Installation failure on matlab 6.5
I've tryed to install the dsPIC toolboxe :
I used all versions of install_dsPIC_R200x.x, its's the same result. I use matlab 6.5.
What could be the problem ?
Thanks in advance
</i>>> install_dsPIC_R2006a
INSTALLATION RTWdsPIC
Reading the archiv
Checksum test passed (12C36605504AC)
RTWdsPIC version none
RTWdsPIC time stamp 21-May-2008 21:14:35
Importing the archiv 100% |******************************|
Toolbox folder is C:\MATLAB6p5\toolbox\MPLAB
Make directory C:\MATLAB6p5\toolbox\MPLAB\blocks
Make directory C:\MATLAB6p5\toolbox\MPLAB\dspic
Make directory C:\MATLAB6p5\toolbox\MPLAB\examples
ERROR OCCURED
during installation
Undefined function or variable 'savepath'.
No error in the installation I/O process.
errorcode is 97.7
----------------------------I used all versions of install_dsPIC_R200x.x, its's the same result. I use matlab 6.5.
Thanks in advance
Re: Installation failure on matlab 6.5
Hi Pick,
The blockset support matlab, starting from version 2006a, i.e. Matlab V7.2 (january 2006)
It is not gonna to work on earlier matlab version.
