fuzzy in dspic 30f4011
macroevil
hi ....great job !!!! :D
i have a problem....i'm trying to make a control based in fuzzy logic but the compiler says
"Warning: A terminate function is necessary, however the Real-Time Workshop build process did not generate a terminate function because the 'Terminate function required' check box is cleared."
the fuzzy block is to simple...one input one output......and bisector dezufication....
i dont' know what to do...can you help me.....
..thanks..
Re: fuzzy in dspic 30f4011
Something is wrong in the configuration of you simulink model.
You could try to make a new model model starting from an example model file in the directory example (then copy-past your blocks).
If it did not solve the problem, upload your model on the forum.
macroevil
too fast your answer......thanks
the model is to simple...only for test fuzzy in dspic....
There is this model of the attached file..
Pièce jointe : prueba_1_adcTors232.mdl
I obtain a datatype error. Most (or all) blockset from the fuzzy logic can only take floating point variables.
Btw, I don't think that you will get an efficient using blocks that compute trigonometric or exponential like function... You may replace the buzzy logic blocks with optimized look up table.
macroevil
mr lubin.
thaks..but i still trying make a control with fuzzy in a dspic, it's work but ony in some cases, when i configure the FIS with only one input and one output, and two rules(mamdani method).....
do you have any example using FIS with mamdani metho..???
thanks a lot......this toolbox it's a great job congratulations...!!
att:
César Jiménez
Hi César,
I do not have any example using fuzzy logic or "FIS".
