DAC on 33fj64GP802
DAC on 33fj64GP802
16 message(s) · archive en lecture seule
Is there any block "DAC" (digital analog converter) for the 33fj64GP802 in the simulink dspic library ?
Lucien
Lucien
Re: DAC on 33fj64GP802
Hi Lucien,
DAC peripheral is not yet available.
Considere using the C function call to build your own function.
I wonder if you are intend to build a dac peripheral for the 33fj64(128)GP802.
Casparus
Casparus
Hi Casparus,
This is not planned yet. However, if you want to give it a try and publish results, I can provide you with a blockset with C function call avaialble.
That should be very agreeable.
Of course, I shall publish the trials and results.
Casparus
Casparus
I'm very always interesting for a dac peripheral for the 33fj64(128)GP802.
Lucien
Lucien
Hi Lucien, I can propose the same solution than crh (No time to have a look by myself by right-now)
LubinKerhuel</em>">
Let me know
LubinKerhuel</em>">
Citation : <em>LubinKerhuel</em> if you want to give it a try and publish results, I can provide you with a blockset with C function call avaialble.
Let me know
Yes I'm interesting for a C call blockset. As soon as the DAC peripherical is finished, of course I will publish the results.
Lucien
Lucien
My C30 code does working now for the DAc peripherical on dspic33fj64gp802.
But now I must integrate it in Matlab Simulink !
Here is my complete C30 code:
#include "p33FJ64GP802.h"
#include "dsp.h"
long i,j,k;
long mydataright,mydataleft;
int const sinus[60]={10,500,500,150,10,500,10,10,150,500,
500,10,350,500,10,10,10,350,500,500,
10,10,10,10,150,150,150,150,150,150,
350,350,350,350,500,500,500,500,500,500,
500,150,350,10,10,350,150,500,10,150,
150,350,10,500,500,10,150,350,10,10};
int const cosinus[60]={150,10,350,500,150,10,10,350,500,500,
10,150,10,500,10,350,10,500,10,150,
10,150,350,500,10,150,350,500,500,150,
500,350,150,10,10,150,350,500,10,10,
10,10,10,10,150,150,150,150,10,500,
500,500,500,500,350,350,350,10,150};
void __attribute__((interrupt,no_auto_psv))_DAC1RInterrupt(void);
void __attribute__((interrupt,no_auto_psv))_DAC1LInterrupt(void);
void initDAC();
void __attribute__((interrupt,no_auto_psv)) _DAC1RInterrupt(void)
IFS4bits.DAC1RIF = 0; /* Clear Right Channel Interrupt Flag */
DAC1RDAT = mydataright; /* User Code to Write to FIFO Goes Here */
void __attribute__((interrupt, no_auto_psv)) _DAC1LInterrupt(void)
IFS4bits.DAC1LIF = 0; /* Clear Right Channel Interrupt Flag */
DAC1LDAT = mydataleft; /* User Code to Write to FIFO Goes Here */
void initDAC()
ACLKCONbits.SELACLK=0;
ACLKCONbits.AOSCMD=0;
ACLKCONbits.ASRCSEL=0;
ACLKCONbits.APSTSCLR=7; //divide clock by 8
DAC1STATbits.ROEN = 1; /* Right Channel DAC Output Enabled */
DAC1STATbits.LOEN = 1; /* Right Channel DAC Output Enabled */
DAC1STATbits.RITYPE = 0; /* Right Channel Interrupt if FIFO is not Full */
DAC1STATbits.LITYPE = 0; /* Right Channel Interrupt if FIFO is not Full */
DAC1CONbits.AMPON = 0; /* Amplifier Disabled During Sleep and Idle Modes */
DAC1CONbits.DACFDIV = 5; /* Divide Clock by 100 (Assumes Clock is 25.6MHz) */
//PLLCLK=80MHZ ; ACLK=10MHz ; DACCLK=100kHz
DAC1CONbits.FORM = 0; /* Data Format is unsigned integer */
DAC1DFLT = 0x8000; /* Default value set to Midpoint when FORM = 0 */
IEC4bits.DAC1RIE = 1; /* Right Channel Interrupt Enabled */
IEC4bits.DAC1LIE = 1; /* Right Channel Interrupt Enabled */
DAC1CONbits.DACEN = 1; /* DAC1 Module Enabled */
long writeDACdataR(void)
mydataright=128*sinus[i];
mydataleft=128*cosinus[i];
// Internal FRC Oscillator
_FOSCSEL(FNOSC_FRC); // FRC Oscillator
_FOSC(FCKSM_CSECMD & OSCIOFNC_ON & POSCMD_NONE);
//_FOSC(FCKSM_CSECMD);
_FWDT(FWDTEN_OFF); // Watchdog Timer Enabled/disabled by user software
// (LPRC can be disabled by clearing SWDTEN bit in RCON register
int main(void)
/* Configure Oscillator to operate the device at 40Mhz
Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
Fosc= 7.37*M*43/(2*2)=80Mhz for 7.37M internal FRC */
PLLFBD=42; /* M=43 */
CLKDIVbits.PLLPOST=0; /* N1=2 */
CLKDIVbits.PLLPRE=0; /* N2=2 */
OSCTUN=23; /* Tune FRC oscillator, if FRC is used */
/* Disable Watch Dog Timer */
RCONbits.SWDTEN=0;
/* Clock switch to incorporate PLL*/
__builtin_write_OSCCONH(0x01); // Initiate Clock Switch to FRC
// Oscillator with PLL (NOSC=0b001)
__builtin_write_OSCCONL(0x01); // Start clock switching
while (OSCCONbits.COSC != 0b001); // Wait for Clock switch to occur
/* Wait for PLL to lock */
while(OSCCONbits.LOCK!=1);
//OSCCONbits.LPOSCEN=0;
CLKDIVbits.DOZE=0b000;
CLKDIVbits.FRCDIV=0b000;
// Initiate Clock Switch to FRC oscillator with PLL (NOSC=0b001)
initDAC();
i=1;
k=0;
for(;;)
while (j<400)
j=j+1;
j=0;
i=i+1;
writeDACdataR();
if (i>60)
i=0;
} Re: DAC on 33fj64GP802
Hi Lucien, Do you have a blockst version with the C call function unrestricted ?
If not, send me an email with the matlab version you are using, I'll provide you with that.
Hi Lucien, did you figure out how the block of DAC for 33fj128GP802? I am working on a project and that will be very helpful to me. Thanks
can you show me what is inside your header dsp.h ?
How do you define your dsPIC ?
I am interested in the C library calls the module. As long as the DAC peripherical is finished, of course, I will publish the results. ...
It is learned from school physics, that an analog-to-digital converter is a device that converts a continuous physical quantity (usually voltage) to a digital number that represents the quantity's amplitude. It needs operating range as 40 MIPS and a high performance DSC CPU.
http://www.snoringaidsnow.org
