Release Notes
Revision as of 17:26, 8 October 2011 by LubinKerhuel (talk | contribs)
  • 08/10/2011: v3.7
    • Bugfix: Simulink model Error report were corrupted by the blockset. link (forum)
    • Bugfix: Constant problem reported with older matlab (R2007b, perhaps affecting also R2008 and R2009... (forum))
  • 11/09/2011: v3.6c
  • 07/09/2011: v3.6b
    • details comming soon
  • 25/07/2011: v3.6
    • Chip added : 256GP710A
  • 15/05/2011: v3.5b
  • 21/04/2011: v3.5
  • 01/03/2011: v3.4c
    • Examples updates
  • 13/01/2011: v3.4b
  • 30/12/2010: v3.4
  • 24/12/2010: V3.3c
  • 05/12/2010: v3.3b
  • 21/11/2010: v3.3a
  • 8/11/2010: V3.3
    • Corrected bug:
  • 23/07/2010: V3.2c
  • 31/03/2010: V3.2b
  • 28/03/2010: V3.2
  • 17/11/2009: V3.1
  • 26/09/2009: V3.0b
  • 26/09/2009: V3.0
    • change version numbering
  • 04/09/2009: V0.99h
  • 08/07/2009: V0.99g
  • 04/06/2009: V0.99f
  • 04/06/2009: V0.99e
  • 19/04/2009: V0.99d
  • 12/03/2009 V0.99c
  • 01/02/2009: V0.99b
    • added 4 chip...
  • 28/10/2008: V0.99a
