Electronic schematic connected to an Explorer 16 board. This board power the DC motor with a PMW signal. The PIC OC1 pin generate a PWM signal with controllable duty cycle that control a MOSFET transistor: FDC6305N. The back EMF is measured via the AN5 channel of the explorer 16 board. The overall system is powered here at 3.3V but could be powered with higher voltages.
Measuring the Back EMF
This model makes the motor PWM duty cycle increasing linearly increasing thus the picooz rotor's speed rate. For each different ducy cycle, channel 5 of the ADC (AN5) is sampled 120 times at 1200 different location within the PWM periode. Datas are sent through the UART 2 for analysis.
Back EMF Measurement. Up : Back-EMF at different instant within the PWM period. Down : Back-EMF at the PWM instant period 11980 for different PWM duty cycle (i.e. for different motor speed). This last curve provide an estimation of the motor speed.
  • The Sampling position within PWM period
  • The PWM duty cycle
Identification of the motor's dynamic. The black line is the filtered measurement of the moto's back EMF in response to a chirp stimulation (at constant amplitude). The red line is the result of the simulated model, identified with theses data. We get a 72% fit.
The design of a controller requires a model. A second simulink model programs the microcontroller to test the dynamic response of the motor. The Back EMF is there always sampled at the instant 11970 (we takes some safety margin). The PWM duty cycle is now a chirp signal (sinus with increasing frequency) that makes the motor to accelerate and to slow down at increasing frequency. We supposed that the Back-EMF is an image of the moto speed rate. Thus, the motor model is identified using the matlab ident graphical user interface.
<Tex>G_{motor}(p) = \frac{-24.62}{(p+78.65)(s+9.78)}</Tex>
Controller design
Sensorless speed controller : State Space Controller implemented on the PIC32 microcontroller using Simulink.
The controller is designed keeping with theses two constraintes :
  • The implementation of the PWM output on the OC1 pin is quite sensitive to noisy set point (see blocks page). Thus, the controller command signal should have a reduced noise level.
  • The continuous decrease of the battery level act as a continuous perturbation on the controller. Thus, rejecting with no steady states error this perturbation requires at least one integrator within the controller loop.
I decided to use an augmented state space model. A state space model has the advantage over a PID or PI only system to filter the output thanks to the internal model. The augmented stats is the integral of the error, providing thus a controller with no steady state error.
We use the matlab new command lqi (available from Matlab 2008b) to compute the matrix gain K. The observer gain L is computed so as to get an observer pole as slow as the slowest pole of the close loop control system. Such a low gain allow to filter efficiently noise comming from the PWM measurement.
Ts = .002;  % Controller Sample time
Picooz_Mrotor = zpk([],[-78.68 -9.787],-24.6222);
Picooz_Mrotor_z = c2d(Picooz_Mrotor,Ts,'zoh');
[Picooz_Mrotor_z_ss,T] = canon(Picooz_Mrotor_z,'modal');
      % transformation pour calculs plus simple x ==> T*x
[Az,Bz,Cz,Dz,Te] = ssdata(Picooz_Mrotor_z_ss);
[m,n] = size(Az);
%% Augmented state space synthesis (K)
R = 1;
Q = diag([1 1 2e6]);
[K,Z,e] = lqi(Picooz_Mrotor_z_ss,Q,R,0);
%Poles en continue :
log(eig(Az))/Ts     % System Natural Poles
log(e)/Ts           % Poles in close loop
PolesControlleur_s = log(e)/Ts ;
%% Observer L Synthesis
poleLent = abs(PolesControlleur_s(1:end-1))
PlacementPolesObs = exp(-poleLent * Ts * 1 );  %*3 usually
L = acker(Az',Cz',PlacementPolesObs');
%% Simplification
% Az is diagonal (thanks to the cannon command)
Az = diag(Az)';
We get results for L and K : L = [-0.0593 0.826] and K = [0.5 1.2 1363.9]. With this design, the new motor time constant is The time constant of the motor <Tex>\tau_{CloseLoop} =70ms </Tex>. Thus a 30% improvement. This improvement is not very huge. We are limited here by the necessity to have a low noise command signal. However, the close loop will counteract for the battery decreasing power.
Results
