SPI communication between two dsPIC
Revision as of 03:00, 15 February 2011 by LubinKerhuel (talk | contribs)
SPI Circuit
Description
Photo of a scope showing 5 SPI trames which were sent with a 1ms interval (model time step). One trame is highlighted in yellow. The bottom part is the clock signal (Clk). The clock is active high, thus its physical level is low (0V) between trames and send 16 ticks @ 39kHz (SPI bus speed defined in SPI configuration block). The top part is the SDO pin for the emitter which sent the 16 bits data on this wire. SDO is connected to SDI pin at the receiver side which sample the data using the clock signal.
SPI acronym stands for Serial Peripheral Interface. It is a numerical bus that in its standard form use 4 wires :
  • One clock (clk) *One output data (SDO for Serial Data Out) *One input data (SDI for Serial Data In) *One Chip Select (CS)
The PWM wire is removed.
1 capacity added on the SPI clock input pin of the slave microcontroller
Data are sent from A ==> B but no data are sent from B ==> A. Thus only one data wire is required here. The SS pin (that is the SPI chip select when configured as slave) is not workable on the dsPIC 30f4012. The SPI slave peripheral is always enabled. Thus, the CS wire is not required also. Thus only two wires are necessary : The Clk for the Clock. The SDO (output) pin of A is connected to the SDI (input) of B. .
Simulink models
Model A: Emission
Execution time use 2.25% of a time step.
SPI BUS write
Model B: Reception
Simulink model B: SPI_b_30f4012
Matlab plot of the data sent by microcontroller B through UART. The rs232gui interface is used to plot incoming data in real-time
