Revision as of 08:47, 14 October 2010 by LubinKerhuel (Talk | contribs) (Acknowledgement)
Jump to: navigation, search
One rate gyro (ADIS 16080) with the simple material used for soldering. Thin wires come from a washing machine motor's coil.
Let's consider:
  • model time-step is 1ms
 >> [R T] = padr(Rn,1,t_Rn);     % remove NaN values
 >> datas = [T R]';
 >> save mydatafile datas;
idxError = find(R(1,:) ~= 55)  % Check data integrity
IMU Data fusion algorithms
Simulation with real data
  • The high pass filter is:
State Space Approach
The state space structure tracks the rate gyro bias and estimate the angle by integrating the unbiased gyro.
  • Simulink models
    • IMU_Simulation.mdl
    • IMU_Simulation_FxdPts.mdl
  • m script
    • Extract_RawDatas.m
    • Script_Kalman.m
    • Caracterisation_Capteurs.m
  • mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
Implementation on a dsPIC
Complementary Filter Order 1
This model implements the complementary filter on the dsPIC and sends the result to matlab. It has the same behaviours as the simulated filter.
The IMU_ComplementaryFilter simulink model is a 'copy-past' mixture made of the IMU_LogData 'data management' part with the IMU_simu_RealData model tuned and optimize filter. This model implements the complementary filter on the dsPIC and sends the result to matlab. It will have the same behaviours of the simulated filter.
Fixed point
  • it takes a roll angle, then
Electronic board evolution
Extended IMU algorithm
This IMU is being tested onboard a Remote Control (RC) flying wing. It is destined to become an important part of the autopilot currently under development. For more information, see page :
Acknowledgement
