PORT D bug on DSPIC33FJ64(128)MC804
Hi Lubin and group,
I am new user for DSPIC and actually I am trying to use your very useful blockset (just downloaded it today).
However I have problems regarding the Digital Input. When I try to compile to DSPIC33FJ128MC804, the following error occurs:
dsPIC_33f_Explorer16.c:165: error: 'PORTDbits' undeclared (first use in this function)
Looking into the .h files, I could notice that DSPIC33FJ128MC804 does not present any definition for PORTDbits.
It seems that the digital Input for DSPIC33FJ128MC804 is made in a different way, but I am not quite sure about that.
However it seems that this is the only error so far.
Can you enlighten me here, please?
I imagine I can use the Analog Input as a digital Input, just by configuring it correctly. But then I guess if the Analog Input is also implemented for this specific DSPIC.
Thank you and regards,
Mikio
Mikio
Re: PORT D bug on DSPIC33FJ64(128)MC804
I checked 33fj MC804 definition either on microchip h file, and in the blockset, it's coherent.
Could you check you select the correct dsPIC in the master block ?
Check then that your simulink model does not contain any port D.
hello I am using 804 as well, I do not think there is any PORTD at all. at least I cant see any pin on the Pin Diagram.
Josef
Josef
Greetings all,
Thank you for your prompt reply.
Ok, my LACK of knowledge (or I shall say my dumbness and ignorance) is responsible for this mistake.
Actually dsPIC33fj64(128)MCx04 does NOT present any PORT D, but only PORT A, B or C.
Thank you again and sorry for bothering!
Regards,
Mikio
Regards,
Mikio
