Compilation error. Please help.
gksinghal
I am using Matlab 2008b, C30 COMPILER, DSPic 30f2012. I have all required toolboxes installed. I run into error when I try to compile the simulink blocks. The simulink block has the dsPIC Master block, UART config block and Tx block.
Thanks in advance
Girish
Error: File: C:\LOCAL\Motor Control\Simulink\Blocksets\blocks\dsPIC_MASTER.tlc Line: 106 Column: 62
The specified index (2) was out of the range 0 - 1
The specified index (3) was out of the range 0 - 1
The specified index (4) was out of the range 0 - 1
The specified index (5) was out of the range 0 - 1
### Real-Time Workshop build procedure for model: 'project1' aborted due to an error.
Re: Compilation error. Please help.
Dear Girish,
I will probably not be available for the next three day.
Anyway, could you try to compile one of the example in the example repertory ?
On your model, Check that you selected one microcontroller in the Master block configuration
Then, if you still get in trouble, could you post your model on this forum ? I'll try to look at that.
