Importing Simulink Generated Code into Mplab
Step 1 : Simulink
- Compile the model
Step 2 : MPLAB
from Version 3.3 of the blockset, a MPLAB project file is created. Thus, you just have to compile once the project in MATLAB and then open the created MPLAB project. The following steps are no more required !
- Create a new project
- Compile
Remarks
Know bug
Enable comment auto-refresher
