Matlab 64 bits - Starter Kit for dsPIC
Ckouna
I'm a student in Troyes and I'd like to know if your toolbox works with the new Starter kit from Microchip.
The Debugger is a PIC : 18F67J50 and the DSPic is a 33FJ256GP506. It's designed only for audio applications with a mic/line in jack, and a speaker out jack.
I don't know many things about dsPIC but I have a project at the university with a teacher, to create a simple filtering application with this Starter Kit or the Explorer 16 board.
I think you speak french, but I'll try keeping typing english as it might increase my knowledges of technical english.
EDIT : Does the toolbox work with R2008a 64bits ? I can't even compile the example for the Explorer 16.
Ckouna
Re: Starter Kit for dsPIC
Heres the error I get when I try to compile the dsPIC_33f_Explorer16 example program :
I clik on the incremental build after the yellow block.
Error using ==> tlc c at 133
Error evaluating IntiFCn callback of Master block ... Error using dsPIC_PortSetting at 416
Error in S-function dsPic ... S-Function 'dsPIC_MASTER' does not exist
If anyone knows what's wrong with how I'm doing things ... Help would be great .
Hi Ckouna,
Citation : Ckouna
The blockset has not been tested on 64 bits matlab. It seems that matlab 64 bits cannot execute 32 bits mex files.
Thus, install a 32 bits matalb on your 64bit Winows and it will work properly.
How many are interrested by a 64 bits version of the blockset ? Let me know !
Ckouna
Thanks for the quick answer, I'm not sure I have the choice to install it in 32 bit but I'll try that.
