QEI - changed target, stoped working
Bobes
I think, it is some trivial problem, but I can not find out where...
I have used the example from here: viewtopic.php?f=1&t=100&start=0&st=0&sk=t&sd=a#p266
When I compile as it is, it works fine, but when I change target to 33FJ128MC804 I start getting these errors:
D:\bobes\0 skola\_car4\my matlab\dsPIC33\QEI 5\QEITest2_dspic\sources>"C:\PROGRA~1\MATLAB\R2009a\bin\win32\gmake" -f QEITest2.mk  GENERATE_REPORT=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc  -c -mcpu=33fj128MC804 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2009a/simulink/include -IC:\PROGRA~1\MATLAB\R2009a/extern/include -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/src/ext_mode/common -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI5~1\QEITest2_dspic\sources -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI5~1 -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    QEITest2_data.c
''pic30-gcc  -c -mcpu=33fj128MC804 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2009a/simulink/include -IC:\PROGRA~1\MATLAB\R2009a/extern/include -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/src/ext_mode/common -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI5~1\QEITest2_dspic\sources -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI5~1 -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    QEITest2_main.c
''pic30-gcc  -c -mcpu=33fj128MC804 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2009a/simulink/include -IC:\PROGRA~1\MATLAB\R2009a/extern/include -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2009a/rtw/c/src/ext_mode/common -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI5~1\QEITest2_dspic\sources -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI5~1 -ID:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c: In function 'QEIInit':
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:5: error: 'QEI_INT_ENABLE' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:5: error: (Each undeclared identifier is reported only once
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:5: error: for each function it appears in.)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:6: error: 'QEI_INT_PRI_5' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:11: error: 'QEI_DIR_SEL_CNTRL' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:12: error: 'QEI_INT_CLK' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:13: error: 'QEI_INDEX_RESET_DISABLE' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:14: error: 'QEI_CLK_PRESCALE_1' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:15: error: 'QEI_GATED_ACC_DISABLE' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:16: error: 'QEI_NORMAL_IO' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:17: error: 'QEI_INPUTS_NOSWAP' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:18: error: 'QEI_MODE_x2_MATCH' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:19: error: 'QEI_UP_COUNT' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:20: error: 'QEI_IDLE_STOP' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:21: error: 'MATCH_INDEX_INPUT_PHASEA' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:22: error: 'QEI_QE_CLK_DIVIDE_1_16' undeclared (first use in this function)
D:\bobes\0SKOLA~1\_car4\MYMATL~1\dsPIC33\QEI6~1/QEI_Functions.c:23: error: 'QEI_QE_OUT_ENABLE' undeclared (first use in this function)
gmake: *** [QEI_Functions.o] Error 255
### Real-Time Workshop build procedure for model: 'QEITest2' aborted due to an error.
I have changed include in QEI_functions.c to #include <p33FJ128MC804.h>. It seems it does not find qei.h, but it is included, and it is in place (otherwise, it would not work in the first place - before changing the target)
void __attribute__((__interrupt__)) _QEI1Interrupt(void)
	extern volatile unsigned int ct_turns;
	// if it overflowed
	  if (ReadQEI() < 0x3FFF){
	    ct_turns++;
	  } else {
	    ct_turns--;
	 // clear the interrupt flag
	  IFS3bits.QEI1IF =0;
This is how I changed the Interrupt routine, I believe the problem may be, that the target I am using has 2 QEI. However I can´t find out why it does not take qei.h in consideration?
If someone has tryed using two QEI, or have an idea where I should look for a solution, please advice.
Kind regards
Josef
Re: QEI - changed target, stoped working
Hi Josef,
typically, chips that have 2 identical peripheral will have a peripheral ref in the peripheral configuration register, like QEI1 / QEI2.
You should have a look on the doc of the chip.
anyway, I did not has occasions to work on QEI peripheral. You may post your question after the forum thread you mentionned. Thus, "QEI developers" will get mails and you may get a more detailed response from them...
Bobes
Hello, we (actually my colleague did) have sorted out the problem, right now I am not exactly sure why it did not work, I hope I will have some time to make some report on that and publish it here, just not sure when yet.
I did correct the QEI numbering before I posted here.... and that works now. However I have still to modify the c-function to work for two QEI... that will take some time as it is not my priority.
