Configuring in a sub-system
I want to use a fixed configuration hidden from ordinary users,
so hiding it inside a masked sub-system makes sense. However,
the resulting <model>_main.c tries to include the generated
headers from the sub-system, as
<model>/<subsystem name>.h and <model>/<subsystem name>_private.h
instead of
<model>.h and <model>_private.h
as expected (and as actually generated).
At present only the Compiler Configuration and Master blocks
are hidden in this way: I think it is the Master block which is
causing trouble. The other generated files do not have the problem.
RTWGenSettings.MyModelName
for my model is "ALT_WINDOW_SIM/Target Board Setup"
and presumably gives the same result everywhere in the model.
The string _private.h is only present in the *.tlc files as a suffix to
%<MyModelName>, which in turn is always defined as
CAST("String",RTWGenSettings.MyModelName)
It seems to me that the definition of MyModelName is an attempt
to second-guess just what RTW actually generates, and in this
case gets it wrong, unless the Master block is in the root of the
model.
There is an obvious work-around - just keep the Master block
in the root of the model - but is there any chance of changing
this behaviour? The comments associate with the definition of
MyModelName suggests that this is really a rather hard problem!
Bernard Leak.
instead of
model.
Bernard Leak.
Re: Configuring in a sub-system
Hi Bernard,
Thanks for the bug report. It is corrected.
The correction will be available in the next release (current release is 0.98fc)
