Error when compiling
gar
We are getting the following error when we compile
Message: "Model Error"
Summary: "Real-Time workshop embedded coder is not licenced or not installed. The current target is C:\......\dspic.tlc"
and in the matlab command window it says....
"Warning: block diagram does not have a parameter called 'GMAKE_PLACE'"
"C30 Compiler Found"
"Real-Time Workshop build procedure for model: 'test_code' aborted due to an error."
What do you recommend???
Re: Error when compiling
Hi Ellis,
The error message may be incorrect.
Could you try to re-install both compiler C30 and C32 downloaded from the microchip website ?
Let me know if it changes anything
h_namazian66
hi Lbin
me too recieve an error when double click on configure block
it says system target file must be defined to dspic real time workshop (simulatio ==> ...)
plz help me i have a project must be done very soon
Could you post your model on the forum so as to see what is the problem ?
