SPI communication between two dsPIC
Revision as of 02:11, 5 January 2011 by LubinKerhuel (talk | contribs)
Description
The objective of this example is to demonstrate how to use a SPI bus to transmit data between two microcontrollers. Two dsPIC (30f3012) exchanges numerical values through a SPI bus. Both dsPIC are programmed using blocks from the dsPIC blockset for simulink available on this website. This example was added in the blockset version 3.4.
Next to come...
