Matlab Variables do not Propagate to C-Function Call Block
malife
I am currently working on 0.98d so maybe you already fixed that in the latest version (which I hope you'll send it to me when you get back from vacations :-) )
But the issue is the following. I have a matlab script that initializes different variables most of it related to sizes and locations of signals. For instance I have a MAX_POSSIBLE variable that determines the maximum amount of bytes I can receive between sample times in the interrupt driven UART. If I configure that value using the variable (instead of just the number) in the C-function call dialog, for instance, for the input size. It will not recognize it; furthermore if I try to compile it says that it can not convert "" to an integer.
Hope this is a simple one to fix. Certainly it is not a show-stopper since I can just put the number manually, but it is convenient that if I change something (like baud rate) all the sizes get reconfigured by reading those variables.
Re: Matlab Variables do not Propagate to C-Function Call Block
Ok, Will have a look on that.
Thanks for the bug report !
Hi Mariano,
It seems to be quite complicated to modify the blockset.
Anyway, there may be a way to do what you wants :
replace : YoutVariable by ['[' num2str(YourVariable) ']'] in the dialog box.
I should work for all blocks.
