C function call block
Hi you all!
Hello Lubin:
I am trying to understand how the C call function block works but I am stuck. I have just tried to read a variable "data" and put it out . I compare it with a constant and set a port bit if it is greater or iqual. I have attached the C function also. After I compile it I get this error:
callf4.o(.text+0x0):C:\Documents and Settings\123\Mis documentos\MATLAB\call4_dspic\sources\..\..\callf4.c: Link Error: Cannot access symbol (_data) at an odd address.
C:\Program Files\Microchip\MPLAB C30\bin\bin/pic30-coff-ld.exe: link errors found, deleting executable `..\../call4.coff'
gmake: *** [..\../call4.coff] Error 0xff
### Real-Time Workshop build procedure for model: 'call4' aborted due to an error.
I was trying to attach the .mdl file and the .c function but I do not know how to attach the files.
Can you explain me how to attach files?
Can you tell me what am I doing wrong?
Jose Luis
Hello Lubin:
Jose Luis
Re: C function call block
Citation : Simon_says Can you explain me how to attach files?
Hi Jose Luis,
To attach files on this forum, just look below the Save - Preview - Submit buttons, there is a tab : "upload attachement".
It will help to see the model.
Hi Lubin..
Here are the .mdl and .c files. I am just trying to turn a pair of leds when the ADC reads more than 2.5V or less than 1.5V. I wanted to use the C function call in order to lear how to use it. I decided to use the example format you posted and it compiles succesfully. However, I program the dsPIC30f4012 and it just turns led RD1 on. That´s all it does. No response to ADC input...nothing. Just RD1 on.
Can you suggest me please?
Thanks a lot!
I was trying to see the C call function output with the matlab scope, but there is no output... Is it posible to simulate and check the performance before program the dsPIC?
Jose Luis
Thanks a lot!
Jose Luis
Dear Joze Luis,
No, C function block will have no behaviour in a simulation. (Like all others blocks from the dsPIC library)
I had a quick glande on your model.
Sample time are Ok for every blocks ; thanks ! (It's a common source of error)
I noticed a datatype error in the C file that make the condition (<= 256) always true and the condition ( >= 512) false !
should be :
Be aware that a global variable called Input is declared by the simulink model. You also use a variable named Input inside your function (That may cause trouble). You may considere to rename this variable either in your C function file or in the simulink model file or just directly connect ADC to C function Call.
It should works ! However, I did not tested on the dsPIC. Let us know !
Citation : Simon_says Is it posible to simulate [C function block] before program the dsPIC?
</i>#include <p30f4012.h>
unsigned char call6(unsigned char Input)
unsigned char Temp;
Temp = (Input);
return Temp;
should be :
unsigned int call6(unsigned int Inputtt)
unsigned int Temp;
Temp = (Inputtt);
return Temp;
Hi Lubin.. Sorry for the delay of my response...
Happy new year to all of you! This season I did not work at all, but now I have tested the model and I can see what my mistakes were. It works as you suggested!!! I have implemented it in a dsPIC and it is working. Thanks a lot. I am continuing experimenting and learning. I´ll get back to you again soon.
Jose Luis
Jose Luis
