Error
Error
sorell13
I tried to compile the first project from the video explanation on the website and I have the following error:
untitled_main.c: In function '_FICD':
untitled_main.c:41: error: syntax error before '{' token
gmake: *** [untitled_main.o] Error 255
### Real-Time Workshop build procedure for model: 'untitled' aborted due to an error.
I am using Matlab 2009b.
I attached to you the generated files and a printscreen of the error. can you help me with this?
Thank you for support
Sincerely yours,
Sorin
Pièce jointe : first example.zip
