Main Page
- Download the Toolbox
- List of Examples
- Pricing
- Review
- Forum
Supported Chip : ----
| PIC 24F | ' | PIC 32F** | ' | PIC 30F | ' | PIC 30F | ' | PIC 33FJ GP | ' | PIC 33FJ MC | ' | PIC 33FJ GP | ' | PIC 33FJ MC* |
| 24fJ128GA006 | 32MX360F256L | 30f2010 | 30f5011 | 33fJ128GP206 | 33fJ256MC510 | 33fj128GP202 | 33fj128MC202 | |||||||
| 24fJ128GA008 | 32MX360F512L | 30f2011 | 30f5013 | 33fJ128GP306 | 33fJ256MC710 | 33fj128GP204 | 33fj128MC204 | |||||||
| 24fJ128GA010 | 32MX460F256L | 30f2012 | 30f5015 | 33fJ128GP310 | 33fJ64MC506 | 33fj128GP802 | 33fj128MC802 | |||||||
| 24fJ64GA006 | 32MX460F512L | 30f3010 | 30f5016 | 33fJ128GP706 | 33fJ64MC508 | 33fj128GP804 | 33fj128MC804 | |||||||
| 24fJ64GA008 | 32MX775F256L | 30f3011 | 30f6010 | 33fJ128GP708 | 33fJ64MC510 | 33fj32GP302 | 33fj32MC302 | |||||||
| 24fJ64GA010 | 32MX775F256L | 30f3012 | 30f6011 | 33fJ128GP710 | 33fJ64MC706 | 33fj32GP304 | 33fj32MC304 | |||||||
| 24fJ96GA006 | 32MX795F512L | 30f3013 | 30f6012 | 33fJ256GP506 | 33fJ64MC710 | 33fj64GP202 | 33fj64MC202 | |||||||
| 24fJ96GA008 | 30f3014 | 30f6013 | 33fJ256GP510 | 33fJ128MC506 | 33fj64GP204 | 33fj64MC204 | ||||||||
| 24fJ96GA010 | 30f4011 | 30f6014 | 33fJ256GP710 | 33fJ128MC510 | 33fj64GP802 | 33fj64MC802 | ||||||||
| 24fJ16GA002 | 30f4012 | 30f6015 | 33fJ64GP206 | 33fJ128MC706 | 33fj64GP804 | 33fj64MC804 | ||||||||
| 24fJ32GA002 | 30f4013 | 33fJ64GP306 | 33fJ128MC708 | |||||||||||
| 24fJ48GA002 | 33fJ64GP310 | 33fJ128MC710 | ||||||||||||
| 24fJ64GA002 | 33fJ64GP706 | |||||||||||||
| 24fJ16GA004 | 33fJ64GP708 | |||||||||||||
| 24fJ32GA002 | 33fJ64GP710 | |||||||||||||
| 24fJ48GA002 | ||||||||||||||
| 24fJ64GA002 | ||||||||||||||
- Newly added chip
- 64MC204, 128MC204, 128GP202, 32MC202, 32MC204, 16MC304 , 33FJ256GP710A
- * PIC 32F
- SPI function not suported yet;
- * Compiler known and fixed bugs
- * Check your compiler installation and version
- at the matlab prompt ==> !pic30-gcc -v for pic30 and !pic32-gcc -v for pic32.
- **Check pic32 compiler v 1.04 Workaround
- **Check pic30 compiler PWM 2 Workaround from version v 3.12 to current version (3.25)...
