erreur
erreur
bonjour monsieur
quand j'essaye d'executer le programme servo_ADC il engendre l'erreur suivante: build genmake1138
voila une copie de mon erreur sur matlab
merci pour votre comprhénsion
Warning: dsPICdrivers.mdl, line 48: block_diagram does not have a parameter named
'CovForceBlockReductionOff'.
In open at 153
In uiopen at 196
Warning: dsPICdrivers.mdl, line 54: block_diagram does not have a parameter named
'CovExternalEMLEnable'.
In open at 153
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==>
dsPIC_ConfigRTWOption at 107
The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==>
Configuration Parameters ==> Real Time workshop.
> In C:\Documents and Settings\Administrateur\Bureau\install dspic\blocks\dsPIC_UART_TX_Labview_Matlab_callback.p>dsPIC_UART_TX_Labview_Matlab_callback at 36
In open at 153
In uiopen at 196
Warning: In instantiating linked block 'Servo_ADC_filter/ADC Input' : Invalid setting in dsPIC :
ADC10 block (mask) 'ADC Input' for parameter 'OutFormatBitspopup'.
In open at 153
In uiopen at 196
PTC30 Compiler found
### Starting Real-Time Workshop build procedure for model: Servo_ADC_filter
### Generating code into build directory: C:\Documents and Settings\Administrateur\Bureau\examples\Servo_ADC_filter_dspic\sources
PPNumber of I/O PINs used : 4
TPTPTTPNumber of I/O PINs used : 4
TTTPTPTPTTPNumber of I/O PINs used : 4
TPTWarning: Source 'Servo_ADC_filter/ADC Input' specifies that its sample time (-1) is
back-inherited. You should explicitly specify the sample time of sources. You can disable this
diagnostic by setting the 'Source block specifies -1 sample time' diagnostic to 'none' in the
Sample Time group on the Diagnostics pane of the Configuration Parameters dialog box.
Warning: Parameter precision loss occurred for 'Value'. The parameter's value cannot be
represented exactly using the run-time data type. A small quantization error has occurred. You
can control this diagnostic on the Diagnostics pane of the Configuration Parameters dialog. This
originated from 'Servo_ADC_filter/Constant1'.
Warning: Parameter precision loss occurred for 'Gain'. The parameter's value cannot be
originated from 'Servo_ADC_filter/Gain'.
### Invoking Target Language Compiler on Servo_ADC_filter.rtw
C:\Documents and Settings\Administrateur\Bureau\examples\Servo_ADC_filter_dspic\sources\Servo_ADC_filter.rtw
C:\Documents and Settings\Administrateur\Bureau\install dspic\dspic\dspic.tlc
-OC:\Documents and Settings\Administrateur\Bureau\examples\Servo_ADC_filter_dspic\sources
-IC:\Documents and Settings\Administrateur\Bureau\install dspic\dspic
-IC:\Documents and Settings\Administrateur\Bureau\install dspic\blocks
-IC:\Documents and Settings\Administrateur\Bureau\examples\Servo_ADC_filter_dspic\sources\tlc
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\mw
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\lib
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\blocks
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\fixpt
-IC:\Program Files\MATLAB\R2008a\stateflow\c\tlc
-aInlineInvariantSignals=0
-aInlineParameters=0
-aInitFltsAndDblsToZero=1
-aGenerateTraceInfo=0
-aTargetFcnLib="ansi_tfl_tmw.mat"
-aSuppressErrorStatus=1
-aPortableWordSizes=0
-aGMAKE_PLACE="C:\PROGRA~1\MATLAB\R2006a\rtw\bin\win32\gmake"
-aOPTIM_GCC="-mcpu=30f3012 -O3 -fschedule-insns -fschedule-insns2"
-aLDFLAGS="-t --report-mem -Map ../untitled.map --heap 0 -cref"
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~1\support\dsPIC30F\gld\p30f3012.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\dsPIC30F\libp30f3012-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a"
-aPIC_INCLUDES="-I C:\PROGRA~1\MICROC~1\MPLABC~1\include"
-aPIC_REF="30f3012"
-aGCCPATH=""
### Writing header file Servo_ADC_filter_types.h
### Writing header file Servo_ADC_filter.h
### Writing source file Servo_ADC_filter.c
### Writing header file Servo_ADC_filter_private.h
### Writing source file Servo_ADC_filter_data.c
### Writing source file Servo_ADC_filter_main.c
Embedded Coder for dsPIC V3.1(17-Nov-2009) for Matlab R2009a.
Licence Accorded to Demonstration Version
[adresse e-mail retirée]
Author : Lubin KERHUEL
WEBSITE : http://www.kerhuel.eu/wiki
SIRENE : 503 920 456
SIRET : 503 920 456 00012
Facturation to : Demo
Demo
Lubin KERHUEL
18 avenue Joseph Lieutaud
13260 Cassis
FRANCE
Check updates and new informations at : www.kerhuel.eu
### Processing Template Makefile: C:\Documents and Settings\Administrateur\Bureau\install dspic\dspic\dspic_pic30_gcc.tmf
### Servo_ADC_filter.mk which is generated from C:\Documents and Settings\Administrateur\Bureau\install dspic\dspic\dspic_pic30_gcc.tmf is up to date
### Building Servo_ADC_filter: .\Servo_ADC_filter.bat
C:\Documents and Settings\Administrateur\Bureau\examples\Servo_ADC_filter_dspic\sources>set MATLAB=C:\Program Files\MATLAB\R2008a
C:\Documents and Settings\Administrateur\Bureau\examples\Servo_ADC_filter_dspic\sources>"C:\PROGRA~1\MATLAB\R2006a\rtw\bin\win32\gmake" -f Servo_ADC_filter.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
Le chemin d'accŠs sp‚cifi‚ est introuvable.
### Real-Time Workshop build procedure for model: 'Servo_ADC_filter' aborted due to an error.
In open at 153
In uiopen at 196
In open at 153
In uiopen at 196
In open at 153
In uiopen at 196
In open at 153
In uiopen at 196
-aPIC_REF="30f3012"
-aGCCPATH=""
Demo
Lubin KERHUEL
13260 Cassis
FRANCE
Re: erreur
essayer de cliquer, avant de compiler sur un block jaune qui permet de configurer le modèle, et corrige les chemins d'accés aux fichiers/compilateurs...
Re: erreur
bonjour j'ai changé et voila ce qu'il m'ecrit:
pouvez vous m'aider SVP
### Generating code into build directory: C:\Documents and Settings\Administrateur\Bureau\Servo_ADC_filter_dspic\sources
TTPTPTWarning: Source 'Servo_ADC_filter/ADC Input' specifies that its sample time (-1) is back-inherited. You should explicitly specify the sample time of
sources. You can disable this diagnostic by setting the 'Source block specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the
Warning: Parameter precision loss occurred for 'Value'. The parameter's value cannot be represented exactly using the run-time data type. A small
quantization error has occurred. You can control this diagnostic on the Diagnostics pane of the Configuration Parameters dialog. This originated from
Warning: Parameter precision loss occurred for 'Gain'. The parameter's value cannot be represented exactly using the run-time data type. A small
C:\Documents and Settings\Administrateur\Bureau\Servo_ADC_filter_dspic\sources\Servo_ADC_filter.rtw
C:\Documents and Settings\Administrateur\Bureau\dspic\dspic.tlc
-OC:\Documents and Settings\Administrateur\Bureau\Servo_ADC_filter_dspic\sources
-IC:\Documents and Settings\Administrateur\Bureau\dspic
-IC:\Documents and Settings\Administrateur\Bureau\blocks
-IC:\Documents and Settings\Administrateur\Bureau\Servo_ADC_filter_dspic\sources\tlc
-aEnforceIntegerDowncast=0
-aInlineInvariantSignals=1
-aInlineParameters=1
-aZeroInternalMemoryAtStartup=0
-aZeroExternalMemoryAtStartup=0
-aInitFltsAndDblsToZero=0
-aGMAKE_PLACE="C:\Program Files\MATLAB\R2008a\bin\win32\gmake"
-aLDPICTYPE="C:\Program Files\Microchip\MPLAB C30\support\dsPIC30F\gld\p30f3012.gld"
-aLDLIBPIC="C:\Program Files\Microchip\MPLAB C30\lib\libpic30-coff.a C:\Program Files\Microchip\MPLAB C30\lib\libp30f3012-coff.a C:\Program Files\Microchip\MPLAB C30\lib\libc-coff.a C:\Program Files\Microchip\MPLAB C30\lib\libm-coff.a"
-aPIC_INCLUDES="C:\Program Files\Microchip\MPLAB C30\include"
-aPIC_REF="30f3012"
-aGCCPATH="'C:\Program Files\Microchip\MPLAB C30\bin\\'"
### Writing code interface description file codeInfo.mat
Embedded Coder for dsPIC V3.0b(02-Oct-2009) for Matlab R2008a.
Demo
Lubin KERHUEL
13260 Cassis
FRANCE
### Processing Template Makefile: C:\Documents and Settings\Administrateur\Bureau\dspic\dspic_pic30_gcc.tmf
### Creating Servo_ADC_filter.mk from C:\Documents and Settings\Administrateur\Bureau\dspic\dspic_pic30_gcc.tmf
C:\Documents and Settings\Administrateur\Bureau\Servo_ADC_filter_dspic\sources>set MATLAB=C:\Program Files\MATLAB\R2008a
C:\Documents and Settings\Administrateur\Bureau\Servo_ADC_filter_dspic\sources>"C:\Program Files\MATLAB\R2008a\bin\win32\gmake" -f Servo_ADC_filter.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
C:\Program Files\Microchip\MPLAB C30\bin\\pic30-gcc -c -mcpu=30f3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2008a/simulink/include -IC:\PROGRA~1\MATLAB\R2008a/extern/include -IC:\PROGRA~1\MATLAB\R2008a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2008a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2008a/rtw/c/src/ext_mode/common -IC:\DOCUME~1\ADMINI~1\Bureau\SERVO_~1\sources -IC:\DOCUME~1\ADMINI~1\Bureau -IC:\PROGRA~1\MATLAB\R2008a\rtw\c\libsrc C:\Program Files\Microchip\MPLAB C30\include Servo_ADC_filter_main.c
pic30-coff-gcc: C:\Program: No such file or directory
pic30-coff-gcc: Files\Microchip\MPLAB: No such file or directory
pic30-coff-gcc: C30\include: No such file or directory
gmake: *** [Servo_ADC_filter_main.o] Error 255
-aPIC_REF="30f3012"
Demo
Lubin KERHUEL
13260 Cassis
FRANCE
