MPLAB matlab
MPLAB matlab
How can solve the following problem please?
C:\Program Files\Microchip\MPLAB C30\bin\pic30-coff-ld.exe: cannot open linker script file C:\PROGRA~1\MICROC~1\MPLABC~1\support\gld\p30f3012.gld: No such file or directory
gmake: *** [..\../mos11.coff] Error 255
### Real-Time Workshop build procedure for model: 'mos11' aborted due to an error.
The file mentioned "P303012.gld" exists and in the directory mentioned as well.
Re: MPLAB matlab
I do not have enough information to help.
Are you compiling inside matlab or using MPLAB ?
Similar question have been posted on the forum. Could you check if one response would not correct the problem ?
Re: MPLAB matlab
Thank you so much Lubin
i would like to compliment you. you really did an excellent job BRAVO
For the problem i had solved it
