Analysis of the Logged datas
Necessity to merge measurement from rate gyro and Accelerometers
Rate Gyro and Accelerometers data fusion algorithms
Simulation with real data
The raw data feeds a block called Sensor Calibration. This block removes bias of rate gyro and accelerometers. Because we use the arctan function, the accelerometer axes do not need to be scaled.
Three angle estimation method are tuned and compared:
Non adaptative Kalman Filter
to be continued...
- M script
- Mat files
On-going projects
