4, 13, 0x00c23c14) + 92 bytes
[200] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(3, 0x00c23bb4, 13, 0x00c23c14) + 247 bytes
[201] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(629, 0x262240e8 "rtwgen", 3, 13) + 626 bytes
[202] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 4772, 160, 0) + 1282 bytes
[203] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 4772, 76, 0) + 39 bytes
[204] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 4772, 76, 0) + 251 bytes
[205] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x722b4c00, 0xffffffff, 0x216eb2c8, 1) + 876 bytes
[206] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c243fc, 10, 0x00c2445c) + 466 bytes
[207] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c243fc, 10) + 23 bytes
[208] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c243fc, 10, 0x00c2445c) + 25 bytes
[209] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c243fc, 10, 0x00c2445c) + 249 bytes
[210] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c243fc, 10, 0x00c2445c) + 420 bytes
[211] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1568, 0x22440154 "tlc_c", 1, 10) + 626 bytes
[212] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 3436, 227, 0) + 1282 bytes
[213] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 3436, 8, 0) + 39 bytes
[214] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 3436, 8, 0) + 251 bytes
[215] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x00c24b00, 0xffffffff, 0x216eaf38, 1) + 876 bytes
[216] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c24e18, 3, 0x2c253b18) + 466 bytes
[217] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c24e18, 3) + 23 bytes
[218] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c24e18, 3, 0x2c253b18) + 25 bytes
[219] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c24e18, 3, 0x2c253b18) + 249 bytes
[220] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c24e18, 3, 0x2c253b18) + 420 bytes
[221] udd_mi.dll:public: void __thiscall ExternalMethodInfo::invokeMethodDirect(bool,class UDMethodSignature *,int *,void * *,int,void * *,class UDErrorStatus *)(0, 0x219229d8, 0x00c24cf8, 0x00c24e18) + 463 bytes
[222] udd_mi.dll:bool __cdecl ouCallMethodWithErrorTrap(class UDMethodInfo *,struct mxArray_tag *,int,struct mxArray_tag * * const,int,struct mxArray_tag const * * const,class Exception * *)(0x21618378, 0x080fa700, 1, 0x00c24e18) + 480 bytes
[223] udd_mi.dll:bool __cdecl ouCallMethod(struct mxArray_tag *,struct mxArray_tag *,int,struct mxArray_tag * * const,int,struct mxArray_tag const * * const)(0, 0x080fa700, 1, 0x00c24e18) + 182 bytes
[224] mcos.dll:public: virtual void __thiscall Mfh_opaque_dynamic::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c24e18, 3, 0x2f4a3550) + 148 bytes
[225] m_dispatcher.dll:public: virtual void __thiscall Mfh_MATLAB_fn::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c24e18, 3, 0x2f4a3550) + 399 bytes
[226] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c24e18, 3, 0x2f4a3550) + 420 bytes
[227] m_interpreter.dll:_inOpaqueReferenceFcn(0x2f4a4af0 "make_rtw", 0x00fff9c0, 0x2f4a3b90, 1) + 276 bytes
[228] m_interpreter.dll:_inOpaqueStructureReferenceOrAssignment(0x080fa700, 0, 0x00c2556c, 0x00c25758) + 928 bytes
[229] m_interpreter.dll:_inStructureReference(0x080fa700, 1, 0x00c2556c, 0x00c2574c) + 139 bytes
[230] m_interpreter.dll:_inComplexReference(1, 0, 0x080fa700, 2) + 126 bytes
[231] m_interpreter.dll:_inMatRefDispatch(36, 0x73746e00, 1, 0) + 709 bytes
[232] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 58, 22, 0) + 1032 bytes
[233] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 58, 18, 0) + 39 bytes
[234] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 58, 18, 0) + 251 bytes
[235] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x722b4c00, 0xffffffff, 0x1f3590f0, 0) + 876 bytes
[236] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c25fa4, 2, 0x00c26004) + 466 bytes
[237] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c25fa4, 2) + 23 bytes
[238] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c25fa4, 2, 0x00c26004) + 25 bytes
[239] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c25fa4, 2, 0x00c26004) + 249 bytes
[240] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c25fa4, 2, 0x00c26004) + 420 bytes
[241] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1552, 0x2179eaac "make_rtw", 0, 2) + 626 bytes
[242] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 449, 5, 0) + 1282 bytes
[243] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 449, 4, 0) + 39 bytes
[244] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 449, 4, 0) + 251 bytes
[245] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0, 0xffffffff, 0x216ea488, 0) + 876 bytes
[246] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c2690c, 2, 0x00c26970) + 466 bytes
[247] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c2690c, 2) + 23 bytes
[248] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2690c, 2, 0x00c26970) + 25 bytes
[249] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2690c, 2, 0x00c26970) + 249 bytes
[250] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2690c, 2, 0x00c26970) + 420 bytes
[251] m_interpreter.dll:_inCallFcn(0, 0x00c2690c, 2, 0x00c26970) + 84 bytes
[252] m_interpreter.dll:_inFullFevalFcn(0, 0x00c2690c, 3, 0x00c2696c) + 234 bytes
[253] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2690c, 3, 0x00c2696c) + 92 bytes
[254] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2690c, 3, 0x00c2696c) + 247 bytes
[255] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(311, 0x2183d030 "feval", 0, 3) + 626 bytes
[256] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 495, 88, 0) + 1282 bytes
[257] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 495, 47, 0) + 39 bytes
[258] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 495, 47, 0) + 251 bytes
[259] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x011c0000 "¦h}Ì)9", 0xffffffff, 0x216e3618 "|1 z#f", 1) + 876 bytes
[260] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c27274, 2, 0x00c272d8) + 466 bytes
[261] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c27274, 2) + 23 bytes
[262] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27274, 2, 0x00c272d8) + 25 bytes
[263] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27274, 2, 0x00c272d8) + 249 bytes
[264] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27274, 2, 0x00c272d8) + 420 bytes
[265] m_interpreter.dll:_inCallFcn(1, 0x00c27274, 2, 0x00c272d8) + 84 bytes
[266] m_interpreter.dll:_inFullFevalFcn(1, 0x00c27274, 3, 0x00c272d4) + 234 bytes
[267] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27274, 3, 0x00c272d4) + 92 bytes
[268] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27274, 3, 0x00c272d4) + 247 bytes
[269] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(311, 0x2183d030 "feval", 1, 3) + 626 bytes
[270] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 101, 6, 0) + 1282 bytes
[271] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 101, 0, 0) + 39 bytes
[272] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 101, 0, 0) + 251 bytes
[273] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x080e3500, 0xffffffff, 0x1f783198, 1) + 876 bytes
[274] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c27abc, 3, 0x00c27b1c) + 466 bytes
[275] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c27abc, 3) + 23 bytes
[276] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27abc, 3, 0x00c27b1c) + 25 bytes
[277] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27abc, 3, 0x00c27b1c) + 249 bytes
[278] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c27abc, 3, 0x00c27b1c) + 420 bytes
[279] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1501, 0x21507c4c "build_target", 1, 3) + 626 bytes
[280] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 512, 51, 0) + 1282 bytes
[281] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 512, 11, 0) + 39 bytes
[282] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 512, 11, 0) + 251 bytes
[283] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0, 0xffffffff, 0x1f783360, 1) + 876 bytes
[284] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(1, 0x00c28304, 2, 0x00c28364) + 466 bytes
[285] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 1, 0x00c28304, 2) + 23 bytes
[286] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c28304, 2, 0x00c28364) + 25 bytes
[287] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c28304, 2, 0x00c28364) + 249 bytes
[288] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(1, 0x00c28304, 2, 0x00c28364) + 420 bytes
[289] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1419, 0x1ebc3da0 "build_standalone_rtw_target", 1, 2) + 626 bytes
[290] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 1751, 473, 0) + 1282 bytes
[291] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1751, 348, 0) + 39 bytes
[292] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 1751, 348, 0) + 251 bytes
[293] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x08102300, 0xffffffff, 0x22c92a48 "|1 z«e", 2) + 876 bytes
[294] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(2, 0x00c28b4c, 4, 0x00c28bac) + 466 bytes
[295] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 2, 0x00c28b4c, 4) + 23 bytes
[296] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c28b4c, 4, 0x00c28bac) + 25 bytes
[297] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c28b4c, 4, 0x00c28bac) + 249 bytes
[298] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(2, 0x00c28b4c, 4, 0x00c28bac) + 420 bytes
[299] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(1424, 0x1ebc3fa0 "loc_codegenentry", 2, 4) + 626 bytes
[300] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 3226, 278, 0) + 1282 bytes
[301] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 3226, 12, 0) + 39 bytes
[302] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 3226, 12, 0) + 251 bytes
[303] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x00c29800, 0xffffffff, 0x1ee30d98, 0) + 876 bytes
[304] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c294b4, 6, 0x00c29518) + 466 bytes
[305] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c294b4, 6) + 23 bytes
[306] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c294b4, 6, 0x00c29518) + 25 bytes
[307] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c294b4, 6, 0x00c29518) + 249 bytes
[308] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c294b4, 6, 0x00c29518) + 420 bytes
[309] m_interpreter.dll:_inCallFcn(0, 0x00c294b4, 6, 0x00c29518) + 84 bytes
[310] m_interpreter.dll:_inFullFevalFcn(0, 0x00c294b4, 7, 0x00c29514) + 234 bytes
[311] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c294b4, 7, 0x00c29514) + 92 bytes
[312] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c294b4, 7, 0x00c29514) + 247 bytes
[313] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(311, 0x22cd7698 "feval", 0, 7) + 626 bytes
[314] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 171, 16, 0) + 1282 bytes
[315] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 171, 0, 0) + 39 bytes
[316] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 171, 0, 0) + 251 bytes
[317] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0x722b4c00, 0xffffffff, 0x1ef9f9c0, 0) + 876 bytes
[318] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x00c29cfc, 7, 0x00c29d5c) + 466 bytes
[319] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x00c29cfc, 7) + 23 bytes
[320] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c29cfc, 7, 0x00c29d5c) + 25 bytes
[321] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c29cfc, 7, 0x00c29d5c) + 249 bytes
[322] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c29cfc, 7, 0x00c29d5c) + 420 bytes
[323] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(892, 0x2127d34c "sl", 0, 7) + 626 bytes
[324] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(1, 41, 62, 0) + 1282 bytes
[325] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 41, 62, 0) + 39 bytes
[326] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(1, 41, 62, 0) + 251 bytes
[327] m_interpreter.dll:int __cdecl inExecuteMFunctionOrScript(class Mfh_mp *,bool)(0, 0xffffffff, 0x22c91c08, 0) + 876 bytes
[328] m_interpreter.dll:void __cdecl inRunMfile(int,struct mxArray_tag * *,int,struct mxArray_tag * *,class Mfh_mp *,struct inWorkSpace_tag *)(0, 0x2ac1a438, 6, 0x00c2a694) + 466 bytes
[329] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(struct _mdUnknown_workspace *,int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0, 0x2ac1a438, 6) + 23 bytes
[330] m_interpreter.dll:public: virtual void __thiscall Mfh_mp::dispatch_file(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x2ac1a438, 6, 0x00c2a694) + 25 bytes
[331] m_dispatcher.dll:public: virtual void __thiscall Mfh_file::dispatch_fh(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x2ac1a438, 6, 0x00c2a694) + 249 bytes
[332] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x2ac1a438, 6, 0x00c2a694) + 420 bytes
[333] m_interpreter.dll:_inCallFcn(0, 0x2ac1a438, 6, 0x00c2a694) + 84 bytes
[334] sl_services.dll:protected: virtual void __thiscall CallFcn_MLCommand::operator()(void)(1, 0x6ffd2bc4, 0, 0x2ac1a438) + 26 bytes
[335] sl_services.dll:class slsvDiagnosticImpl * __cdecl slsvFEVAL_NoThrow(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const,char const *,bool)(0, 0, 6, 0x00c2a694) + 84 bytes
[336] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl slCallFcnWithTrappingPrompt(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const,char const *,int)(0, 0, 6, 0x00c2a694) + 71 bytes
[337] libmwsimulink.dll:void __cdecl RTWBuildCore(struct slBlockDiagram_tag *)(0x27db9358, 0x00c2a868, 0x2afd5770, 0x00c2a714 "T§Â") + 307 bytes
[338] libmwsimulink.dll:void __cdecl RTWSimprmGcbf(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00c2a804, 1, 0x00c2a868) + 271 bytes
[339] libmwbuiltins.dll:void __cdecl bnFeatureFcn(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00c2a804, 2, 0x00c2a864) + 111 bytes
[340] m_dispatcher.dll:public: virtual void __thiscall Mfh_builtin::dispatch_mf(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2a804, 2, 0x00c2a864) + 92 bytes
[341] m_dispatcher.dll:public: void __thiscall Mfunction_handle::dispatch(int,struct mxArray_tag * *,int,struct mxArray_tag * *)(0, 0x00c2a804, 2, 0x00c2a864) + 247 bytes
[342] m_interpreter.dll:int __cdecl inDispatchFromStack(int,char const *,int,int)(131, 0x2f0b4044 "feature", 0, 2) + 626 bytes
[343] m_interpreter.dll:enum opcodes __cdecl inDispatchCall(char const *,int,int,int,int *,int *)(0x2f0b4044 "feature", 131, 0, 2) + 107 bytes
[344] m_interpreter.dll:int __cdecl inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag volatile *,int *)(0, 0, 0, 0) + 6048 bytes
[345] m_interpreter.dll:int __cdecl protected_inInterp(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(0, 0, 0, 0) + 39 bytes
[346] m_interpreter.dll:int __cdecl inInterPcodeSJ(enum inDebugCheck,int,int,enum opcodes,struct inPcodeNest_tag *,int *)(0, 0, 0, 0) + 251 bytes
[347] m_interpreter.dll:_inInterPcode(0, 0x00c2af64, 0x00c2ade0 "p®Â", 0) + 92 bytes
[348] m_interpreter.dll:enum inExecutionStatus __cdecl in_local_call_eval_function(int *,struct _pcodeheader *,int *,struct mxArray_tag * * const,enum inDebugCheck,bool)(0, 0x00c2af64, 0, 0) + 189 bytes
[349] m_interpreter.dll:enum inExecutionStatus __cdecl inEvalStringWithIsVarFcn(struct _memory_context *,char const *,enum EvalType,int,struct mxArray_tag * * const,enum inDebugCheck,struct _pcodeheader *,int *,bool (__cdecl*)(void *,char const *),void *,bool,bool)(0x7b9dd604, 0x2aa333b0 "try\nfeature('RTWBuild',get_para", 0, 0) + 484 bytes
[350] m_interpreter.dll:enum inExecutionStatus __cdecl inEvalCmdWithLocalReturn(char const *,int *,bool,bool,bool (__cdecl*)(void *,char const *))(0x2aa333b0 "try\nfeature('RTWBuild',get_para", 0, 0, 0) + 79 bytes
[351] m_interpreter.dll:public: virtual enum inExecutionStatus __thiscall InterpBridge::EvalCmdWithLocalReturn(char const *,int *,bool,bool)(0x2aa333b0 "try\nfeature('RTWBuild',get_para", 0, 0, 0) + 25 bytes
[352] m_interpreter.dll:_inEvalCmdWithLocalReturn(0x2aa333b0 "try\nfeature('RTWBuild',get_para", 0, 0, 0) + 30 bytes
[353] m_interpreter.dll:public: virtual enum inExecutionStatus __thiscall InterpBridge::EvalCmd(char const *,bool)(0x2aa333b0 "try\nfeature('RTWBuild',get_para", 0, 0x00c2b060, 0x6ffb5fcc) + 35 bytes
[354] m_interpreter.dll:_inEvalCmd(0x2aa333b0 "try\nfeature('RTWBuild',get_para", 0, 0x6ffb6f5a, 0x0fb147a0) + 24 bytes
[355] sl_services.dll:protected: virtual void __thiscall EvalCmd_MLCommand::operator()(void)(1, 0x6ffd2bd8 "pcûo _ûo", 0, 0) + 12 bytes
[356] sl_services.dll:class slsvDiagnosticImpl * __cdecl slsvEVAL_NoThrow(char const *,bool)(0x2aa333b0 "try\nfeature('RTWBuild',get_para", 1, 0x1eb5ea60 "controlMCUSlugsMKII/Inner Loop//..", 9) + 63 bytes
[357] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl EvalCmd(char const *,struct inWorkSpace_tag *)(0x261acf28 "try\nfeature('RTWBuild',get_para", 0x0fb147a0, 19, 0x2a14bb50) + 63 bytes
[358] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl slCallCallbackWithType(void *,char const *,int,enum CBGraphValidity,enum CBWkSpType)(0x261d5cd8, 0x261acf28 "try\nfeature('RTWBuild',get_para", 19, 1) + 601 bytes
[359] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl BlockCallback(class slBlock *,int)(0x261d5cd8, 0x00c2b1c0, 0x00c2b180, 0x6e6e4c65) + 70 bytes
[360] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl BlockOpenCallback(class slBlock *)(0x261d5cd8, 0x261acf29 "ry\nfeature('RTWBuild',get_param", 0, 0x405d8010) + 18 bytes
[361] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl BlockOpenOpenFcn(class slBlock * *,struct BlockOpenRec *)(0x00c2b228, 0, 0x261d5cd8, 0x00c2b228) + 21 bytes
[362] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl BlockOpenDefault(class slBlock * *,struct BlockOpenRec *)(0x00c2b1c0, 0x00c2b228, 0x7be8f460, 0x261d5cd8) + 58 bytes
[363] libmwsimulink.dll:class slsvDiagnosticImpl * __cdecl BlockOpen(class slBlock *,struct BlockOpenRec *)(0x261d5cd8, 0x00c2b228, 0x29f8d468, 4) + 89 bytes
[364] libmwsimulink.dll:void __cdecl BlockOpenFromUI(class slBlock *,struct slGraph_tag const *,struct BlockOpenRec *)(0x261d5cd8, 0x2a40de70, 0x00c2b228, 0x29f8d468) + 78 bytes
[365] libmwsimulink.dll:void __cdecl DefaultBlockHandleClickFcn(struct slGraph_tag *,class slBlock *,class SlEvent *,struct mwpoint *)(0x2a40de70, 0x261d5cd8, 0x2249adc0, 0x00c2b304) + 740 bytes
[366] libmwsimulink.dll:void __cdecl BlockHandleClick(struct slGraph_tag *,class slBlock *,void *,struct mwpoint *)(0x2a40de70, 0x261d5cd8, 0x2249adc0, 0x00c2b304) + 30 bytes
[367] libmwsimulink.dll:void __cdecl bdeButtonDownFcn(struct WinRec_tag *,class SlEvent *)(0x29f8d468, 0x2249adc0, 0x29f8d468, 0x00c2b33c "h³Â") + 745 bytes
[368] libmwsimulink.dll:public: static void __cdecl SlUserEvent::sendUserEvent(void (__cdecl*)(struct WinRec_tag *,class SlEvent *),struct WinRec_tag *,void *)(0x6e142bd0, 0x29f8d468, 0x00c2b384, 0x00c2b368 "¨³Â") + 205 bytes
[369] libmwsimulink.dll:_bdeButtonDownWrapper(0x29f8d468, 0x00c2b384, 0x29f8d468, 3408078) + 21 bytes
[370] libmwgui.dll:void __cdecl wm_ButtondownFcn(struct WinRec_tag *,void *)(0x29f8d468, 0x00c2b384, 0x29e93d00, 0x6e8cbef0) + 67 bytes
[371] libmwsimulink.dll:protected: void __thiscall CMdlView::OnLButtonDblClk(unsigned int,class CPoint)(1, 206, 52, 0x7d73bbe0) + 126 bytes
[372] MFC80.DLL:0x00de2cd8(515, 1, 3408078, 0x00c2b474)
[373] MFC80.DLL:0x00de277e(515, 1, 3408078, 0x7d73bcc0)
[374] MFC80.DLL:0x00de1514(0, 525174, 515, 1)
[375] MFC80.DLL:0x00de172a(525174, 515, 1, 3408078)
[376] libmwsimulink.dll:long __stdcall AfxWndProcDllStatic(struct HWND__ *,unsigned int,unsigned int,long)(525174, 515, 1, 3408078) + 51 bytes
[377] USER32.dll:0x769d86ef(0x6e9afe7f, 525174, 515, 1)
[378] USER32.dll:0x769d8876(1292564, 0x6e9afe7f, 525174, 515)
[379] USER32.dll:0x769d89b5(0x6e9afe7f, 1, 0x00c2b6d0 "à¶Â", 0x7b22ec0e)
[380] USER32.dll:0x769d3578(0x00c2b694, 0x7b2967b0 "H8&{", 0, 0x7c1322f0)
[381] uiw.dll:char * __cdecl getCommand(char *,int)(0x7e86b988, 4096, 0x00c2b730 "¬·Â", 0x7e857bbf) + 606 bytes
[382] uiw.dll:public: virtual char * __thiscall uiw::UIW_IOProxy::getCmdWindowCommand(char *,int)const (0x7e86b988, 4096, 0, 0) + 16 bytes
[383] libmwbridge.dll:char * __cdecl winReadStdin(char * const,unsigned int,bool)(0x7e86b988, 4096, 0, 0x00c2f8d4) + 79 bytes
[384] libmwbridge.dll:char * __cdecl ioReadLineOS(bool,struct _iobuf * const,char * const,char * const,int,bool * const,void (__cdecl*const)(void),char * (__cdecl*const)(char * const,unsigned int,bool))(0, 0x72341b78 "@I4r", 0x1d19d4a0, 4096) + 265 bytes
[385] libmwbridge.dll:char * __cdecl ioReadLine(bool,struct _iobuf *,char *,char *,int,bool *)(0, 0x72341b78 "@I4r", 0x1d19d4a0, 0x1d19d4a0) + 99 bytes
[386] libmwbridge.dll:void __cdecl mnGetFullLine(char * *,unsigned int *,unsigned int *,bool)(0x00c2f8d8, 0x00c2f8cc, 0, 0x7b95ab70) + 205 bytes
[387] libmwbridge.dll:_mnGetCommandLineBuffer(0, 0, 0x0fbdc488, 0) + 124 bytes
[388] libmwbridge.dll:__catch$_mnParser$0(0x0109ffd8, 0, 0x0d0c4601, 1) + 164 bytes
[389] mcr.dll:private: void __thiscall mcrInstance::mnParser_on_interpreter_thread(void)(0x0fbdc4c0, 0x084ae39c, 10, 0x00c2fb98) + 51 bytes
[390] mcr.dll:public: void __thiscall boost::function0<void>::operator()(void)const (0, 0x0fbdc488, 0, 0x0fbdc488) + 63 bytes
[391] mcr.dll:public: virtual void __thiscall mcr::runtime::InterpreterThread::Impl::NoResultInvocationRequest::run(void)(0x7a0ee820, 0x083a3c00 "¬±Íy", 0x00c2fa20, 0) + 53 bytes
[392] mcr.dll:private: static void __cdecl mcr::runtime::InterpreterThread::Impl::invocation_request_handler(int)(0x0fbdc488, 0, 0x00030000 "Actx ", 0x00c2fb9c) + 40 bytes
[393] uiw.dll:bool __cdecl UIW_DispatchUserMessage(int,int)(9223, 0x0fbdc488, 0x00c2fb9c, 3) + 81 bytes
[394] uiw.dll:long __stdcall HandleUserMsgHook(int,unsigned int,long)(0, 1, 0x00c2fb9c, 9223) + 95 bytes
[395] USER32.dll:0x769f6e6e(0x00030000 "Actx ", 1, 0x00c2fb9c, 0x7b2563e0)
[396] USER32.dll:0x769d31eb(0x00c2fb8c, 0x00c2fb9c, 0x00c2fbb8, 0)
[397] USER32.dll:0x769d4260(0x00c2fb8c, 48, 0x00c2fc98 "ÔüÂ", 0x771e63e0)
[398] ntdll.dll:0x771e642e(0x00c2fc08, 0, 0, 0)
[399] uiw.dll:void __cdecl UIW_GetAndDispatchMessage(struct tagMSG *)(0x00c2fc08, 0x010ba268, 0, 0x00c2fc50 "hüÂ") + 20 bytes
[400] uiw.dll:void __cdecl UIW_GetAndDispatchMessage(void)(0x0fc0e640, 0x0fc0e638, 0, 9223) + 15 bytes
[401] uiw.dll:public: virtual void __thiscall uiw_ppeHook::pollingDuringFcn(bool)(0, 0, 0x00c2fcd2, 0x0fc0e638) + 53 bytes
[402] libuij.dll:struct sysq::during_F<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> __cdecl std::for_each<class std::_Vector_iterator<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *,class std::allocator<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> >,struct sysq::during_F<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> >(class std::_Vector_iterator<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *,class std::allocator<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> >,class std::_Vector_iterator<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *,class std::allocator<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> >,struct sysq::during_F<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *>)(0x00c2fcd2, 0x0fc0e638, 0x0fc0e640, 0) + 41 bytes
[403] libuij.dll:struct sysq::during_F<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> __cdecl sysq::ppe_for_each<struct sysq::during_F<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *> >(struct sysq::during_F<class sysq::wsfcn_proxy<class sysq::ws_ppeHook *> *>)(0x00c2fcd2, 0, 0x010a1288, 0x7b990f43) + 70 bytes
[404] libuij.dll:void __cdecl sysq::ppeMainLoop(int,int,bool)(1, 0xffffffff, 0, 2) + 243 bytes
[405] libuij.dll:void __cdecl sysq::ppeLoopIfOK(int,int,bool)(1, 0xffffffff, 0, 0) + 118 bytes
[406] libuij.dll:void __cdecl sysq::processPendingEvents(int,int,bool)(1, 0xffffffff, 0, 0x00c2fd90 "ÐýÂ") + 100 bytes
[407] libuij.dll:void __cdecl UIJ_WS_ProcessPendingEvents(int,int)(1, 0xffffffff, 0x010a1288, 0x0109a1d8) + 18 bytes
[408] mcr.dll:public: void __thiscall mcr::runtime::InterpreterThread::Impl::process_events(class boost::shared_ptr<class mcr::runtime::InterpreterThread::Impl> const &)(0x00c2fde8, 2, 0x0109faa8, 0x03dcdd60) + 138 bytes
[409] mcr.dll:__catch$?run@Impl@InterpreterThread@runtime@mcr@@QAEKABV?$shared_ptr@VImpl@InterpreterThread@runtime@mcr@@@boost@@PAUinit_context@1234@@Z$0(0x00c2fde8, 0x0109d470, 0x7a0f1940, 0x0109b6a0) + 128 bytes
[410] mcr.dll:unsigned long __cdecl run_init_and_handle_events(void *)(0x03dcdd60, 0x0040b7cc, 602478, 0) + 76 bytes
[411] mcr.dll:private: void __thiscall mcr::runtime::InterpreterThreadFactory::runThreadFunction(void)(0x00c2fe98, 0x00c2fe54, 0x00c2fe58 "¸þÂ", 0x7b95c1bc) + 108 bytes
[412] MATLAB.exe:public: void __thiscall boost::function0<void>::operator()(void)const (0, 0, 1, 0x0109b6a0) + 63 bytes
[413] MATLAB.exe:int __cdecl mcrMain(int,char const * * const)(1, 0x0109c6b0, 4194304, 10) + 158 bytes
[414] MATLAB.exe:_WinMain@16(4194304, 0, 602478, 10) + 109 bytes
[415] MATLAB.exe:___tmainCRTStartup(0x7ffd8000, 0x00c2ffd4 "ìÿÂ", 0x771fb495, 0x7ffd8000) + 320 bytes
[416] kernel32.dll:0x76871194(0x7ffd8000, 0x77e555c0, 0, 0)
[417] ntdll.dll:0x771fb495(0x00406e06, 0x7ffd8000, 0, 0)
[418] ntdll.dll:0x771fb468(0x00406e06, 0x7ffd8000, 0, 0x78746341)
MATLAB m-file stack trace:
> In coder\private\code_sfun_glue_code at 125
In coder\private\code_chart_source_file_sfun at 55
In coder\private\code_chart_source_file at 10
In coder\private\generate_code_for_charts_and_machine at 70
In sfc at 163
In stateflow\private\targetman>code_method at 309
In stateflow\private\targetman>method_nag_wrapper at 130
In stateflow\private\targetman at 76
In stateflow\private\autobuild_kernel>autobuild_local at 195
In stateflow\private\autobuild_kernel at 53
In stateflow\private\autobuild_driver at 110
In stateflow\private\slsf at 122
In tlc_c at 160
In RTW.makertw.make_rtw at 227
In make_rtw at 22
In C:\Users\SLUG_Test\Documents\MATLAB\dsPIC Blockset\dspic\make_CreateMPLAB.p>make_CreateMPLAB at 5
In simulink\private\build_target>RunBuildCmd at 88
In simulink\private\build_target at 6
In simulink\private\build_standalone_rtw_target at 51
In C:\Program Files\MATLAB\R2010a\toolbox\simulink\simulink\private\slbuild_private.p>loc_codegenentry at 473
In C:\Program Files\MATLAB\R2010a\toolbox\simulink\simulink\private\slbuild_private.p>slbuild_private at 278
In sl at 16
In slbuild at 62
Code Directory :
"C:\Users\SLUG_Test\Documents\MATLAB\SLUG_Autopilot\slprj\_sfprj\controlMCUSlugsMKII\_self\sfun\src"
Machine (#17): "controlMCUSlugsMKII" Target : "sfun"
Chart "myMux Fun1" (#18):
"c1_controlMCUSlugsMKII.h"
"c1_controlMCUSlugsMKII.c"
Chart "myMux Fun1" (#28):
"c2_controlMCUSlugsMKII.h"
"c2_controlMCUSlugsMKII.c"
Chart "myMux Fun5" (#38):
"c3_controlMCUSlugsMKII.h"
"c3_controlMCUSlugsMKII.c"
Chart "Buffer IC Channel" (#49):
"c4_controlMCUSlugsMKII.h"
"c4_controlMCUSlugsMKII.c"
Chart "Embedded MATLAB Function" (#56):
"c5_controlMCUSlugsMKII.h"
"c5_controlMCUSlugsMKII.c"
Chart "Buffer IC Channel1" (#64):
"c6_controlMCUSlugsMKII.h"
"c6_controlMCUSlugsMKII.c"
Chart "negprotect" (#71):
"c7_controlMCUSlugsMKII.h"
"c7_controlMCUSlugsMKII.c"
Chart "Compute Circles" (#78):
"c8_controlMCUSlugsMKII.h"
"c8_controlMCUSlugsMKII.c"
Chart "Embedded MATLAB Function1" (#93):
"c9_controlMCUSlugsMKII.h"
"c9_controlMCUSlugsMKII.c"
Chart "Embedded MATLAB Function" (#100):
"c10_controlMCUSlugsMKII.h"
"c10_controlMCUSlugsMKII.c"
Chart "Embedded MATLAB Function1" (#112):
"c11_controlMCUSlugsMKII.h"
"c11_controlMCUSlugsMKII.c"
Chart "myMux Fun1" (#120):
"c12_controlMCUSlugsMKII.h"
"c12_controlMCUSlugsMKII.c"
Chart "myMux Fun2" (#128):
"c13_controlMCUSlugsMKII.h"
"c13_controlMCUSlugsMKII.c"
Code generation failed !errorOccurred
### Real-Time Workshop build procedure for model: 'controlMCUSlugsMKII' aborted due to an error.
>> I attached the error window also.
http://img713.imageshack.us/img713/9108/error1t.th.png
http://img99.imageshack.us/img99/443/error2m.th.png
Am I not initiating something? MATLAB isn't sucessfully compiling the model correctly so I can't try the -mlarge-data compile flag.
Do have an Idea of what I am doing wrong?
EDIT 11-22-10: Tried to compile the latest commit and got the same error. This has to be caused by MATLAB.
Here is my compiler info, etc.
OS: Windows 7 (32-bit)
MATLAB: Matlab 2010a (32-bit)
mex and mbuild compiler: Microsoft Visual C++ 2008 Express
dsPIC Blockset V3.3a
MPLAB C30 Compiler (MPLAB C Compiler for PIC24 MCUs and dsPICs v3.25 LITE Mode)
MPLAB C32 Compiler (MPLAB C Compiler for PIC32 v1.1B LITE Mode)
MPLAB IDE v8.60
Dan
Re: SLUGS - an open source autopilot
Hi Dan,
I tested again with another configuration :
mex and mbuild compiler: LCC
MPLAB C30 Compiler (MPLAB C Compiler for PIC24 MCUs and dsPICs v3.24 LITE Mode)
MPLAB IDE v8.60
The first attempt crash (I mean, that MATLAB crashed i.e. exit)
Thus, I restarted matlab, removed the two directory created : slpjr and controlMCUSlugsMKII_dspic.
Then compiling went Ok (or you will get a link error if -mdata-large is not added, see previous post)
HOWEVER, when I compile the model a second time, I get a matlab crash (propose to save the model and then exit) !
Thus, I suspect a matlab problem with windows memory. The model might be memory consumming, the blockset may also do something wront that create the problem if memory is not sufficient ?
The windows 32 system I am using has 3Go of RAM (from system properties)
Test with previous windows 64 had only 2go or RAM)
The difference with your configuration is only on C30 compiler and mex compiler.
- The problem you get is not at compilation time. C30 Compiler should not be responsible.
- The model might call mex and the difference between LCC and visual C compiler may change something ? (change with mex-setup, provided you have LCC installed, from matlab CD)
There is clearly something weird about the model file, however, It can be compiled anyway. It might be too big ? Can you try with other computer ? try also to remove some blocks of the model, that may isolate the problem and reduce memory required. Perhaps something can be configured differently with matlab memory or windows cache memory ?
You could also try to create a new model, configure it properly and copy-past all blocks. Simulink model file store information about blockset that SLUG team has but that we do not have. Theses information may create problems thus copying blocks into a new model file might clean it up !
I may have a look on the blockset to check if it might create such problems.
MPLAB IDE v8.60
Lubin,
I reinstalled everything on a different computer. It compiled all the way to the following error.
I then followed the directions on recompiling the mcp file and adding the -mlarge-data to the simulink model. I recompiled and got the following command window output:
Getting closer!
Dan
sbrk.o(.libc+0x4):C:\Users\Lubin\Desktop\SLUGS\clib\sbrk.c: Link Error: Cannot access symbol (___curbrk) with file register addressing. Value must be less than 8192. Suggest large-data model. I then followed the directions on recompiling the mcp file and adding the -mlarge-data to the simulink model. I recompiled and got the following command window output:
PPTPTPNumber of I/O PINs used : 8
TTPNumber of I/O PINs used : 8
TPTTTPTPTPNumber of I/O PINs used : 8
TTPTPTWarning: Input port 1 of 'controlMCUSlugsMKII/Trim Vals/Log
Trims Using PWM High [groundStationDriver.c]/Report Airspeed'
is not connected.
Warning: Output port 1 of 'controlMCUSlugsMKII/Update PWM
Commands and Send Telemetry/[dR dE dA dT]2' is not connected.
Commands and Send Telemetry/[dR dE dA dT]3' is not connected.
Warning: Parameter precision loss occurred for 'Threshold'.
The parameter's value cannot be represented exactly using the
run-time data type. A small quantization error has occurred.
You can control this diagnostic on the Diagnostics pane of the
Configuration Parameters dialog. This originated from
'controlMCUSlugsMKII/Inner Loop// Navigation/Compute
psi_dot_m/Protect NaNs/Switch3'.
Warning: Parameter precision loss occurred for 'Gain'. The
'controlMCUSlugsMKII/Inner Loop// Navigation/L1 Output
Feedback Controller With Projection Operator/Control
Law/Compute Coef/-T'.
Feedback Controller With Projection Operator/Protect
NaNs/Switch3'.
NaNs2/Switch3'.
Feedback Controller With Projection Operator/State
Predictor/Compute Coef/-T'.
Warning: Parameter precision loss occurred for 'Value'. The
Feedback Controller With Projection Operator/Trapezoidal
Integrator/Constant'.
Integrator/Constant1'.
Integrator/Constant2'.
Integrator/Constant3'.
Integrator/Protect NaNs/Switch3'.
Integrator/Protect NaNs1/Switch3'.
Integrator/Switch1'.
the Configuration Parameters dialog. This originated from
'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral
Channel/Angle Conversion/Unit Conversion'.
Channel/Angle Conversion2/Unit Conversion'.
Channel/Bank to Psi Dot/Constant1'.
the run-time data type. A small quantization error has
occurred. You can control this diagnostic on the Diagnostics
pane of the Configuration Parameters dialog. This originated
from 'controlMCUSlugsMKII/Inner Loop// Navigation/Lateral
Channel/Bank to Psi Dot/Protect NaNs/Switch3'.
Channel/Bank to Psi Dot/Protect NaNs1/Switch3'.
Channel/High Pass (Washout) Filter/Constant1'.
Channel/High Pass (Washout) Filter/Constant2'.
Channel/High Pass (Washout) Filter/Constant3'.
Channel/Protect NaNs/Switch3'.
Channel/Protect NaNs1/Switch3'.
Channel/Protect NaNs2/Switch3'.
Channel/Protect NaNs3/Switch3'.
Channel/Roll Control [PID]/Gain'.
Channel/Roll Control [PID]/Trapezoidal Integrator/Constant'.
Channel/Roll Control [PID]/Trapezoidal Integrator/Protect
NaNs /Switch3'.
NaNs1/Switch3'.
Channel/Roll Control [PID]/Trapezoidal Integrator/Switch1'.
Channel/Roll Control [PID]/delayTime'.
Channel/Sideslip Compensation/Bank to Psi Dot/Constant1'.
Channel/Sideslip Compensation/Constant'.
Channel/Sideslip Compensation/Low Pass/Compute Coef/-T'.
Channel/Sideslip Compensation/Protect NaNs2/Switch3'.
Channel/Sideslip Compensation/psi_dot to Bank/Constant1'.
Channel/Switch'.
Channel/Switch1'.
Channel/Switch2'.
Channel/Switch3'.
Channel/Yaw Damper [PID]/Gain'.
Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant'.
Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant1'.
Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant2'.
Channel/Yaw Damper [PID]/Trapezoidal Integrator/Constant3'.
Channel/Yaw Damper [PID]/Trapezoidal Integrator/Protect NaNs
/Switch3'.
NaNs1/Switch3'.
Channel/Yaw Damper [PID]/Trapezoidal Integrator/Switch1'.
Channel/Yaw Damper [PID]/delayTime'.
Channel/psi_dot to Bank/Constant1'.
'controlMCUSlugsMKII/Inner Loop// Navigation/Longitudinal
Channel/Air Density from Height/Constant 2 from Model'.
Channel/Air Density from Height/Length Conversion/Unit
Conversion'.
Channel/Air Density from Height/Rho_0 (Kg//m^3)'.
Channel/Airspeed Hold [PID]/Gain'.
Channel/Airspeed Hold [PID]/Trapezoidal
Navigation/Longitudinal Channel/Airspeed Hold
[PID]/Trapezoidal Integrator/Protect NaNs /Switch3'.
[PID]/Trapezoidal Integrator/Protect NaNs1/Switch3'.
Channel/Airspeed Hold [PID]/delayTime'.
Warning: Parameter precision loss occurred for 'LowerLimit'.
Navigation/Longitudinal Channel/Compute Airspeed/[ 0.01
50000]'.
Channel/Height Error to Pitch Command [PI]/Gain'.
Channel/Height Error to Pitch Command [PI]/Trapezoidal
Navigation/Longitudinal Channel/Height Error to Pitch
Command [PI]/Trapezoidal Integrator/Protect NaNs/Switch3'.
Command [PI]/Trapezoidal Integrator/Protect NaNs /Switch3'.
Command [PI]/Trapezoidal Integrator/Switch1'.
Channel/Pitch To Elevator [PID]/Gain'.
Channel/Pitch To Elevator [PID]/Trapezoidal
Navigation/Longitudinal Channel/Pitch To Elevator
Channel/Pitch To Elevator [PID]/delayTime'.
Navigation/Longitudinal Channel/Protect NaNs/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs1/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs2/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs3/Switch3'.
Navigation/Longitudinal Channel/Protect NaNs4/Switch3'.
Navigation/Longitudinal Channel/Schedule LPF'.
Navigation/Longitudinal Channel/Switch'.
Navigation/Navigation/Compute Lateral
Error/Subsystem3/Protect NaNs/Switch3'.
Navigation/Navigation/Compute WP Index/Compute P/Compute T
in Frenet/Normalize Vector/Zero Bound'.
P/Geod2LTP1/ECEF2LTP (UEN)/Deg2R'.
P/Geod2LTP1/Geod2ECEF1/Deg2R'.
P/Geod2LTP1/Geod2ECEF1/Deg2R1'.
P/Geod2LTP1/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Compute WP Index/Compute P/Get
Circles/Compute delta Left Turn/Constant5'.
Circles/Constant5'.
Circles/compute delta Right Turn/Constant5'.
Navigation/Navigation/Compute WP Index/Grab IC/Compute GS
Location/Geod2ECEF1/Deg2R'.
Location/Geod2ECEF1/Deg2R1'.
Location/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Compute WP Index/Protect
NaNs/Switch3'.
Navigation/Navigation/Compute WP Index/Switch when in Line
Segment/1st WP'.
Segment/Compute Projection/Protect NaNs/Switch3'.
Segment/Compute Total Run/Protect NaNs/Switch3'.
Navigation/Navigation/Get Wps Compute Frenet/Compute
Frenet/Normalize Vector /Zero Bound'.
'controlMCUSlugsMKII/Inner Loop// Navigation/Navigation/Get
Wps Compute Frenet/Geod2LTP1/ECEF2LTP (UEN)/Deg2R'.
Wps Compute Frenet/Geod2LTP1/Geod2ECEF1/Deg2R'.
Wps Compute Frenet/Geod2LTP1/Geod2ECEF1/Deg2R1'.
Wps Compute
Frenet/Geod2LTP1/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Wps Compute Frenet/Geod2LTP2/ECEF2LTP (UEN)/Deg2R'.
Wps Compute Frenet/Geod2LTP2/Geod2ECEF1/Deg2R'.
Wps Compute Frenet/Geod2LTP2/Geod2ECEF1/Deg2R1'.
Wps Compute
Frenet/Geod2LTP2/Geod2ECEF1/eccentricity^2/Rp=polar radius'.
Navigation/Navigation/Get Wps Compute Frenet/Switch'.
Navigation/Navigation/Gravity'.
Navigation/Navigation/Park, Deyst & How Lat Accel
Cmd/Compute Eta/Subsystem6/Protect NaNs/Switch3'.
Warning: Parameter precision loss occurred for 'UpperLimit'.
Cmd/Compute Eta/Subsystem6/[-1,1]'.
Cmd/GainSchedule L2 and Get Groundspeed/Protect
NaNs/Switch3'.
Navigation/Navigation/Park, Deyst & How Lat Accel Cmd/Park's
Lateral Accel Command/Protect NaNs/Switch3'.
Navigation/Navigation/as_c to phi_c/Protect NaNs/Switch3'.
from 'controlMCUSlugsMKII/Inner Loop// Navigation/Protect
NaNs/Switch3'.
'controlMCUSlugsMKII/Trim Vals/Gain1'.
'controlMCUSlugsMKII/Trim Vals/Gain2'.
'controlMCUSlugsMKII/Trim Vals/Gain3'.
from 'controlMCUSlugsMKII/Update PWM Commands and Send
Telemetry/Generate PWM Signals Based on the Control Type/If
Control Type Is Selective Passthrough/Switch'.
Control Type Is Selective Passthrough/Switch1'.
Control Type Is Selective Passthrough/Switch2'.
Control Type Is Selective Passthrough/Switch3'.
'controlMCUSlugsMKII/get Nav Vars/Angle Conversion/Unit
Conversion'.
from 'controlMCUSlugsMKII/get Nav Vars/Direction Cosine
Matrix to Euler Angles/Subsystem3/[-1,1]'.
### Invoking Target Language Compiler on controlMCUSlugsMKII.rtw
### Using System Target File: C:\Users\Dan\Documents\MATLAB\dsPIC_blockset\dspic\dspic.tlc
### Writing source file controlMCUSlugsMKII.c
### Writing header file controlMCUSlugsMKII_private.h
### Writing header file controlMCUSlugsMKII.h
### Writing header file controlMCUSlugsMKII_types.h
### Writing header file rtwtypes.h
### Writing header file rt_MAXf_snf.h
### Writing header file rt_zcfcn.h
### Writing source file rt_zcfcn.c
### Writing header file rt_nonfinite.h
### Writing source file rt_nonfinite.c
### Writing header file rt_SATURATE.h
### Writing header file rt_SIGNf_snf.h
### Writing header file rtGetInf.h
### Writing source file rtGetInf.c
### Writing header file rtGetNaN.h
### Writing source file rtGetNaN.c
### Writing source file controlMCUSlugsMKII_data.c
### Writing source file controlMCUSlugsMKII_main.c
### Creating HTML report file controlMCUSlugsMKII_codegen_rpt.html
.### Evaluating PostCodeGenCommand specified in the model
Embedded Coder for dsPIC V3.3a(22-Nov-2010) for Matlab R2010a.
Licence Accorded to Blake Mills
[adresse e-mail retirée]
University of Colorado-Boulder
University of Colorado at Boulder
xxx UCB
Boulder, Colorado 80309-0xxx
USA
Facturation to : Blake Mills
Check updates and new informations at : www.kerhuel.eu
### Processing Template Makefile: C:\Users\Dan\Documents\MATLAB\dsPIC_blockset\dspic\dspic_pic30_gcc.tmf
### Creating controlMCUSlugsMKII.mk from C:\Users\Dan\Documents\MATLAB\dsPIC_blockset\dspic\dspic_pic30_gcc.tmf
### Building controlMCUSlugsMKII: "C:\PROGRA~1\MATLAB\R2010a\bin\win32\gmake" -f controlMCUSlugsMKII.mk GENERATE_REPORT=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/DEE.c
''pic30-gcc -c C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/DEES.s -Wa,-p=33fJ256MC710,-g
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/apUtils.c
C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/apUtils.c:852:7: warning: no newline at end of file
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/circBuffer.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include controlMCUSlugsMKII_data.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include controlMCUSlugsMKII_main.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include dsPIC_InputCapture_Interrupt.c
dsPIC_InputCapture_Interrupt.c: In function '_IC2Interrupt':
dsPIC_InputCapture_Interrupt.c:11: warning: PSV model not specified for '_IC2Interrupt';
assuming 'auto_psv' this may affect latency
dsPIC_InputCapture_Interrupt.c: In function '_IC3Interrupt':
dsPIC_InputCapture_Interrupt.c:32: warning: PSV model not specified for '_IC3Interrupt';
dsPIC_InputCapture_Interrupt.c: In function '_IC4Interrupt':
dsPIC_InputCapture_Interrupt.c:53: warning: PSV model not specified for '_IC4Interrupt';
dsPIC_InputCapture_Interrupt.c: In function '_IC5Interrupt':
dsPIC_InputCapture_Interrupt.c:74: warning: PSV model not specified for '_IC5Interrupt';
dsPIC_InputCapture_Interrupt.c: In function '_IC8Interrupt':
dsPIC_InputCapture_Interrupt.c:95: warning: PSV model not specified for '_IC8Interrupt';
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/groundStationDriver.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/interProcCommSlave.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/navSupport.c
C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/navSupport.c:211:2: warning: no newline at end of file
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/protDecoder.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include rtGetInf.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include rtGetNaN.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include rt_nonfinite.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include rt_zcfcn.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib/sbrk.c
''pic30-gcc -c -mcpu=33fJ256MC710 -O -merrata=exch -mlarge-data -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\controlMCUSlugsMKII_dspic\sources -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62 -IC:\Users\Dan\Documents\MATLAB\SLUG_Autopilot\malife-SLUGS-13d8c62\clib -I C:\PROGRA~1\MICROC~1\MPLABC~2\include controlMCUSlugsMKII.c
''pic30-ld -t --report-mem -Map ../untitled.map --heap 0 -cref -T C:\PROGRA~1\MICROC~1\MPLABC~2\support\dsPIC33F\gld\p33fJ256MC710.gld -o ..\../controlMCUSlugsMKII.cof DEE.o DEES.o apUtils.o circBuffer.o controlMCUSlugsMKII_data.o controlMCUSlugsMKII_main.o dsPIC_InputCapture_Interrupt.o groundStationDriver.o interProcCommSlave.o navSupport.o protDecoder.o rtGetInf.o rtGetNaN.o rt_nonfinite.o rt_zcfcn.o sbrk.o controlMCUSlugsMKII.o C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a
C:\Program Files\Microchip\MPLAB C30\bin\bin/pic30-coff-ld.exe: mode pic30_coff
DEE.o
DEES.o
apUtils.o
circBuffer.o
navSupport.o
protDecoder.o
rtGetInf.o
rtGetNaN.o
rt_nonfinite.o
rt_zcfcn.o
sbrk.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)crt0_standard.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)brk.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)data_init_standard.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)putsUART2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntTimer1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture4.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture4.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture5.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture5.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenCapture8.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntCapture8.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)SetDCMCPWM.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)ConfigIntMCPWM.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a)OpenMCPWM.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)memcpy.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)vsprintf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)memset.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)doprnt.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)powers.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)fputc.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)fseek.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)fflush.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)flsbuf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)buf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a)errno.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fixsfsi.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)atan2f.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)powf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)sqrtf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)atanf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)asinf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)sinf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)cosf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)tanf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)acosf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)expf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fixunssfsi.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)feqltle.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fne.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fgtge.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)mulsf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)addsf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)divsf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)floatsisf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)floorf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fmodf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)muldf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)extendsfdf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)deqltle.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dne.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fixdfdi.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)floatdisf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)frexpf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dgtge.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)divdf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fixunsdfsi.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)subdf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)adddf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)divmoddi3.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fixunsdfdi.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)floatdidf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)funpack.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)funpack2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)futil.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fchop.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)_frexpf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)ldexpf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)logf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fpack.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)asinacosf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)sincosf.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fcompare.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)fmodrem.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dunpack2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dpack.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dcompare.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dunpack.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dpropagateNaN.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a)dtype.o
Program Memory [Origin = 0x200, Length = 0x2aa00]
section address length (PC units) length (bytes) (dec)
.text 0x200 0x2b52 0x40fb (16635)
.const 0x2d52 0x94 0xde (222)
.text 0x2de6 0x126 0x1b9 (441)
.text 0x2f0c 0xf0 0x168 (360)
.isr 0x2ffc 0x2 0x3 (3)
_02bc8a804cebe8d0 0x3000 0x1000 0x1800 (6144)
.text 0x4000 0x6190 0x9258 (37464)
.dinit 0xa190 0x384 0x546 (1350)
.text 0xa514 0x2da 0x447 (1095)
.text 0xa7ee 0x10e 0x195 (405)
.text 0xa8fc 0x1b4 0x28e (654)
Total program memory used (bytes): 0xfd05 (64773) 24%
Data Memory [Origin = 0x800, Length = 0x7800]
section address alignment gaps total length (dec)
.bss 0x800 0 0x174e (5966)
.data 0x1f4e 0 0x386 (902)
.dconst 0x22d4 0 0x2a (42)
.bss 0x22fe 0 0x2c (44)
.data 0x232a 0 0x4 (4)
.bss 0x232e 0 0x4 (4)
.data 0x2332 0 0x4 (4)
.bss 0x2336 0 0x8 (8)
_020821504cebe8d9 0x7f32 0 0xce (206)
Total data memory used (bytes): 0x1c0c (7180) 23%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x233e 0x5bf4 (23540)
Maximum dynamic memory (bytes): 0x5bf4 (23540)
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fseek.o)(.libc.ftell+0xa):fake: undefined reference to `lseek'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fseek.o)(.libc.fseek+0x1e):fake: undefined reference to `lseek'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fseek.o)(.libc.fseek+0x52):fake: undefined reference to `lseek'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fseek.o)(.libc.fseek+0x5c):fake: undefined reference to `lseek'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fseek.o)(.libc.fseek+0x66):fake: undefined reference to `lseek'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fseek.o)(.libc.fseek+0xc8):fake: more undefined references to `lseek' follow
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(fflush.o)(.libc.fflush+0x2e):fake: undefined reference to `write'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(flsbuf.o)(.libc._flsbuf+0x3a):fake: undefined reference to `write'
C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a(flsbuf.o)(.libc._flsbuf+0x56):fake: undefined reference to `write'
C:\Program Files\Microchip\MPLAB C30\bin\bin/pic30-coff-ld.exe: link errors found, deleting executable `..\../controlMCUSlugsMKII.cof'
gmake: *** [..\../controlMCUSlugsMKII.cof] Error 255
### Real-Time Workshop build procedure for model: 'controlMCUSlugsMKII' aborted due to an error. Getting closer!
Dan
It's getting closer.
You can now open the project within MPLAB and play with compilation options (anyway, not sure that would solve the problem)
The problem is in the last step : linking all objects and library binary files.
Comparing your list of object file being used with mine (in earlier post), it can be seen that the .o file list are different (after replacing few ~2 by ~1...)
At first sight, mine has 10 more file.
However, your list contains also library file not present in mine like (not exhaustive list) :
fputc.o
fseek.o
fflush.o
flsbuf.o
buf.o
Mine contain also library file not present in yours like (not exhaustive list) :
xprintf.o
At first thought, I do not see why file system fonction are needed (like fputc, fseek ...)
I think that some simulink model configuration have change a bit. (for example, there are option for the embedded code to report or not error, or to log data or not). Theses configuration bit change a bit the code and calls function that are not available ?
Same model should generate the same code.
fputc.o
fseek.o
fflush.o
flsbuf.o
buf.o
xprintf.o
Sorry for the long silence. I was out of town. I agree completely with Lubin. lseek() and write () are NOT used at all neither by Simulink (on a 2007A Windows XP configuration) nor by the custom C code I wrote for the low-level drivers. I think this is something completely different. It could be the Matlab version. It could be that it is trying to use the wrong linker. Or it could be the language tool library version.
The only thing I've seen come close to a report about this is in here: http://www.microchip.com/forums/tm.aspx ... ference+to
My best guess would be for you to try to downgrade the C 30 compiler to version 3.12 which is the one I have installed. You can download an older version from here : http://www.microchip.com/stellent/idcpl ... e=en023073
See if it gets you somewhere. Please do report here if this suggestion works or if you get exactly the same error.
This is very strange.
Thanks Mariano for the idea,
very quick post just to inform that I downloaded the latest version of C30 compiler (3.25) on my windows 32bits system with matlab 2010a and successfully get the model compiling.
Perhaps Dan may upload its model on the forum so as I will be able to test it ? Thet may provide new informations...
(I am not available this WE)
Hey Guys,
Sorry for the late reply, I was on vacation for a bit. So I attached the current SLUG Autopilot folder that I have been compiling from to see if it is a model issue. Let me know if you get anything working with this.
Dan
Here is the zip file link:
http://hotfile.com/dl/85363043/5dbefa9/ ... o.zip.html
Dan
Dan,
I confirm the version you uploaded compiles without a problem in my setup. This really narrows it to either your setup (compiler/Matlab version/ dsPIC Blockset version) or OS version. I am really sorry you are going through this but neither Lubin nor I have been able to reproduce it and, as you can expect, if we can't reproduce the error than we can not debug it.
You can download the version of the complete folder you uploaded with the files I just compiled here: http://dl.dropbox.com/u/6400827/Stable.zip
Did you try downgrading the compiler version as I suggested in my previous post? I am really out of ideas. Do you have any other computer where you can install from scratch?
I think it is a good time for a Skype telecon, ideally with Lubin Joining us.
I forgot to add that the only thing I did to compile was to double click the configuration block, then adding the errata and large data model flags to the compiler options. After that it compiled with no issue
Guys,
I double clicked the configure block and made sure all the flags were added and tried to re-compile. I got the exact same error. I feel like a teleconference would be perfect. I have all day Monday open if that works for both of you. I will try and compile the model with the older version of the C30 compiler (v3.12) on Monday before talking to you both.
Dan
Dan
Citation : malife I think it is a good time for a Skype telecon, ideally with Lubin Joining us.
I'll ba available on monday eivening (either about 19h30, or 20h30 or later on, French time is UTC+1.)
PS : I uploaded on the forum directly mariano dropbox's file (more sustainable for the forum). Prefere using the forum upload function that is more sustainable in time.
Lubin,
If I did my math right then I will be available at 2:00pm MST which is 21hr your time. Does this work for you? My Skype name is dan_ambrosio.
Let me know if this works for you.
Dan
Ps. Mariano do you have a preferred time?
Dan
Ok for me
I also have MPLAB IDE installed on my computer. While installing MPLAB, Mirochip also propose to install compiler and so on. I usually install them all.
Thus, you may try to install MPLAB also (freely available from Microchip website)
Lubin,
I do have the MPLAB IDE installed on my computer and install all the compilers. I tried to install your version of the MPLAB C30 compiler V3.25 and got the same lseek error as above. When I downgraded my compiler to V3.24 I get an error about memory when trying to compile the model
Also, when I double click to open the controlMCUSlugsMKII.mdl I get the following output from MATLAB.
I don't know if this is relevant at all since I wasn't getting most of these before. I am kind of running out of options here on what do to. Do you think it is the way I installed the MPLAB C30 compiler?
Dan
Warning: Could not find an exact (case-sensitive) match for 'ExecBatch'.
C:\Users\Dan\Documents\MATLAB\dsPIC_blockset\dspic\execBatch.p is a case-insensitive match and will be
used instead.
You can improve the performance of your code by using exact
name matches and we therefore recommend that you update your
usage accordingly. Alternatively, you can disable this warning using
warning('off','MATLAB:dispatcher:InexactCaseMatch').
This warning will become an error in future releases.
> In C:\Program Files\MATLAB\R2010a\toolbox\rtw\rtw\private\getSTFInfo.p>getSTFInfo at 97
In rtwprivate at 12
In stf4target at 34
In stf2target at 61
In general\private\openmdl at 13
In open at 158
In uiopen at 196
Warning: GMAKE_PLACE not defined, check tlc target
> In C:\Users\Dan\Documents\MATLAB\dsPIC_blockset\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 45
In C:\Users\Dan\Documents\MATLAB\dsPIC_blockset\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 87
In open at 158
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. The *System Target File
must be defined to dsPIC Real Time workshop (Simulation ==> Configuration Parameters ==> Real Time
workshop
In open at 158
In uiopen at 196
Warning: The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==>
Configuration Parameters ==> Real Time workshop
In open at 158
In uiopen at 196
Warning: In instantiating linked block 'controlMCUSlugsMKII/Master' : Invalid setting in Master block
(mask) 'Master' for parameter 'MCLR'
In open at 158
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Calculus Time Step'. two
dsPIC_MASTER blocks find. Max number of dsPIC_MASTER block is one !
In open at 158
In uiopen at 196
Warning: two dsPIC_MASTER blocks find. Max number of dsPIC_MASTER block is one !
In open at 158
In uiopen at 196
Dan
Hi Dan,
It seems you model file get two MASTER blocks now ! One of them may be in a subsystem ?
Here is the message I get while opening the model :
With a 32 bit windows,
I downloaded the zip fild you posted : SLUG_Autopilot_Ambrosio.zip
I unzip it into the same directory as you : C:\USERS\SLUG\Documents\MATLAB\
Then, I directly open the MPLAB project file : C:\USERS\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcp
and it sucessfully compiled within MPLAB. I get the following report :
Then, I renamed the directory where the c files are generated : controlMCUSlugsMKII_dspic (into controlMCUSlugsMKII_dspic_original)
I opened the model controlMCUSlugsMKII.mdl from MATLAB (2010a). Simulink was able to generate C code and compile it.
Comparing your generated source files with mines shows no differences (except in comment, like time etc...)
The only weird things I noticed is that matlab sometimes crashed. It may be due to the large size of the model file ?
From theses elements, I think that you are facing a problem with the compiler as the code you generated and that does not compile from your side successfully compiled here. Also, generated code from your matlab and mine is equal (except for comments)
You may have more insight posting the problem on the microchip forum (or to ask Microchip directly if you can)
The only solution I could propose is to start a new model from scratch, add blocks from mariano model one by one, compiling the model at several step. Do not forget to add custom c file written by the slug team in simulink configuration panel.
C:\Program Files\81eq9Z16RLFXQ\dspic\execBatch.m is a case-insensitive match and will be
used instead.
In rtwprivate at 12
In stf4target at 34
In stf2target at 61
In open at 158
In uiopen at 196
> In dsPIC_ConfigRTWOption at 45
In dsPIC_MASTER_callback at 45
In open at 158
In uiopen at 196
In open at 158
In uiopen at 196
(Simulation ==> Configuration Parameters ==> Real Time workshop
In open at 158
In uiopen at 196
in Master block (mask) 'Master' for parameter 'MCLR'
In open at 158
In uiopen at 196
PT>> With a 32 bit windows,
Debug build of project `C:\USERS\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcp' started.
Language tool versions: pic30-as.exe v3.24, pic30-gcc.exe v3.24, pic30-ld.exe v3.24, pic30-ar.exe v3.25
Preprocessor symbol `__DEBUG' is defined.
Tue Nov 30 18:21:37 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\DEE.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\DEES.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\apUtils.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\circBuffer.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_data.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_main.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\groundStationDriver.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\interProcCommSlave.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\navSupport.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\protDecoder.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\rtGetInf.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\rtGetNaN.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\rt_nonfinite.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\rt_zcfcn.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources\sbrk.o".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.cof".
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.hex".
Clean: Deleted file "C:\USERS\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII.c" -o"controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\DEE.c" -o"controlMCUSlugsMKII_dspic\sources\DEE.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -c -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\DEES.s" -o"controlMCUSlugsMKII_dspic\sources\DEES.o" -Wa,-I"controlMCUSlugsMKII_dspic\sources",--defsym=__DEBUG=1
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\apUtils.c" -o"controlMCUSlugsMKII_dspic\sources\apUtils.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\apUtils.c:852:7: warning: no newline at end of file
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\circBuffer.c" -o"controlMCUSlugsMKII_dspic\sources\circBuffer.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_data.c" -o"controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_data.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_main.c" -o"controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_main.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c" -o"controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c: In function '_IC2Interrupt':
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c:11: warning: PSV model not specified for '_IC2Interrupt';
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c: In function '_IC3Interrupt':
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c:32: warning: PSV model not specified for '_IC3Interrupt';
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c: In function '_IC4Interrupt':
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c:53: warning: PSV model not specified for '_IC4Interrupt';
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c: In function '_IC5Interrupt':
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c:74: warning: PSV model not specified for '_IC5Interrupt';
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c: In function '_IC8Interrupt':
controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c:95: warning: PSV model not specified for '_IC8Interrupt';
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\groundStationDriver.c" -o"controlMCUSlugsMKII_dspic\sources\groundStationDriver.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\interProcCommSlave.c" -o"controlMCUSlugsMKII_dspic\sources\interProcCommSlave.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\navSupport.c" -o"controlMCUSlugsMKII_dspic\sources\navSupport.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\navSupport.c:211:2: warning: no newline at end of file
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\protDecoder.c" -o"controlMCUSlugsMKII_dspic\sources\protDecoder.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rtGetInf.c" -o"controlMCUSlugsMKII_dspic\sources\rtGetInf.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rtGetNaN.c" -o"controlMCUSlugsMKII_dspic\sources\rtGetNaN.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rt_nonfinite.c" -o"controlMCUSlugsMKII_dspic\sources\rt_nonfinite.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rt_zcfcn.c" -o"controlMCUSlugsMKII_dspic\sources\rt_zcfcn.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib\sbrk.c" -o"controlMCUSlugsMKII_dspic\sources\sbrk.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII.o" "controlMCUSlugsMKII_dspic\sources\DEE.o" "controlMCUSlugsMKII_dspic\sources\DEES.o" "controlMCUSlugsMKII_dspic\sources\apUtils.o" "controlMCUSlugsMKII_dspic\sources\circBuffer.o" "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_data.o" "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_main.o" "controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.o" "controlMCUSlugsMKII_dspic\sources\groundStationDriver.o" "controlMCUSlugsMKII_dspic\sources\interProcCommSlave.o" "controlMCUSlugsMKII_dspic\sources\navSupport.o" "controlMCUSlugsMKII_dspic\sources\protDecoder.o" "controlMCUSlugsMKII_dspic\sources\rtGetInf.o" "controlMCUSlugsMKII_dspic\sources\rtGetNaN.o" "controlMCUSlugsMKII_dspic\sources\rt_nonfinite.o" "controlMCUSlugsMKII_dspic\sources\rt_zcfcn.o" "controlMCUSlugsMKII_dspic\sources\sbrk.o" "C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a" "C:\
PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a" "C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a" -o"controlMCUSlugsMKII.cof" -Wl,-L"controlMCUSlugsMKII_dspic\sources",--script="..\..\..\..\..\..\PROGRA~1\MICROC~1\MPLABC~2\support\dsPIC33F\gld\p33fJ256MC710.gld",--defsym=__MPLAB_BUILD=1,--defsym=__MPLAB_DEBUG=1,-Map="controlMCUSlugsMKII.map",--report-mem
.text 0x200 0x296e 0x3e25 (15909)
.text 0x2b6e 0x8c 0xd2 (210)
.isr 0x2bfa 0x2 0x3 (3)
_01b4ba104cf532a2 0x2c00 0x1000 0x1800 (6144)
.const 0x3c00 0x94 0xde (222)
.text 0x3c94 0x646a 0x969f (38559)
.dinit 0xa0fe 0x1da 0x2c7 (711)
.text 0xa2d8 0x3be 0x59d (1437)
.text 0xa696 0x8e 0xd5 (213)
Total program memory used (bytes): 0xf7b0 (63408) 24%
.nbss 0x800 0 0x2 (2)
.bss 0x802 0 0x174e (5966)
.data 0x1f50 0 0x9e (158)
.dconst 0x1fee 0 0x32 (50)
.data 0x2020 0 0x22 (34)
.bss 0x2042 0 0x2c (44)
.data 0x206e 0 0x12 (18)
.dconst 0x2080 0 0x8 (8)
.data 0x2088 0 0x6 (6)
.bss 0x208e 0 0x4 (4)
.data 0x2092 0 0x2 (2)
.bss 0x2094 0 0x2 (2)
.data 0x2096 0 0x2 (2)
.dconst 0x2098 0 0x2 (2)
.data 0x209a 0 0x2 (2)
_00f01a104cf532a5 0x7f32 0 0xce (206)
Total data memory used (bytes): 0x196a (6506) 21%
heap 0 0 (0)
stack 0x209c 0x5e96 (24214)
Maximum dynamic memory (bytes): 0x5e96 (24214)
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-bin2hex.exe" "C:\USERS\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.cof"
Loaded C:\USERS\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.cof.
Debug build of project `C:\USERS\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcp' succeeded.
Tue Nov 30 18:21:47 2010
BUILD SUCCEEDED Then, I renamed the directory where the c files are generated : controlMCUSlugsMKII_dspic (into controlMCUSlugsMKII_dspic_original)
Re: SLUGS - an open source autopilot
Lubin,
I opened the controlMCUSlugsMKII.mcp file in MPLAB IDE v8.60 and right click on the main folder to BuildAll. Here is the output:
I then looked at the main directory and found the a new controlMCUSlugsMKII.hex was generated. Doesn't this mean that it compiled sucessfully? There could be something wrong with the makefile that is being used by MATLAB to generate the hex file. Theoretically, I should be able to compile in MATLAB till it breaks then open the mcp file to finish the hex compile right?
Dan
Debug build of project `C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcp' started.
Language tool versions: pic30-as.exe v3.25, pic30-gcc.exe v3.25, pic30-ld.exe v3.25, pic30-ar.exe v3.25
Tue Nov 30 11:03:16 2010
Clean: Deleted file "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII.c" -o"controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\DEE.c" -o"controlMCUSlugsMKII_dspic\sources\DEE.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -c -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\DEES.s" -o"controlMCUSlugsMKII_dspic\sources\DEES.o" -Wa,-I"controlMCUSlugsMKII_dspic\sources",--defsym=__DEBUG=1
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\apUtils.c" -o"controlMCUSlugsMKII_dspic\sources\apUtils.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\apUtils.c:852:7: warning: no newline at end of file
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\circBuffer.c" -o"controlMCUSlugsMKII_dspic\sources\circBuffer.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_data.c" -o"controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_data.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_main.c" -o"controlMCUSlugsMKII_dspic\sources\controlMCUSlugsMKII_main.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.c" -o"controlMCUSlugsMKII_dspic\sources\dsPIC_InputCapture_Interrupt.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\groundStationDriver.c" -o"controlMCUSlugsMKII_dspic\sources\groundStationDriver.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\interProcCommSlave.c" -o"controlMCUSlugsMKII_dspic\sources\interProcCommSlave.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\navSupport.c" -o"controlMCUSlugsMKII_dspic\sources\navSupport.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\navSupport.c:211:2: warning: no newline at end of file
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\protDecoder.c" -o"controlMCUSlugsMKII_dspic\sources\protDecoder.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rtGetInf.c" -o"controlMCUSlugsMKII_dspic\sources\rtGetInf.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rtGetNaN.c" -o"controlMCUSlugsMKII_dspic\sources\rtGetNaN.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rt_nonfinite.c" -o"controlMCUSlugsMKII_dspic\sources\rt_nonfinite.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "controlMCUSlugsMKII_dspic\sources\rt_zcfcn.c" -o"controlMCUSlugsMKII_dspic\sources\rt_zcfcn.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256MC710 -x c -c "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib\sbrk.c" -o"controlMCUSlugsMKII_dspic\sources\sbrk.o" -I"controlMCUSlugsMKII_dspic\sourcescontrolMCUSlugsMKII_dspic\sources" -I"." -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\controlMCUSlugsMKII_dspic\sources" -I"C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\stable\clib" -I"C:\PROGRA~1\MICROC~1\MPLABC~2\include" -I"C:\PROGRA~1\MATLAB\R2010a/simulink/include" -I"C:\PROGRA~1\MATLAB\R2010a/extern/include" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/ert" -I"C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common" -D__DEBUG -O -merrata=exch -mlarge-data
.text 0x200 0x2bda 0x41c7 (16839)
.const 0x2dda 0x94 0xde (222)
.text 0x2e6e 0x126 0x1b9 (441)
.text 0x2f94 0x3e 0x5d (93)
.text 0x2fd2 0x1e 0x2d (45)
.isr 0x2ff0 0x2 0x3 (3)
_02b13a804cf53c67 0x3000 0x1000 0x1800 (6144)
.dinit 0xa190 0x38c 0x552 (1362)
.text 0xa51c 0x2da 0x447 (1095)
.text 0xa7f6 0x324 0x4b6 (1206)
.text 0xab1a 0x32 0x4b (75)
Total program memory used (bytes): 0xfddd (64989) 24%
.data 0x232a 0 0x6 (6)
.bss 0x2330 0 0x4 (4)
.data 0x2334 0 0x2 (2)
.data 0x233e 0 0x2 (2)
_01fb21504cf53c71 0x7f32 0 0xce (206)
Total data memory used (bytes): 0x1c0e (7182) 23%
heap 0 0 (0)
stack 0x2340 0x5bf2 (23538)
Maximum dynamic memory (bytes): 0x5bf2 (23538)
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-bin2hex.exe" "C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.cof"
Loaded C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.cof.
Debug build of project `C:\Users\SLUG\Documents\MATLAB\SLUG_Autopilot\Stable\controlMCUSlugsMKII.mcp' succeeded.
Tue Nov 30 11:03:45 2010
BUILD SUCCEEDED
Dan
Citation : LubinKerhuel Doesn't this mean that it compiled sucessfully?
Yes, very good news !
Citation : LubinKerhuel Theoretically, I should be able to compile in MATLAB till it breaks then open the mcp file to finish the hex compile right?
Yes. If I were in your shoes, I would (at least once) delete the two generated folder : slpjr and controlMCUSlugsMKII_dspic to make sure that matlab created new files. Then, if it compiles within MPLAB, it's all Ok.
I am just a bit frustrated as we did not find the problem that make the compiler not working when it is called from MATLAB !
Anyway, it's lucky that the automatic generation of the MPLAB project file has been added very recently !
I hope we'll have some in flight video soon ! Do not hesitate to embed youtube or vimeo video within this wiki website !
Citation : dambrosio There could be something wrong with the makefile that is being used by MATLAB to generate the hex file
That's correct ! There was something wrong with the makefile that does not work anymore with the latest Microchip linker pic30-ld (V3.25).
I could not have this tools working (with this version only as it works great with all previous version ) thus I replaced it by the pic30-gcc tools that call the linker in backend.
This solution is a bit tricky but seems Ok anyway.
Please let me know !
Hi Lubin, Mariano,
Were you able to compile the controlMCUSlugsMKII.mdl file w/ v3.4 of the blockset?
I am using r2010b, v3.4b of the blockset, and the 13d8c62 version of Mariano's awesome AP project. I was able to successfully compile the sensorMCUSlugsMKII.mdl file after adding four missing variables (baroTempK, baroMeanTemp, pitTempK, pitMeanTemp), but have not been able to compile the control model file.
The recurring error is shown below involving the reshape block. I tried removing the block and re-adding it from the r2010b math library, but I get the same error. Any thoughts?
Justin
Justin
Lubin,
I am trying to get the SLUG autopilot code to compile without having to do the "work around" in mplab could you give me a little more information on what you did in the following quote?
Dan
Dan
Hi Dan,
There are two ways to execute the linker :
- Either calling directly the linker executable: pic30-ld
- Neither calling the compiler with appropriate flags (compiler is pic30-gcc)
In one of the recent version I tested (3.25), I could not manage to get the linkerpic30-ld working properly. Thus, the blockset now use the other way to call the linker!
Which blockset version are you using?
I could provide you with the latest version which might solve the problem you are facing.
Hi guys,
I am working on UAV application and i wish to adopt the SLUG files WITH lubin BLOCKSETS. I real appreciate your discussion so far on this forum.
1. I will appreciate a brief guidelines on adoption of the SLUG .mdl first for sensors' data acquisition for flight data based on the experience already share on this forum
2. is the GPS codes generic for all gps module: am using EM-406A,
if it works for this GPS, what is the minimum c.codes to be included in order to use only the GPS function. I am planning to use other IMU through analog inputs into the simulink sensordata, So, I will want to remove other c. functions related to other sensors for now.
looking for to read from you. Let me know if additional info is required.
thanks
thanks
Much has happened in the past two or three years since this thread was originally created. SLUGS has been tested and fully developed, and Lubin now works @ Microchip, and stopped developing this blockset and now develops the official Microchip blockset (congrats on your position!).
So my question:
What modifications are needed to adapt SLUGS in its final form to work with the official Microchip blockset?
I am interested in this, and if someone can guide me I can perform this task and provide you with the result once finished.
So my question:
