probleme - Matlab Version
I have version 7.0.1 of Matlab. I installed your software but it does not work and when I built it, it answered me that :
"Error while evaluating the 'SelectCallback' in system target
file 'dspic.tlc'. Last recorded error message:
Property 'TargetLang' does not exist."
can you give me a version compatible with my Matlab's version?
thanks
thanks
Hi hamaoui,
There is some difference in the Real Time Workshop Embedded Coder Toolbox between Matlab 7.0.1 and Matlab 7.2 (R2006b). That is why you get this error.
It is quite a hard work to make the toolbox compatible with earlier matlab version. I am not planning to do it.
You should upgrade your matlab to an earlier release. (R2006a, R2006b and R2007a are currently fully supported)
Re: probleme - Matlab Version
why is there no "interface Tx Matlab" block in the dsPIC toolbox for matlab 2007b? Or can i just take the one from 2007a?
thanks
don
thanks
don
The block "Interface Tx-Matlab" is available in all the version of the toolbox.
Anyway, you could also start the user interface of this block by typing "rs232gui" at the matlab prompt.
