does not appear Interface tx-Matlab
Hello.
I installed install_dsPIC_R2008a, I do not see the block "dbl-click to open Graphical Interface." I could give any solution.
Thank you for your prompt response.
German Enrique Cruz
Greetings from Chile.
Hola.
He instalado install_dsPIC_R2008a, no me aparece el bloque "dbl-clic to open Graphical Interface". Me podrían dar alguna solución.
Gracias por su pronta respuesta.
Germán Enrique Cruz
Saludos desde Chile.
German Enrique Cruz
Hola.
Germán Enrique Cruz
Re: does not appear Interface tx-Matlab
Are you looking for this block ?
Double click on this block is the equivelent to type at the matlab prompt :
>> rs232gui
>> rs232gui
I have the same problem. In the "Simulink library browser" -> "Embedded Target for Microchip dsPIC" -> "Serial port" the "Interface Tx-Matlab" block is not visible, even if the Matlab command "rs232gui" works fine. To use the "Interface Tx-Matlab" block I have to click with the right mouse button on the library "Serial port" in the "Simulink library browser" and select "Open the serial port lybrary", in this way the block shows up.
I hope this can help.
PS: I'm using Matlab R2007b
Hi, Thanks for reporting this problem. It should be solved on the very last version of the blockset 0.98c, experimental now. (download if only from the release note page ; Bottom of the page)
