File:IMU dsPIC 30f4012 TestElectronics.png
Original file (711 × 610 pixels, file size: 26 KB, MIME type: image/png)
IMU_dsPIC_30f4012_TestElectronics Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the values from the X, Y and Z axis of the accelerometer, and the Y and X axis of the rate gyro. Data are sent to Matlab (or labview) through the UART at 115200bps with the Tx Output Multiplexed for Matlab-Labview block. All data cannot be send ; there will be missing data thus this model is usefull to check every component is working only.
current | 13:29, 12 July 2008 | 711 × 610 (26 KB) | LubinKerhuel (talk | contribs) | IMU_dsPIC_30f4012_TestElectronics Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the values from the X, Y and Z axis of the accelerometer, and the Y and X axis of the rate gyro. Data are sent to Matlab (or labview) through the U |
