remappable Pin
remappable Pin
Hi Lumbin,
I need to select the I/O, so to configure the UART function on some Pins of a 33FJ128GP804.
I plan to use a C call function, called one time, to initialize the I/O mapping MUX.
Before to start I would appreciate to know, if you have a better/other way or a small exemple ?
Thank you.
Thank you.
Re: remappable Pin
Hi Ender,
There is a port mapping block to do it. It is not described on the wiki, but it is in the blockset anyway.
Re: remappable Pin
Yes, this seemed strange, because easy and interesting for your blockset Lumbin, so I guessed that you had done something like that yet, but I had never see this blockset before.
Thanks, great job it works fine in my project. :D
