C-function block can't inherit input vector dimensions
C-function block can’t inherit input vector dimensions
bmairs
I'm trying to pass the output of the xPC blockset Pack block into the C-function call block. The Pack block doesn't allow inheriting of its output signal dimensions and the C-function call block seems to require its dimensions to be specified. I've tried using -1 as the input vector size, but then the generated code passes a single integer (seemingly randomly generated) to that function when it's called.
I'd like to do this:
Pack Block -> C-Function call
(pack block outputs unspecified signal whose dimensions are determined when compiled) (the C-function call uses the dimension size passes by the input vector)
In my specific example I have a 28 element vector coming out of the Pack Block. When I pass that to the C-Function call which has -1 specified for the input dimension size the generated function call looks like this: "uart2EnqueueActuatorData(((uint8_T)37U));". It's not only passing it just one element when it should be 28, it seemingly made up some constant to actually pass the function. Very odd.
