Build error
Build error
I get this error when trying to build the block..
can you tell me what i have to do..
Im running a Matlab r2008a and Mplab8.01
running a c30 compliler student version 2.05
P
T
Model configured...
P
T
P
Number of I/O PINs used : 1
T
P
T
P
T
P
T
P
T
### Starting Real-Time Workshop build procedure for model: let
### Generating code into build directory: C:\Documents and Settings\Barry\My Documents\MATLAB\let_dspic\sources
P
T
P
T
P
T
P
T
P
T
Warning: Output port 1 of 'let/Digital Output Write' is not connected.
### Invoking Target Language Compiler on let.rtw
C:\Documents and Settings\Barry\My Documents\MATLAB\let_dspic\sources\let.rtw
C:\Documents and Settings\Barry\My Documents\MATLAB\dspic\dspic.tlc
-OC:\Documents and Settings\Barry\My Documents\MATLAB\let_dspic\sources
-IC:\Documents and Settings\Barry\My Documents\MATLAB\dspic
-IC:\Documents and Settings\Barry\My Documents\MATLAB\blocks
-IC:\Documents and Settings\Barry\My Documents\MATLAB\let_dspic\sources\tlc
-ID:\MATLAB\R2008a\rtw\c\tlc\mw
-ID:\MATLAB\R2008a\rtw\c\tlc\lib
-ID:\MATLAB\R2008a\rtw\c\tlc\blocks
-ID:\MATLAB\R2008a\rtw\c\tlc\fixpt
-ID:\MATLAB\R2008a\stateflow\c\tlc
-aInlineInvariantSignals=0
-aInlineParameters=0
-aGenerateTraceInfo=0
-aSuppressErrorStatus=1
-aPortableWordSizes=0
-aGMAKE_PLACE="D:\MATLAB\R2008a\bin\win32\gmake"
-aOPTIM_GCC="-mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -fno-short-double"
-aLDFLAGS="-t --report-mem -Map ../untitled.map --heap 0 -cref"
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~2\support\dsPIC30F\gld\p30f4013.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC30F\libp30f4013-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a"
-aPIC_INCLUDES="-I C:\PROGRA~1\MICROC~1\MPLABC~2\include"
-aPIC_REF="30f4013"
-aGCCPATH=""
### Writing header file let_types.h
### Writing header file let.h
### Writing source file let.c
### Writing header file let_private.h
### Writing source file let_data.c
### Writing source file let_main.c
Embedded Coder for dsPIC V0.98fe(16-Sep-2008) for Matlab R2008a.
Licence Accorded to Demo
[adresse e-mail retirée]
Author : Lubin KERHUEL
WEBSITE : http://www.kerhuel.eu
SIRENE : 503 920 456
Facturation to :
SIRET : 503 920 456 00012
Check updates and new informations at : http://www.kerhuel.eu
### Processing Template Makefile: C:\Documents and Settings\Barry\My Documents\MATLAB\dspic\dspic_pic30_gcc.tmf
### Wrapping unrecognized make command (angle brackets added)
### <D:\MATLAB\R2008a\bin\win32\gmake>
### in default batch file
### Creating let.mk from C:\Documents and Settings\Barry\My Documents\MATLAB\dspic\dspic_pic30_gcc.tmf
### Building let: .\let.bat
C:\Documents and Settings\Barry\My Documents\MATLAB\let_dspic\sources>set MATLAB=D:\MATLAB\R2008a
C:\Documents and Settings\Barry\My Documents\MATLAB\let_dspic\sources>D:\MATLAB\R2008a\bin\win32\gmake -f let.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc -c -mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -ID:\MATLAB\R2008a/simulink/include -ID:\MATLAB\R2008a/extern/include -ID:\MATLAB\R2008a/rtw/c/src -ID:\MATLAB\R2008a/rtw/c/ert -ID:\MATLAB\R2008a/rtw/c/src/ext_mode/common -IC:\DOCUME~1\Barry\MYDOCU~1\MATLAB\LET_DS~1\sources -IC:\DOCUME~1\Barry\MYDOCU~1\MATLAB -ID:\MATLAB\R2008a\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include let_data.c
''pic30-gcc -c -mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -ID:\MATLAB\R2008a/simulink/include -ID:\MATLAB\R2008a/extern/include -ID:\MATLAB\R2008a/rtw/c/src -ID:\MATLAB\R2008a/rtw/c/ert -ID:\MATLAB\R2008a/rtw/c/src/ext_mode/common -IC:\DOCUME~1\Barry\MYDOCU~1\MATLAB\LET_DS~1\sources -IC:\DOCUME~1\Barry\MYDOCU~1\MATLAB -ID:\MATLAB\R2008a\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include let_main.c
''pic30-gcc -c -mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -ID:\MATLAB\R2008a/simulink/include -ID:\MATLAB\R2008a/extern/include -ID:\MATLAB\R2008a/rtw/c/src -ID:\MATLAB\R2008a/rtw/c/ert -ID:\MATLAB\R2008a/rtw/c/src/ext_mode/common -IC:\DOCUME~1\Barry\MYDOCU~1\MATLAB\LET_DS~1\sources -IC:\DOCUME~1\Barry\MYDOCU~1\MATLAB -ID:\MATLAB\R2008a\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include let.c
''pic30-ld -t --report-mem -Map ../untitled.map --heap 0 -cref -T C:\PROGRA~1\MICROC~1\MPLABC~2\support\dsPIC30F\gld\p30f4013.gld -o ..\../let.coff let_data.o let_main.o let.o C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC30F\libp30f4013-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a
C:\Program Files\Microchip\MPLAB C30\bin\pic30-coff-ld.exe: cannot open linker script file C:\PROGRA~1\MICROC~1\MPLABC~2\support\dsPIC30F\gld\p30f4013.gld: No such file or directory
gmake: *** [..\../let.coff] Error 255
### Real-Time Workshop build procedure for model: 'let' aborted due to an error.
C30 Compiler found Re: Build error
You must update your C30 compiler to version (3.10b or 3.11b) (student version is also Ok)
See requirements http://www.kerhuel.eu/wiki/Download#Requirement
