Hyper Sampling
Revision as of 18:13, 1 March 2009 by LubinKerhuel (talk | contribs) (New page: thumb|right|250px|RC filter The objective of this example is to demonstrate the synchronization of the ADC sampling time with PWM generated signal. The rise and fa...)
The Electronics – RC filter
Principle
The filter output signal is
  • Periodic
  • Time invariant
Simulink model file
Results
Looking deeper
Acknoledgement
