Support for dsPIC30F6014A ?
Hellon Lubin,
Recently, I've got a demo board with dsPIC30F6014A for compensator design. Your toolbox, it seems support 6014only,is it compatible with 6014A? If not,can you add the function for that? Thanks very much!
Cheers
gladiac
Cheers
gladiac
Re: Support for dsPIC30F6014A ?
Hi Gladiac,
dsPIC30F6014 and dsPIC30F6014A should be compatible.
I guess that dsPIC30F6014A is a revised version of the dsPIC30F6014 microcontroller with few correction.
I may add the dsPIC30F6014A pic to the blockset, but is it necessary ? (C program would use different library and definition file, but they may be very similar...)
Let me know if you encounter any problem and if adding the A version may solve them...
