Syntax error in compilation
Beni
Hi!
I have an compilation error when try to build the examples:
### Invoking Target Language Compiler on ledsample.rtw
	C:\0beni\matlabwork\ledsample_dspic\sources\ledsample.rtw
	C:\0beni\matlabwork\dspic\dspic.tlc
	-OC:\0beni\matlabwork\ledsample_dspic\sources
	-IC:\0beni\matlabwork\dspic
	-IC:\0beni\matlabwork\blocks
	-IC:\0beni\matlabwork\ledsample_dspic\sources\tlc
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\mw
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\lib
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\blocks
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\fixpt
	-IC:\0beni\Programok\MATLAB\R2006a\stateflow\c\tlc
	-aInlineInvariantSignals=0
	-aInlineParameters=0
	-aIgnoreCustomStorageClasses=1
	-aPrefixModelToSubsysFcnNames=1
	-aTargetFcnLib="ansi_tfl_tmw.mat"
	-aCombineOutputUpdateFcns=0
	-aSuppressErrorStatus=0
	-aERTCustomFileBanners=0
	-aGMAKE_PLACE="C:\0beni\Programok\MATLAB\R2006a\rtw\bin\win32\gmake"
	-aOPTIM_GCC="-mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -fno-short-double"
	-aLDFLAGS="-t --report-mem -Map ../untitled.map --heap 0  -cref"
	-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~1\support\dsPIC30F\gld\p30f4013.gld"
	-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a  C:\PROGRA~1\MICROC~1\MPLABC~1\lib\dsPIC30F\libp30f4013-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a"
	-aPIC_INCLUDES="-I C:\PROGRA~1\MICROC~1\MPLABC~1\include"
	-aPIC_REF="30f4013"
	-aGCCPATH=""
Error: File: execstring Line: 1 Column: 23
Unterminated string
Error: File: execstring Line: 1 Column: 26
syntax error
I figured out that \ should be \\ and between the " " there should be no whitespace or it's a syntax error..
i use matlab r2006. Where can I set the optim_gcc and the other parameters, or how can i solve that problem?
regards,
Beni
Beni
Re: Syntax error in compilation
Hi!
Ok I found the solution:
I have to set at
Simulation ==> Configuration Parameters.. ==> Real-Time Workshop ==> DsPIC options
the path variables / to //
ex.:
C:\Programs\MATLAB\R2006a\rtw\bin\win32\gmake
change to:
C:\\Programs\\MATLAB\\R2006a\\rtw\\bin\\win32\\gmake
and it complies well.
regards,
Beni
